Forum: Old versions
Topic: Virtual DJ6 and Numark NS7 (genelar topic) - Page: 5
This is the midi map for NS7
LED OUTPUTS
CC 0 - FSTARTA
CC 1 - FSTARTB
CC 2 - XFADER Reverse
CC 3 - Prepare
CC 4 - Files
CC 5 - Crates
CC 6 - <EMPTY>
CC 7 - Sync Deck A
CC 8 - CUE Deck A
CC 9 - Play Deck A
CC 10 - Delete Deck A
CC 11 - Hot Cue 1 Deck A
CC 12 - Hot Cue 2 Deck A
CC 13 - Hot Cue 3 Deck A
CC 14 - Hot Cue 4 Deck A
CC 15 - Hot Cue 5 Deck A
CC 16 - Keylock Deck A
CC 17 - <EMPTY>
CC 18 - Motor Off Deck A
CC 19 - 1/2x Deck A
CC 20 - 2x Deck A
CC 21 - Loop On/Off Deck A
CC 22 - Shift Left Deck A
CC 23 - Shift Right Deck A
CC 24 - Loop Mode Auto/Manual Deck A
CC 25 - In / Auto Loop 1 Deck A
CC 26 - Out / Auto Loop 2 Deck A
CC 27 - Select / Auto Loop 4 Deck A
CC 28 - Reloop / Auto Loop 8 Deck A
CC 29 - Sync Deck B
CC 30 - CUE Deck B
CC 31 - Play Deck B
CC 32 - Delete Deck B
CC 33 - Hot Cue 1 Deck B
CC 34 - Hot Cue 2 Deck B
CC 35 - Hot Cue 3 Deck B
CC 36 - Hot Cue 4 Deck B
CC 37 - Hot Cue 5 Deck B
CC 38 - <EMPTY>
CC 39 - Keylock Deck B
CC 40 - <EMPTY>
CC 41 - Motor Off Deck B
CC 42 - 1/2x Deck B
CC 43 - 2x Deck B
CC 44 - Loop On/Off Deck B
CC 45 - Shift Left Deck B
CC 46 - Shift Right Deck B
CC 47 - Loop Mode Auto/Manual Deck B
Cc 48 - In / Auto Loop 1 Deck B
CC 49 - Out / Auto Loop 2 Deck B
CC 50 - Select / Auto Loop 4 Deck B
CC 51 - Reloop / Auto Loop 8 Deck B
CC 52 - VU Meter Left
CC 53 - VU Meter Right
CC 54 - Sync Meter Full On/Off
CC 55 - Quartz Lock Indicator Deck A
CC 56 - Quartz Lock Indicator Deck B
CC 57 - All Mappable LED Indicators ON
CC 58 - <EMPTY>
MOTOR FUNCTIONS
CC 65 - Deck A Motor Start (Forward)
CC 66 - Deck A Motor Stop
CC 67 - Deck A Motor Stop
CC 68 - Deck A Motor Stop
CC 69 - 33/45 RPM
CC 70 - Deck A Motor Reverse
CC 75 - Deck B Motor Start (Forward)
CC 76 - Deck B Motor Stop
CC 77 - Deck B Motor Stop
CC 78 - Deck B Motor Stop
CC 79 - 33/45 RPM
CC 80 - Deck B Motor Reverse
CC 81 - <EMPTY>
thru
CC 127 - <EMPTY>
the last list of MIDI CC is not complete
and get wrong inside.
my NS7 mapper is complete !
now igo to try all working test.
Temprary i work Without motor track, but the jogWheel in motion cause some problem to play.
Augh !
NS7 came in today and i love it i use virtual dj 5.2 anyone got a xml for this ?
you must have vdj 6 to make it run first ! and the map is not complete today !
