Hello everyone.
Please help.
A deck and B deck if I was playing at the same time, B deck hands to stop the platter.
Then B and stop music playback deck.
However, A deck, even if the same thing, non-stop music playback.
Please tell me the solution.
Please help.
geposted Tue 02 Jun 09 @ 8:41 am
masato_39 wrote :
Hello everyone.
Please help.
Please help.
Are both your decks platter mode the same? What is the Platter Mode button color of each -> Green or Orange?
geposted Tue 02 Jun 09 @ 8:58 am
Hello cstoll.
yes. mode the Same for both.
Of the problem,
I play at the plate on both decks.
When playing alone deck(A or B), no problem.
Of the problem,
geposted Tue 02 Jun 09 @ 9:16 am
Same thing happenin to me. Kinds of drop the midi connection between vdj and 3700. Then the 3700 does not respond to any button events. you have to stop the vdj manually disconeect the 3700 and reconnect back and at times it does not recognise the 3700 anymore. At times when i try to close vdj, it just hangs and not even task manager will close it. I have to restart. Lots of bugs and instability with the 3700 and v6.
geposted Tue 02 Jun 09 @ 3:26 pm
Problem described by the video
http://www.youtube.com/watch?v=pWnZiZV8Dug&feature=channel_page
DN-S3700×2 settings
A)
MIDI CH 1
Unit No SET 1
B)
MIDI CH 2
Unit No SET 2
DN-S3700×2 settings
A)
MIDI CH 1
Unit No SET 1
B)
MIDI CH 2
Unit No SET 2
geposted Thu 04 Jun 09 @ 9:39 am
Do not change the MIDI channels for your S3700s, leave them the factory defaults of Channel 0 -- VirtualDJ internally separates them for the respective decks.
geposted Thu 04 Jun 09 @ 9:43 am
Yes, I'll try it.
Thank you so much for quick response.
geposted Thu 04 Jun 09 @ 9:53 am
MIDI tried the same CH1 BOTH. The problem is not resolved.
MIDI CH0 is not set. can set up the 1-6CH.
Please help me.
Please help me.
geposted Thu 04 Jun 09 @ 7:53 pm
Ok, I see the problem ... The active deck selected is changing when you scratch a platter which then looses the platter for the opposite deck.
Let me see what I can do ...
geposted Thu 04 Jun 09 @ 7:59 pm
Ok, just make them both MIDI Chan 1
And try this .. Change in the Mapper the actions for the following keys-
PLATTER1 -> action_deck 1 ? deck 1 denon_platter 1 : deck 2 denon_platter 1
PLATTER2 -> action_deck 1 ? deck 1 denon_platter 2 : deck 2 denon_platter 2
Does that resolve the problem ?
geposted Thu 04 Jun 09 @ 8:13 pm
*** Sorry *** accidentally hit the wrong button ...
But I got the info ...
cstoll
cstoll
geposted Fri 05 Jun 09 @ 1:09 pm
I just tried it and still same problem.
geposted Fri 05 Jun 09 @ 2:37 pm
I think I miss typed .. try these please ...
PLATTER1 -> action_deck 1 ? deck 1 select & denon_platter 1 : deck 2 select & denon_platter 1
PLATTER2 -> action_deck 1 ? deck 1 select & denon_platter 2 : deck 2 select & denon_platter 2
geposted Fri 05 Jun 09 @ 2:53 pm
hello cstoll.
I tried it. but The problem is not resolved.
Please check the video.
http://www.youtube.com/watch?v=K8Fk__e0-Zg
geposted Mon 08 Jun 09 @ 6:45 am
Ok, let's continue this discussion here - https://virtualdj.com/forums/110440/Hardware_Technical_Support/Denon_Controllers_-_V6.html
geposted Mon 08 Jun 09 @ 8:06 am
ok! Thank you.
geposted Mon 08 Jun 09 @ 8:16 am
my denon 3700 is not working very well on my pc wxp am using. deck 1 is working ok but deck 2 platter not working when deck 1 is active but if you stop deck 1 then deck 2 platter is active and can scratch, any help
geposted Sun 15 Nov 09 @ 11:30 pm
hello my name is DJ INFINITI and I'm having an issue with the virtual DJ previously i use to play with the virtual DJ link to my DENON 3700. they use to play good with no problem. some how it start giving me a problem like the deks start switching without asking. like dek A switch to Dek B. i restart the sistem to see if i can get it back, but now the virtual does not want to boot the DENON 3700 i check the drivers and it it connected and complet as installed.
and for te record i m using the virtual 7
please help i don't know what to do on CD mode the denon works perfect and on usb mode but the midi mode is not responding.
geposted Fri 09 Aug 13 @ 5:37 pm
First of all, digging up a four year old thread will not make the forum moderators very happy.
Decks switching from A to B is caused by Atomix strange policy of assigning a deck swap command to the eject buttons.
Please register the serial number of your Virtual DJ 7 so that you can download the latest update of VDJ.
geposted Sat 10 Aug 13 @ 6:06 am
Follow this Setup Guide https://virtualdj.com/wiki/DN-S3700.html
geposted Sun 11 Aug 13 @ 5:24 am
