Wish I have MAC but hopefully soon. In PC yes you'll experience that CPU spikes with the new coloured track position and some jerking too but can be easily rectified so to run smooth like a silk by updating the graphics driver. Just maybe applicable in MAC to.
geposted Thu 11 Oct 12 @ 8:33 am
Bro, i have bought a macbook pro 13.3 mid-2012 model with the very high specs last month and it was just 2-weeks from me and i returned it:
2.9GHZ Intel i7 with crisp display
16GB memory
VRAM 512 - I'm frustrated when upgrading the RAM to 16GB the VRAM does not change (that is stupid part that apple lock the VRAM)
1TB Hard Drive
Intel HD4000 Graphic Card
Believe me... it crawls like a turtles very slow. Before you decide you google it firs and you will see and read in many forums that apple have harvested units from users RETURNING THE UNIT every now and then like mine i have returned it because the apple local dealer can't do anything on that. I prepare to use my old one 13.3 2.4GHZ with 4GB RAM & 256 VRAM which runs really fast than the new macbook pro 13.3 mid 2012 2.9GHZ i7.
16GB memory
1TB Hard Drive
geposted Fri 12 Oct 12 @ 12:40 am
Salamat sa heads-up bro Cesar. Buti nalang ala akong perang pambili, hehehe
geposted Fri 12 Oct 12 @ 1:55 am
Ang problema bro is hindi sapat yong ine-expect mong quality from what have paid for. Kung baga too expensive for that piece of crap. Yes the physical appearance is good, solid nice and beautiful but when you ask about the performance it is vey poor. Pinalitan ko ng Fujitsu with the same specs and it runs so fast that over thrown my old macbook.
geposted Fri 12 Oct 12 @ 2:14 am
Kumusta mga bro....
geposted Fri 12 Oct 12 @ 3:02 pm
djkooyeah wrote :
Tanong lang, tungkol sa Mixdeck pag nag sync ako (press B sa laptop) nag papalit yung tempo ng DECK2 habang nag plaplay paano ko maayus un?
Hi Bro,
Hope you already had a chance to play with the mapping I sent you on e-mail.
Yung mga functions na hindi mo kailangan, just feel free to change them (as you know that I am a 4deck user with video).
Kung may maitutulong ako sa mapping-action na gusto mo, I will try to help too.
Cheers!
geposted Tue 16 Oct 12 @ 1:30 pm
Mga sir may vestax typhoon n ako kso ng crash ung vdj pro n galing torrent ahehehe pati traktor hnd gumagana... eh nka amd ako hnd binabsa ng computer ung ksamng software kya ng ddl ako ngaun ng vdj le7 dito sa site sna gumana ahehehe dami k n dl na songs haayyy wish me luck mga sir! excited n ako mg spin!
geposted Sat 20 Oct 12 @ 11:08 am
HA! GUMANA SRAP MG MIX WOW!! GNITO PLA FEELING NITO!! ay sorry all caps.... paano po mg dl ng mga effects na pwd s LE?
geposted Sat 20 Oct 12 @ 12:16 pm
tanong ko sagot ko, hnd p[la pwd syang dap[at pro user sayang nman
geposted Sat 20 Oct 12 @ 1:42 pm
Jokriss
yun ang problema sa cracked version,anytime pwede kang bitinin.
yup,that why they called it LE Limited Edition so Limited access din he!he!he! Mag upgrade knlng ng PRO para unlimited access ka.
how much na ang Typhoon?
geposted Sun 21 Oct 12 @ 4:47 am
14k sir.. ano b mgndang effects s le png transition? mhal ung pro dba? $199 8k din un ahehehe
geposted Sun 21 Oct 12 @ 5:24 am
mga sir pwd po b pgawa nman ng dj drop dj jokriss po thank you po
geposted Sun 21 Oct 12 @ 5:29 am
mag Pro Basic knlng..
geposted Sun 21 Oct 12 @ 1:30 pm
may gnun ba? mg kano un?
geposted Sun 21 Oct 12 @ 9:09 pm
@ jokriss
Check HERE for comparison.
I'm afraid Pro Basic does NOT support MIDI/HID.
geposted Mon 22 Oct 12 @ 1:50 am
@ jokriss
geposted Mon 22 Oct 12 @ 1:51 am
If I were you, I will just save and wait until you can afford to get the Pro-Version.
If you will get more serious in spinning, I guarantee you na mag-a-upgrade ka ng controller in the future.
Having the Pro-Version, you won't need to pay for any upgrade. So pretty much, kahit ano pa ang magginging bagong controller mo, either it will be natively supported... or it will be mappable.
Opinion ko lang to... Ikaw pa rin ang magde-decide down the line.
Cheers!
Cheers!
geposted Mon 22 Oct 12 @ 10:11 pm
guys, i'm planning to migrate from audio to full video jock this 2013. What do you think about this laptop? Will it suffice on video mixing?
http://www.onyougo.com/hp-pavilion-g4-2126tx-notebook-pc-notebooks-specs_pi1783645e2
Thanks for your inputs in advance guys.
Gab
Gab
geposted Tue 23 Oct 12 @ 9:40 am
Gab
Gab
Mac!!! And I never looked back!
I started with Imac 21" (discovered too big for gigs - but I enjoyed the big screen)
Then got a MacbookPro 13" (too small)
Finally I got 2 MacbookPro 15" (the perfect ones for me)
*I was surprised with CesarCastillo's experience with the new 2012 Macs. Mine are from late 2008 to late 2011.
geposted Tue 23 Oct 12 @ 1:50 pm
mga sir may keyboard mappiungs b ang vdj le? png sampler lng? mron b nun? kc wlangf gumagana s keyboard k pra mg trigger nang samplers eh
geposted Tue 23 Oct 12 @ 4:15 pm