How far are we on getting the NS7 to work with Virtual DJ 6?
dj-in-norway wrote :
Mapper will come ;) someone will make that pretty soon i bet ;)
[Jepordy theme playing in background]
who can give us the midi mapper with vdj 6.1 working in NS7? thanks! i has NS7 long time!i waiting the midi mapper!thank the guys can give us the midi mapper!
using the above table of CC commands, I've gotten the platters to start spinning and the LED lights for the Play button to work:
add these to the NS7 Definition file:
<led cc="0x41" ccoff="0x42" name="JOGWHEEL" default="PLAY" deck="1"/> //41 = start Deck 1 Motor; 42 = stop Deck 1 Motor
<led cc="0x09" name="LED_PLAY" default="PLAY" deck="1"/>
<led cc="0x1F" name="LED_PLAY" default="PLAY" deck="2"/>
Maybe this will spark some revived interest in getting this thing mapped. Gonna keep playing with it...I'll post any findings I come across, cause I know I want this thing mapped!! :)
Reall works, thanks. It is a kick off for me. So i will help so much i can.
Just to make things a little more clear...I'm using b1shop's zip file (test_090602.zip) as a starting point which includes a Definition file and mapper.
Hope that helps.
Yapp me too.
So far
<led cc="0x08" name="LED_CUE" default="CUE" deck="1"/>
<led cc="0x1E" name="LED_CUE" default="CUE" deck="2"/>
<led cc="0x07" name="LED_SYNC" default="SYNC" deck="1"/>
<led cc="0x1D" name="LED_SYNC" default="SYNC" deck="2"/>
Will continue tommorow. Let´s play footbal.:-)
I'm now trying to figure out how to get the Pitch sliders to work a little better. It seems they only respond to 1/64th of the actual slider. The same goes for the crossfader and volume control.
From B1shop's definition file:
<slider cc="0x24" ccmsb="0x04" name="PITCH" deck="1" />
<slider cc="0x25" ccmsb="0x05" name="PITCH" deck="2" />
Any help would be greatly appreciated.
Posting as I go:
<led cc="0x0A" name="LED_HOTCUE_DELETE_A" default="HOTCUE_DELETE_A" />
<led cc="0x0B" name="LED_HOTCUE_1_A" default="HOTCUE_1_A"/>
<led cc="0x0C" name="LED_HOTCUE_2_A" default="HOTCUE_2_A"/>
<led cc="0x0D" name="LED_HOTCUE_3_A" default="HOTCUE_3_A"/>
<led cc="0x0E" name="LED_HOTCUE_4_A" default="HOTCUE_4_A"/>
<led cc="0x0F" name="LED_HOTCUE_5_A" default="HOTCUE_5_A"/>
No sense in multiple people mapping LEDs.
Anyone got any ideas on what parameter to use to change the LED's colors between White<-->Red?
I spoke to Atomix today. The rep stated they have a "V.I.P. Beta MIDI map" availible only to V.I.P. DJs. he stated it had a few minimal bugs or features that need some minor detail, How ever this will be fixed on the final release version.
I am still interested in getting this thing working with VDJ I all ready own 2 Hercules RMXs and a NS7. If it works I will buy another one and two copies of VDJ Pro. I will even do cross counrty promotion for them at no cost and feature the setups in my next event on July 4th.
@ sirwesley
1. Did you make 2nd jogwheel spin?
2. Works sliders correctly now?
3. can you upload whole definition file somewhere?
Thank you Tjeck
Tjeck1972 wrote :
@ sirwesley
Thank you Tjeck
1. I've gotten the 2nd jogwheel to spin, but that's about it.
2. Still confused on the sliders.
3. I'll upload both the DEF and Map once I get them a little more functional.
Ok, so i will focus on sliders now.
we can define the Multicolor Leds like a <BAR>
with optional param MIN=0% and MAX 2%.
Sending cc note value 0 for black, 1 for red, or 2 for white
(need many condition inside at action VDJscript).
AUGH !
Not sure how to use this yet:
Platter 1 = Ch.01.Pitchbend+Ch01.CC.000
Platter 2 = Ch.01.CC.002+Ch.03.Pitchbend
Anyone have any idea how to code this up? Pulled this from another VDJ forum.
25%
