Topic: Version 6.0.1 - Page: 2
chise1 wrote :
When activated, 'getfood' will prompt you for a zip code or an address, and it will open your web browser and show you (courtesy of Google Maps) the nearest take-out places to get food.
Thought this was a joke at first, then, programmed the G key out of curiosity and was gobsmacked that it worked. Hilarious!!!! :-)
djsherz wrote :
Getfood in the scripting... genius! :-)
Just waiting for get_beer / get_laid / get_paid, and we're done here!
Yup, can't wait :-)
NICE... VDJ > Everyone Else
all i need in my life now is the boggis mapper for the hc4500
96 kHz, 24 support would be great when is that happening
I sent a PM to JPB last night, the mapper will have to be completely rewritten and tested which could take some time. I'm just sticking with 5.2 for just now.
yea... i seen that in another post, i just mapped it out myself to be somewhat similar until it comes out
That is more a function of your soundcard. Also you are playing mp3 or wav or lossless files on a mac they are mastered at a lot less bit rate so you would loose quality in the up sampling.
having said it as yet, as if i need to it speaks for it self... but an excellent piece of work steph and all of the team involved, big slap on the back to all of you, nice work.
Hi:
I have a problem. iTunes option on folders list just wont show even if it is marked as "on" on config options. Im running XP SP3 in spanish (Mexico), iTunes 8.2.0.23. PLEASE HEEELLLPP!
Thank you
Yesterday my first video gig with the 6.01.
It was a disaster.
The vids stutter every time I played one.
Also it gave problems with recognizing my DMC2.
I couldn't play along with this configuration.
Therefore I decided the uninstall it and re-installed the 5.1 version that I had before.
For me it wasn't a succes to work with the 6.01.
Maybe you don't have problems at all but you really need to test it very good before you use it.
That was my experience last night
djcrossfade wrote :
n.i scratch pro has this and it still sounds better than vdj
It doesn't matter if the software supports 24bit/96kHz audio, if your source material isn't encoded with such high bitrate and sampling frequency.
CDs - and therefor MP3's ripped from CDs - and pretty much every single MP3 bought from any online store is 16bit/44khz. The only higher frequency source material is available as DVD-A or SACD formats, which haven't exactly boomed yet on the mainstream.
Besides, this whole "Traktor sounds better" claim has been empirically proven as a myth in a previous thread. However, if somebody could get their hands on some 24bit/96kHz material to play via Traktor, then it would naturally sound better. I'm feeling lazy to confirm this myself, but I wonder does Traktor really support such sampling frequencies or is it just the specs of Audio8 sound card?
It was a disaster.
I would never install and do a gig with any software ,without giving it at least a week of testing on my own first. I carry 2 laptops with me to all gigs one will have a know stable version, the 2nd one I upgrade. I will play with the newest version every night, until I feel confident in it. The laptop with the older version stays the main playback advice, until I am satisfied.
I have found that it cuts off the last few seconds of a video.
I, and a few peeps are experiencing video blackness in video previews from time to time. Is this a common issue? What should I/we look into as the cause?
AMD 4600+
2Gig RAM
nvidia geForce 7600gt w/256m
XP Pro
6.0.1
i need some help with the icdx, the parameters button dosnt work for the crossfade, can anyone help please. vdj 6
fixed it!!!
I have listened to some DVD-A and to be honest with you, on popular (or anything you would play in a nightclub/bar/lounge/car/home/cell phone or i-pod) I challenge ANYONE, and I mean ANYONE who can tell the difference between 320kbs ac3 16/44 and a DVD-A 24/96. Yes MAYBE if you specialize in acoustic testing and you have trained ears and are listening to PERFECTLY recorded classical music and you are in a specially built soundroom then, yeah, you could tell the difference., but nobody else can.
I'm sorry, anyone that SAYS they can tell the difference in the bass, clap, sample, rap, overdub, sound effect, repeat sequence 40 times world of contemporary music has their proverbial lips on someone's proverbial ass to get some free SWAG. Hell 99.9 percent of the population of the entire "erf" thinks their blackberry is Hi-Fi!
i would make a good beta tester..........
multiple systems , multiple types of play (strip club and mobile)
more than 50 hours a week in front of a paying audience ..........
It would if the software passes audio data off to the audio layer 1on1 which it doesn't in most cases. Audio passes through EQ/Effects and then some plus generally some processing is done by the software. So yes, it would require the software to support it.
But then again, in real-life applications the advantage for DJ apps like this are very slim at best..
djcrossfade wrote :
What a great observation. Is that your opinion, or do you have research numbers to back that up?
its a observation.
again im not hating on vdj i happen to like the layout more than mixvibes and Traktor Scratch .
i was using Traktor Scratch Pro for good bit with my rme sound card .
side by side with vdj
and i can tell that Traktor Scratch had a much more rich cleaner sound playing the same song .
with mixvibes (which i have) has about the same as Traktor Scratch .
anyway im hoping vdj comes up and beats down mixvibes and Traktor Scratch on the sound front and the scratching front.
as for now. as far as scratching. mixvibes is the king it as more of a natal feel to vinyl .
being that was a turntablist (im going to get be in to it ) i can tell
We have already proven that there is absolutely no sound difference between traktor and VDJ. So, whatever you are hearing is likely imaginary. Have a look at the following thread: http://www.virtualdj.com/forums/107227/General_Discussion/Kind_of_embarrassed.html?search=rta&page=1 for actual proven testing not "I can tell..." B.S.
For everyone else here who has said they hear a difference, I call B.S. Go and read that thread as well. Cyder I wish you'd chime in here as well to let everyone know about those test we ran!
40%
