Latest Hercules Console Driver PC & MAC
http://ts.hercules.com/eng/index.php?pg=files_faq
If you are using Vista, it is important you install as an administrator or vista will install all wrong, by default Vista makes all people limited users with limited powers.
Latest Virtual DJ Hercules Console Editions
Insert your VDJ Console edition serial number here http://www.virtualdj.com/users/edit.html
and download latest update here http://www.virtualdj.com/download/updates.html
Special time-limited offer for the release of the DJConsole RMX, STEEL & Trim 4&6 (Scratch Starter Kit)
This is the link: http://www.virtualdj.com/buy/index.html
enter your VirtualDJ DJC serial number HERE to get a 150$ discount off the regular price
![](http://img84.imageshack.us/img84/6562/aaaw2.jpg)
Virtual DJ Performances
![](http://img338.imageshack.us/img338/3310/16403449lu5.gif)
Internal mixer mode (Standard use with Headphone connected to the Console)
MK2 PC
![](http://it.virtualdj.com/image/oldblog/9/83792/image.jpg)
MK2 MAC
![](http://img266.imageshack.us/img266/6200/macandmk2headphonesvb3.jpg)
RMX PC in WDM
![](http://img363.imageshack.us/img363/236/rmxzh0.gif)
RMX PC in ASIO (this mode enable the external inputs and time code)
![](http://img363.imageshack.us/img363/91/rmxasioqx9.gif)
RMX MAC
INPUT : none
OUTPUT : headphone
SOUNDCARD : 4 out card (no DJCONSOLE RMX icon)
DRIVER: Hercules Dj Console RMX
MK2 External mixer mode (With Headphone connected to an external mixer)
Step 1
![](http://it.virtualdj.com/image/oldblog/6/83792/image.jpg)
Step 2
Go in option and select Crossfader > Disabled
Now if crossfader is linked to video you can use only to crossfader the video but no audio.
Step 3 (Set "Use External mixer" in English)
![](http://it.virtualdj.com/image/oldblog/11/83792/image.jpg)
Ps. Any restart of Virtual DJ require a new External mixer selection into the Hercules MK2 panel.
RMX External mixer mode (With Headphone connected to an external mixer)
![](http://img387.imageshack.us/img387/2548/aazu2.gif)
More info about Hercules Hardware Products:
DJ Console Rmx -> http://www.hercules.com/uk/DJ-Music/bdd/p/62/dj-console-rmx/
DJ Control Steel (no integrated sound card) -> http://www.hercules.com/uk/DJ-Music/bdd/p/83/dj-control-steel/
DJ Console MK4 -> http://www.hercules.com/uk/DJ-Music/bdd/p/125/dj-console-mk4/
DJ Control MP3 e2 (no integrated sound card) -> http://www.hercules.com/uk/DJ-Music/bdd/p/110/dj-control-mp3-e2/
Trim 4&6 Sound Card -> http://www.hercules.com/uk/DJ-Music/bdd/p/102/deejay-trim-4-6/
Trim 4&6 Sound Card (Scratch Starter Kit) -> http://www.hercules.com/uk/DJ-Music/bdd/p/119/deejay-trim-4-6-scratch-starter-kit/
DJ Console MK2 -> http://www.hercules.com/uk/DJ-Music/bdd/p/12/dj-console-mk2-virtualdj-djc-ed/
DJ Control MP3 (no integrated sound card) -> http://www.hercules.com/uk/DJ-Music/bdd/p/14/dj-control-mp3/
Old Topics:
Hercules MP3/MK2 - Setup, Solutions, Fixes, Issues, etc...
Hercules RMX/Steel - Setup, Solutions, Fixes, Issues, etc...
MK2 PC
MK2 MAC
RMX PC in WDM
RMX MAC
INPUT : none
OUTPUT : headphone
Step 1
Step 2
Old Topics:
geposted Fri 22 May 09 @ 3:35 am
do you have a driver for Hercules RMX functioning with Windows 7 ?
geposted Sat 30 May 09 @ 11:11 am
No, Hercules have not released one. When Windows 7 is officially released then I guess Hercules will have a Driver package ready.
You could try this though (bottom post)
geposted Sat 30 May 09 @ 11:24 am
Mac OS X driver package for DJ Console Series - Version 1.36 2009-05-29
Supported products
- DJ Control Steel
- DJ Console Rmx
- DJ Console Mk2
- DJ Control MP3
Installation procedure:
1- Click the link below to download the new driver for your Hercules DJ product
2- Once the download is complete, double-click the installation file and follow the instructions provided to install your drivers.
NOTE: At the end of the installation, you may be prompted to update your firmware version if you have not already updated it. Please be sure to strictly follow the on-screen instructions for this very important procedure.
Minimum System Requirements:
- MAC OS X 10.4 (Tiger) or 10.5 (Leopard)
- G4/G5 1.5 Ghz OR Intel Core Duo 1.66 Ghz and higher
- 512 Mb RAM
Changes :
- Correct the "error in sound driver" problem in Virtual DJ after upgrading to OS X 10.5.7 (Aggregate Device)
[OS X 10.4 (Tiger) / 10.5 (Leopard)] 4 MB
ftp://ftp.hercules.com/pub/webupdate/DJCSeries/DJSeriesInstall_1_36.pkg.zip
Supported products
- DJ Control Steel
- DJ Console Rmx
- DJ Console Mk2
- DJ Control MP3
- 512 Mb RAM
Changes :
geposted Sun 31 May 09 @ 10:48 am
Just installed Pro Version Virtual 6.0 but it is not recognizing the hercules Remix....It has worked fine with previous version (i Believe it was 5.2) i skipped a version before i downloawded 6.0)...Please help need it to work for the clubs...
geposted Mon 01 Jun 09 @ 8:38 pm
Did you update to the latest drivers?
geposted Mon 01 Jun 09 @ 8:50 pm
The Updated drivers worked...Thanks as always with the quick and correct instructions...
