Topic: virtual dj timecode vinyl purchase
anybody knows where to get the VDJ timecode vinyl's. there is no link on the page. also, will virtual vinyl timecodes work with vitual dj.?
geposted Tue 16 Jun 09 @ 4:13 pm
hey, you're right I can't seem to track it down either - I would recommend you purchased serato vinyl. i bought vdj tcv and they were warped out of the packaging. the serato vinyl also feel more sturdy. Then stick Norway's (?) vinyl stikers over them
but, will the serato timecode vinyl work with vdj??
yes
where can i buy serato TCV in the uk?? ive googled it and can only seem to find them in the states.
i bought vv tcv from the states, off the website, then paid postage from the states to the uk only to recieve them and find they were sent from down south somewhere in the uk....bit annoying, but bought serato ones of ebay and it worked out about a tenner cheaper, and they work well
Try WestendDJ, they're almost complete there but a bit pricey. It's where i bought all my TCV spares like Serato TCV (red and blue ver0.2), my audio8 and Trak TCV (white and red). They don't have Numark TCV at that time but if they have now do carefully check the quality for the ones i have are warped and poor quality made. I said it so because if you put it side to side and scrutinize it one by one NumarkTCV is just out of quality by far. BTW you cannot use Trak TCV's with VDJ, just for info.
You can get Numark Virtual Vinyl control plates from decks.co.uk. Just been looking at them myself! For a pair it'll come to just under £30.
Failing that take a look on ebay, there's plenty on there in the UK and abroad.
Hard to find records stock all timecode vinyls.
www.htfr.com
They are in uk and deliver next day
