Hi!
Im trying to play and try some videomixing for first time, but some .avi files cant be played, why is that ?
Its just reading "ERROR", and when im looking at file path, its reading "the file can be played in video decoder, its impossible to play file".
Whats that mean, will it work in Pro-version ? Some .avi files works, and some not, thats strange.
Thanks in advance!
/Fredde
Thanks in advance!
/Fredde
geposted Tue 14 Apr 09 @ 4:59 am
check have you the current version of directx and c++ installed...
geposted Tue 14 Apr 09 @ 5:16 am
Remember that AVI is also a carrier package, the avi's could be divx, xvid or some other codec, drag the file into a util like videoinspector :-
http://www.kcsoftwares.com/index.php?vtb
And see what codec it uses and make sure you have the necessary codec installed.
geposted Tue 14 Apr 09 @ 6:27 am
Hi!
When i open a file in videoinspector its says "Valid: No".
So does that mean i have to convert them somehow ?
Some videos are working in both VDJ and videoinspector so i dont think there is any problems with DirectX or c++, but im not sure, i havent tried to update thoose.
/Fredde
/Fredde
geposted Tue 14 Apr 09 @ 7:30 am
Hi!
Still not work, this is how it looks:
http://i302.photobucket.com/albums/nn85/Freddeme/aviproblem.jpg?t=1239742623
What can i do ?
Like i said, some avi-files work and some not.
Thanks in advance :-)
/Fredde
What can i do ?
/Fredde
geposted Tue 14 Apr 09 @ 3:58 pm
Maybe it's a codec that videoinspector doesn't recognise, try mediainfo
geposted Tue 14 Apr 09 @ 7:12 pm
Hi!
I dont what i do in Mediainfo, this is how it looks:
http://i302.photobucket.com/albums/nn85/Freddeme/aviproblem2.jpg?t=1239777684
Can it be that thoose avifiles are damaged if they not opened ?
/Fredde
/Fredde
geposted Wed 15 Apr 09 @ 1:43 am
Dj Freddem,
Virtual dj can play mpg files the best.
What you can try is to convert them to mpg and try it again.
A good converting software is Magic Converter: http://www.brothersoft.com/magic-converter-23248.html
Give it a try and set everything to best quality.
geposted Wed 15 Apr 09 @ 7:27 am
Looks like they could be corrupted in some way, the thing is that at present there are so many confusing codec varations around that it occasionally happens, the advice re mpeg above is correct, but if the files are corrupt then a converter wont be able to read them. Do they play in VLC media player, VLC will play practically ANYTHING.
geposted Wed 15 Apr 09 @ 9:19 am
Hi!
No, thats the strange thing, thoose files that VDJ cant read, cant either VLC read/play, so im guess the are in some way corrupt.
geposted Wed 15 Apr 09 @ 9:21 am
I think you're guessing right.
geposted Thu 16 Apr 09 @ 5:10 am
TOPHOUSE, thanks for the lead on "videoinspector" that's a handy little program.
(The only thing that seems odd it won't read .vob files. I tried renaming it to mpeg and then it read the video stream but not the audio?
geposted Thu 16 Apr 09 @ 12:16 pm
I think mediainfo reads vobs though renee, hang on a sec........ yes it does, also GSpot is very good (ha, don't you know it!)
geposted Thu 16 Apr 09 @ 3:00 pm
It's been a while but yes I remember, or you could hum a few bars?...
(I found the program, works great.... thanks.
geposted Thu 16 Apr 09 @ 5:09 pm
hey,when i was trying to record a movie in vdj,i pressed record and it said that there was no codec found ,so i looked @ codecs in the optionmenu and in that menu there where lots off videocodecs ,
what the hell happend??
please help me,im making an aftermovie and everything when't good when trying it so i wan't to start recording very fast
geposted Mon 29 Nov 10 @ 4:12 pm
This is an old thread on a different topic; please start a new topic with all the information.
geposted Mon 29 Nov 10 @ 4:55 pm
