Forum: Hardware Technical Support - Topic: Denon DN-S3700 and problems with VDJ6
Questions or comments about the supported hardware by VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
For general troubleshooting and MIDI controller configuration, please see Config & Troubleshooting.
Hardware products
VirtualDJ Forum
Hardware Technical...
Denon DN-S3700...
Autor - Topic: Denon DN-S3700 and problems with VDJ6 -
masato_39
VIP Member
Posted Tue 02 Jun 09 @ 8:41 am
Hello everyone.
Please help.
A deck and B deck if I was playing at the same time, B deck hands to stop the platter.
Then B and stop music playback deck.
However, A deck, even if the same thing, non-stop music playback.
Please tell me the solution.
cstoll
Atomix Productions
Posted Tue 02 Jun 09 @ 8:58 am
masato_39 wrote :
Hello everyone.
Please help.
Are both your decks platter mode the same? What is the Platter Mode button color of each -> Green or Orange?
masato_39
VIP Member
Posted Tue 02 Jun 09 @ 9:16 am
Hello cstoll.
yes. mode the Same for both.
Of the problem,
I play at the plate on both decks.
When playing alone deck(A or B), no problem.
DJ_Manixx
Professional edition user
VDJ Radio DJ
Posted Tue 02 Jun 09 @ 3:26 pm
Same thing happenin to me. Kinds of drop the midi connection between vdj and 3700. Then the 3700 does not respond to any button events. you have to stop the vdj manually disconeect the 3700 and reconnect back and at times it does not recognise the 3700 anymore. At times when i try to close vdj, it just hangs and not even task manager will close it. I have to restart. Lots of bugs and instability with the 3700 and v6.
masato_39
VIP Member
Posted Thu 04 Jun 09 @ 9:39 am
Problem described by the video
http://www.youtube.com/watch?v=pWnZiZV8Dug&feature=channel_page
DN-S3700×2 settings
A)
MIDI CH 1
Unit No SET 1
B)
MIDI CH 2
Unit No SET 2
cstoll
Atomix Productions
Posted Thu 04 Jun 09 @ 9:43 am
Do not change the MIDI channels for your S3700s, leave them the factory defaults of Channel 0 -- VirtualDJ internally separates them for the respective decks.
masato_39
VIP Member
Posted Thu 04 Jun 09 @ 9:53 am
Yes, I'll try it.
Thank you so much for quick response.
masato_39
VIP Member
Posted Thu 04 Jun 09 @ 7:53 pm
MIDI tried the same CH1 BOTH. The problem is not resolved.
MIDI CH0 is not set. can set up the 1-6CH.
Please help me.
cstoll
Atomix Productions
Posted Thu 04 Jun 09 @ 7:59 pm
Ok, I see the problem ... The active deck selected is changing when you scratch a platter which then looses the platter for the opposite deck.
Let me see what I can do ...
cstoll
Atomix Productions
Posted Thu 04 Jun 09 @ 8:13 pm
Ok, just make them both MIDI Chan 1
And try this .. Change in the Mapper the actions for the following keys-
PLATTER1 -> action_deck 1 ? deck 1 denon_platter 1 : deck 2 denon_platter 1
PLATTER2 -> action_deck 1 ? deck 1 denon_platter 2 : deck 2 denon_platter 2
Does that resolve the problem ?
masato_39
VIP Member
Posted Fri 05 Jun 09 @ 1:09 pm
*** Sorry *** accidentally hit the wrong button ...
But I got the info ...
cstoll
DJ_Manixx
VDJ Radio DJ
Posted Fri 05 Jun 09 @ 2:37 pm
I just tried it and still same problem.
cstoll
Atomix Productions
Posted Fri 05 Jun 09 @ 2:53 pm
I think I miss typed .. try these please ...
PLATTER1 -> action_deck 1 ? deck 1 select & denon_platter 1 : deck 2 select & denon_platter 1
PLATTER2 -> action_deck 1 ? deck 1 select & denon_platter 2 : deck 2 select & denon_platter 2
masato_39
VIP Member
Posted Mon 08 Jun 09 @ 6:45 am
hello cstoll.
I tried it. but The problem is not resolved.
Please check the video.
http://www.youtube.com/watch?v=K8Fk__e0-Zg
cstoll
Atomix Productions
Posted Mon 08 Jun 09 @ 8:06 am
masato_39
VIP Member
Posted Mon 08 Jun 09 @ 8:16 am
ok! Thank you.
gangstacop
No license user
Posted Sun 15 Nov 09 @ 11:30 pm
my denon 3700 is not working very well on my pc wxp am using. deck 1 is working ok but deck 2 platter not working when deck 1 is active but if you stop deck 1 then deck 2 platter is active and can scratch, any help