One last question. On the remix it has 6 function buttons..with #1 and #2 were for loop
#3 and # 4 were for speeding up slowing down to help match beats
#6 i used for the backspin/Brake etc...
How do i get that all back?
geposted Mon 01 Jun 09 @ 9:17 pm
You should be able to pick the options from the RMX skin. http://www.virtualdj.com/addons/4554/Hercules_RMX___Steel.html
If you want to hard set them ... then you can do that in the Config -> Mappers dialog.
geposted Mon 01 Jun 09 @ 9:24 pm
That did it...thanks as always
geposted Tue 02 Jun 09 @ 7:12 am
Maybee you could tell me how ik can intergrate mijn hercules control mp3 to version 6?
I would be verry happy to use it on the latest version :)
geposted Sat 06 Jun 09 @ 8:01 am
You might want to contact Hercules and find out if your firmware is properly installed
geposted Tue 09 Jun 09 @ 8:06 pm
I upgraded the drivers so it should be good
geposted Wed 10 Jun 09 @ 10:35 am
s there any plug in or download i can get to make virtual dj work with a wireless hercules dj mixer?
geposted Fri 12 Jun 09 @ 4:34 am
No.
geposted Fri 12 Jun 09 @ 5:28 am
Hercules DJ Console Series - 2009_HDJS_2 package
Installation:
1- Uninstall the previous driver version: to do so, click Start/Settings/Control Panel. Select the Add or Remove Programs icon, then uninstall Hercules DJConsole Series drivers. Alternatively, you can simply launch this package: it will uninstall the previous drivers for you.
2- Restart your PC.
3- Launch this package to install the new drivers.
4- At the end of the installation, you may be prompted to update your firmware version if you have not already updated it. Please be sure to strictly follow the on-screen instructions for this very important procedure.
5- You are now ready to use your DJ controller.
Supported products:
- DJ Control Steel
- DJ Control MP3
- DJ Console Rmx
- DJ Console Mk2
- DJ Console
Changes:
- Corrects a possible delay in updating the fader’s position in VirtualDJ
Download:
ftp://ftp.hercules.com/pub/webupdate/DJCSeries/2009_HDJS_2.exe
[Windows XP / XP 64 bit/ Vista x86 (32-bit) / Vista x64 (64-bit)] 18 MB
Installation:
2- Restart your PC.
Supported products:
- DJ Control Steel
- DJ Control MP3
- DJ Console Rmx
- DJ Console Mk2
- DJ Console
Changes:
Download:
geposted Sat 13 Jun 09 @ 3:33 am
I see that folks have been asking for it, so I've come up with a simple solution for jogwheel default (the one that is currently visible in the skin) effect slider adjustment that I would like to share with you.
The method described here uses the scratch button as shift...Use whatever button you'd like, or replace 'default' with the effect name and assign the additional actions to the button you've assigned for the effect, if you wish. This was tested on my RMX using hard-coded 6+6 buttons and the default widescreen VDJ6 skin.
SCRATCH action=vinyl_mode [add this] & set $shift while_pressed
JOG action=var $shift ? action_deck 1 ? effect default slider 1 : effect default slider 2 : jog_wheel
Happy spinnin' ;)
DJ Doc
Happy spinnin' ;)
DJ Doc
geposted Sat 13 Jun 09 @ 1:09 pm
Can someone help with the RMX mapping since I do want get all the default settings from previous version of VDJ pro? You can send me a link to the thread with the RMX mapping setup.
geposted Sun 14 Jun 09 @ 3:42 pm
Hello djspeaky09,
Do you mean you want to control VirtualDJ with Hercules Mobile DJ?
1) I think Atomix has released a version of VirtualDJ Pro which was at least partly compatible with this wireless DJ mixer.
2) Hercules has MIDI drivers for Hercules Mobile DJ in Windows, I have beta-tested this driver a long time ago, so if you want to control VirtualDJ Pro with this mixer, it is possible, but
- it requires VirtualDJ Pro to get VirtualDJ MIDI learning mode,
- a MIDI mapping won't use on Mobile DJ screens (you won't get on screen the name of the tracks, the BPM rate or the elapsed time) since the MIDI mapping doesn't include text, except if Atomix includes a management of the text.
geposted Mon 15 Jun 09 @ 3:17 am
Happy spinnin' ;)
DJ Doc
Happy spinnin' ;)
DJ Doc
DUDE! You are the man! I never would have figured that out! Really, I tried and I was not even remotely close. I owe you one, thank you, thank you, thank you very much.
geposted Mon 15 Jun 09 @ 5:09 pm
How can I use this same example to program my DN-S1200 FX2 button and the Jogwheel to control the effect slider? Can you be a bit more specific when using a different controller?
Happy spinnin' ;)
DJ Doc
Happy spinnin' ;)
DJ Doc
geposted Mon 15 Jun 09 @ 6:35 pm
