Hi:
Anyone know links to develop Video plugins from sractch?. I want to develop my first video plugin and realy I don't know how to start.
Realy need a good tutorial which explain in detail how to start and show all the commands I cabn use.
Hope any can help me.
Thanks
Thanks
geposted Mon 11 May 09 @ 10:05 pm
I've done quite a few now...
You'll need C++ and DirectX skills - the level of skill required depends on what you are trying to acheieve.
Regards,
Scott
Regards,
Scott
geposted Tue 12 May 09 @ 5:51 am
Thanks for answer
For example you developed a plugin named SCROLLING TEXT.
Is possible to send to me the source code in order to have as a guide and learn about it?
I have C++ skills and some of Directx as well, but need some examples in order to start.
Hope you can help me.
Regards
walter D.
Regards
walter D.
geposted Tue 12 May 09 @ 5:43 pm
Scrolltext is quite a large video plugin, definately not a good starting point ;)
geposted Tue 12 May 09 @ 6:11 pm
No Matter, because I can learn a lot from it.
It has a windows, buttons, scrolls buttons, text editor, and video (text controller).
If you can send me it will be very appreciatted
Regards
walter D.
Regards
walter D.
geposted Tue 12 May 09 @ 6:15 pm
Most of what you listed there is just basic dialog handling :)
geposted Tue 12 May 09 @ 6:33 pm
so, if possible to it send me?
geposted Tue 12 May 09 @ 10:06 pm
I'm afraid not.
What effect are you trying to accomplish?
If you have the SDK, then you have the barebones of a video effect plugin already :)
geposted Wed 13 May 09 @ 7:16 am
Ok, More simple.
Do you have a plugin (source code) for example to only put a "X" in the center of the output video screen when the plugin is activate?
Regards
Walter D.
Regards
Walter D.
geposted Wed 13 May 09 @ 11:23 am
"X" as drawtext, "X" as createtext, or "X" as a polygon?
geposted Wed 13 May 09 @ 12:10 pm
Lest start with "X" is a drawtext
Thanks for your help
Regards
Regards
geposted Wed 13 May 09 @ 2:43 pm
you can use the functions D3DX... :
http://msdn.microsoft.com/en-us/library/bb173961.aspx
#include <d3dx9.h>
#pragma comment(lib,"d3dx9.lib")
ID3DXFont *p_Font;
D3DXCreateFontIndirect(D3DDevice,...,&p_Font)
p_Font->DrawText(...)
geposted Wed 13 May 09 @ 4:41 pm
