apres la demande de djcel ; voila ma config midi qui marche impec sous 5.2.1
<?xml version="1.0" encoding="windows-1252"?>
<midi version="5" author="Kaymyst" date="30/11/2008">
<note note="4" midichannel="16" action="hotcue" chan="1" value="1" />
<note note="6" midichannel="16" action="hotcue" chan="1" value="2" />
<note note="5" midichannel="16" action="hotcue" chan="2" value="1" />
<note note="7" midichannel="16" action="hotcue" chan="2" value="2" />
<ctrl ctrl="23" midichannel="16" mode="encoder" encodermode="0" action="loop" increments="1" />
<note note="3" midichannel="16" action="loop" />
<ctrl ctrl="22" midichannel="16" mode="encoder" encodermode="0" action="browser_updown" increments="1" />
<note note="2" midichannel="16" action="pause_stop" />
<note note="2" midichannel="16" action="browser_open" value="1" />
<note note="2" midichannel="16" action="sync" value="auto" />
<ctrl ctrl="21" midichannel="16" mode="encoder" encodermode="0" action="browser_switch" increments="1" />
<ctrl ctrl="20" midichannel="16" mode="encoder" encodermode="0" action="video_select_fx" increments="1" />
<note note="0" midichannel="16" action="video_fx" />
<ctrl ctrl="7" mode="slider" action="level" chan="active" scale="0" />
<note note="1" midichannel="16" action="select" chan="active" />
<ctrl ctrl="3" mode="slider" action="video_crossfade" scale="0" />
<note note="20" midichannel="16" action="pause" chan="1" />
<note note="20" midichannel="16" action="browser_open" chan="1" />
<note note="20" midichannel="16" action="sync" />
<note note="20" midichannel="16" action="hotcue" chan="1" value="1" />
<note note="22" midichannel="16" action="pause" chan="1" />
<note note="22" midichannel="16" action="browser_open" chan="1" />
<note note="22" midichannel="16" action="sync" />
<note note="22" midichannel="16" action="hotcue" chan="1" value="2" />
<note note="21" midichannel="16" action="pause" chan="2" />
<note note="21" midichannel="16" action="browser_open" chan="2" />
<note note="21" midichannel="16" action="sync" />
<note note="21" midichannel="16" action="hotcue" chan="2" value="1" />
<note note="23" midichannel="16" action="pause" chan="2" />
<note note="23" midichannel="16" action="browser_open" chan="2" />
<note note="23" midichannel="16" action="sync" />
<note note="23" midichannel="16" action="hotcue" chan="2" value="2" />
</midi>
</midi>
geposted Sat 06 Jun 09 @ 1:37 am
Je voulais dire les 2 nouveaux fichiers comme expliqué ici:
http://www.virtualdj.com/wiki/ControllerDefinition.html
1) un fichier xml "definition" (à créer uniquement si le contrôleur n'est pas encore listé dans VirtualDJ)
2) un fichier xml "mapper"
(le fichier posté ci-dessus n'est plus compatible avec VirtualDJ 6 car le moteur de gestion des contrôleurs MIDI a totalement changé)
Le fichier xml "definition" de la Nuo4 n'a pas encore été défini donc tu dois d'abord passer par cette étape.
geposted Sat 06 Jun 09 @ 4:54 am
houla !!! je fais ça comment moi?? tu commences à parler chinois pour moi là...
le tuto est en anglais en plus..
geposted Sun 07 Jun 09 @ 10:07 pm
alors c'est ça le progrès?...pour utiliser la nouvelle version faut se taper des lignes de commandes comme à l'époque MS-DOS?
Je ne sais pas pour vous mais le taff de Dj est suffisamment compliqué comme ça
geposted Tue 16 Jun 09 @ 5:43 pm
absolument d'accord
pour l'instant je reste avec la version 5.2.1 il y a plien de chose que je ne peux plus faire avec la 6.01
wait n see = manuel vdj sript en français
explication plus détaillée des commandes
possibilité de sauvegarder et de charger des raccourcis clavier (comme avant)
geposted Sat 20 Jun 09 @ 2:18 am
