hi can sombody tell me where do i get sonique visual? i boght vdjpro but it does not have any visuals.please if someone knows.
geposted Thu 23 Apr 09 @ 11:48 am
Sonique visuals can be downloaded from the plugins section of the site ( http://www.virtualdj.com/addons/index.html ):
http://www.virtualdj.com/addons/4207/72_Sonique_Visual_plugins_certified.html
geposted Thu 23 Apr 09 @ 12:18 pm
thanks a lot man ,that really help and I'sorry if it was a stupit question....once again thanks
geposted Thu 23 Apr 09 @ 1:10 pm
I have downloaded the Sonique Visuals but for some reason I'm have trouble getting Cue/VDJ to load it. I have downloaded a bunch of things from here and I can't get them working. After downloading any of the plugins/effects, how do you get them into VDJ? A tutorial or explaination is needed...Please and thank you!
RuDeDoGG
RuDeDoGG
geposted Thu 23 Apr 09 @ 4:50 pm
- Copy the .svp files into a folder, e.g: My Documents\VirtualDJ\Plugins\VideoEffect
- In VirtualDJ, go to Effects -> Video Effects -> Soniquie
- Click on the Open button. Browse to the folder where you copied the .svp files and click on one of them.
- Click SLIDESHOW to enable a changing slideshow for variety.
- Recommended: Go to CONFIG -> Video and choose Sonique in the 'Use this plugin for audio-only files' box. This will automatically use sonique visuals when playing audio files.
geposted Thu 23 Apr 09 @ 7:12 pm
@azen & rudedog, made these for other users a while back, hope it helps... sorry jp, just thought visuals are normally a lot easier to understand sometimes and would help your explanation.
how to - use plugins for the first time
how to - use soniques
Go into config > choose video tab > go down to the bottom right drop down window and select sonique, to the left make sure you tick the box, come out of config and select effects > select video tab > select sonique > select/click on activate > select open > this is where you go to where you have your sonique folder, now open the folder and double click on a file, this will now run your sonique effects. you can now play with the two sliders for the type of effect you want. slide show delay will give you how long each effect will run for and the transparency will let you fade the soniques over other effects like a video, show logo etc...
N.B If you have the time go through your individual soniques and delete the crappy ones, saves getting them up on the screen.
geposted Thu 23 Apr 09 @ 7:28 pm
