quick question about the skin resizer,do u have to have the licensed copy in order to actually use the skin? Im trying to resize a mixstation skin to 1440 x 900 and it creates the xml file but i cannot access the skin in the actual vdj program
i also get the messege " problem reading license number " when i open the resizer
any help is appreciated
geposted Thu 19 Mar 09 @ 1:25 pm
The Skin resizer you can download without any problem and you can make changes to your skin, but if you want to change your browser and add the edges then you must make a donation to the tool Jeremk
geposted Thu 19 Mar 09 @ 1:51 pm
Hi,
what version of the Skin Resizer are you using?
Version 2.0 introduced a bug in the picture saving function, this was corrected in version 2.0.2 available here
geposted Thu 19 Mar 09 @ 4:52 pm
i have downloaded the new version but i still get the messege " problem reading license number " and the resize skin screen only shows half of the screen,with no do the job button, it creates the file and it is in my skins folder but when i try to use the new screen it dosent show up in the skin folder in the actual vdj program
geposted Thu 19 Mar 09 @ 5:17 pm
geposted Wed 25 Mar 09 @ 7:40 am
skins and plugins are only accessible to licensed users, where did you get the mixstation skin from...
please register your license so you can gain access to these skins.
geposted Wed 25 Mar 09 @ 9:49 am
