Does any1 know if you can assign more than 1 function to a button or some sort of macro on an xp10?
If so, how?
I hate using the SHIFT button to do an extra action. I know its possible using keyboard shortcuts...
If so, how?
geposted Mon 04 Apr 05 @ 2:40 am
Indeed you can do macro with keyboard but not with buttons on the skin.
Only create actions with the same key in the order of execution (from up to down)
geposted Mon 04 Apr 05 @ 3:46 am
... but why not in a future release ?
The idea is not bad at all.
geposted Mon 04 Apr 05 @ 10:33 am
you should write your idea in the topic "new features"
geposted Mon 04 Apr 05 @ 12:40 pm
You can do this with the keyboard. I haven't been able to figure out how to do it with an XP10 button though. Don't think it can be done. I wanted to program buttons to do stuff like go to cue #2 and loop 16. Doable with the keyboard but XP10 would be nice too.
geposted Mon 04 Apr 05 @ 6:08 pm
@anewsome,
i have uploaded a new plugin with your wish and you can control the button of the plugin with the XP10 by using the action effect_button()
geposted Mon 04 Apr 05 @ 6:55 pm
Good stuff djcel...
i'll check it out
i'll check it out
geposted Tue 05 Apr 05 @ 4:31 am
Thanks djcel. I'm gonna check it out too.
geposted Tue 05 Apr 05 @ 5:41 pm
