Forum: VirtualDJ Skins
Topic: Black is Back!!! Updated: JN-Black v2.06 - Page: 2
erxonPRO InfinityMember since 2003
Oh well, guess I'm not that "experienced" afterall :P Thanks for explanation.
geposted Wed 09 Mar 05 @ 2:23 pm
Black power ¡¡¡¡¡ thzx Jim.
geposted Wed 09 Mar 05 @ 11:58 pm
djcelPRO InfinityModeratorMember since 2004
In the pannel cue , could you add two columns of goto cue. I mean the normal "goto and play" as currently and a new one with [cue_stop(n° cue)] for "goto and pause"
geposted Sat 12 Mar 05 @ 7:25 pm
DJ RickPRO InfinityMember since 2003
It might be good also if we have the ability to adjust/move the cgb. I've seen this on other skins, and I actually thought it came in handy pretty often to be able to make an adjustment when needed.
BTW, I used this skin last night. As I thought, when it was time to get mixing I couldn't really see the wav form colors good enough, so I switched to split screen, and all was better than ever! This may be the single best skin ever created for VDJ.
(my humble opinion) :-)
geposted Sat 12 Mar 05 @ 8:10 pm
bmac16PRO InfinityMember since 2005
Jim,
Great Skin! Best one out there right now. When you do your next update can you add two items.
Full Screen - It seems that this function isn't available on this version. My skin covers only 2/3 of my computer screen.
Also for us former CD player dj's a +/- for Pitch bend would be great. I currently use my keyboard for this function but I would rather have it available in your skin. I'm not a big fan of the rotary nudges.
Thanks
BMAC
geposted Thu 07 Apr 05 @ 4:34 pm
BMAC:
This skin has a full-screen mode, but it is made in a widescreen resolution (9:6), not 4:3 as your monitor. It's intended for widescreen laptop monitros mostly, but another 4:3 version might be made if Jim has time.
Regards
geposted Thu 07 Apr 05 @ 10:11 pm
Jim,
I'm a big "platinum" user...if "black" had a 1024x768 cousin and the "pro" mode you mentioned, I would be hooked!
Are you still reading this? Stop...go mod it for me. It's my right to demand new skins...I mean, that's what you guys get paid for, right? ;)
Seriously, nice skins...great job!
Break.
geposted Fri 08 Apr 05 @ 7:10 am
erxon,
Thanks for the quick response. Would It be easy to go into the skin's XML and change the screens width to fit a 4:3 screen?. All help would be appreciated.
Regards
geposted Fri 08 Apr 05 @ 3:45 pm
It's not easy to convert the size of a skin. You need to move all the butttons,sliders,... one by one to convert it. Each Line of the xml to rewrite. Good luck with it exists only a convert from 800x600 to 1024x768 from Kaleo (see plugins download section) but that's all
geposted Fri 08 Apr 05 @ 4:26 pm
Hi Guys!
To make a skin in different resolutions takes time (lots of it). If I had the time, I would do it. But since I don't get paid for the hard work... there is few incentives for me to spend days making skins. I only make skins that I myself use.
I do make minor (and major) tweaks and adjustments that people suggest. But I do not have time to make a skin in different resolutions. I'm sorry.
But I don't mind people changing my skins and adjusting them to fit their needs. And I do suggest you learn how to code skins to fit your needs.
Cheers!
- Jim Nordic
geposted Sat 09 Apr 05 @ 12:04 pm
Hi Jim-
I think your skin is the best and it is the one I use. In my resolution too! Keep up the great work and keep posting your upgrades as you make them.
Thanks!
geposted Wed 13 Apr 05 @ 6:30 pm
vailixiPRO InfinityMember since 2005
Jim,
I've used your skin on my desktop computer only, because of the widescreen format....and I must say.....it is the best yet. Unfortunately, I play mostly outdoor psytrance renegades/festivals and bringing my desktop isn't practical.I will pay you for a 1024x768 JN-Black v2.06 skin so that I can use it on my laptop. vax
geposted Tue 07 Feb 06 @ 7:13 pm
