After some issues with "beatlock" and some research (THANK YOU: discjockeydoc) i want to ask you skinners out there:
Is there an easy way to get an element in the skin that shows the beatlock state (like the SYNC button in VDJ 5.2.1)?
Or better if Beatlock is activated a big red TEXT showing me that beatlock is activated. Is this possible?
You must know that ill never use beatlock but sometimes i have inadvertently activated it. This brings some issues to an playing song: if you drag an "slower" song to the other deck, the pitch from the running deck syncs to the new song and will be locked up there. if you doesnt see that beatlock is activated you going cracy ;-)
Thanks for your help
cu
pOpY
cu
pOpY
geposted Thu 16 Jul 09 @ 5:20 am
http://www.virtualdj.com/addons/8379/CUE_RMX_by_cioce_%281280x768%29.html
Try it, the STAR Beatlock button is so big and easy to see ;)
geposted Thu 16 Jul 09 @ 6:49 am
Hello. Thanks for the Link, but i want to use the "normal" skin and just see the beatlock status.
cu
pOpY
cu
pOpY
geposted Sun 19 Jul 09 @ 10:25 am
The beatlock status is visible in the Scratch pannel.
geposted Sun 19 Jul 09 @ 7:24 pm
I am dont using the scratch panel, so i doesnt switch to it. I just want to see if i inadvertently have activated beatlock.
cu
pOpY
cu
pOpY
geposted Mon 20 Jul 09 @ 2:40 am
Someone one day will explain me the sense to have beatlock in scratch pannel...
geposted Mon 20 Jul 09 @ 4:46 am
Thats a good question ;-) (i dont know the answer)
I have modified the Original VDJ6 Skins and added an Beatlock Button! I have taken the beatlock Button out from the skin "CUE_RMX_by_cioce", so i hope thats no problem at all?
So how can i upload the skin to VDJs Skin section?
cu
pOpY
cu
pOpY
geposted Tue 21 Jul 09 @ 4:18 pm
Thank you for the link.
I have uploaded it.
Will the skin be reviewed before it goes online? I cant see it?
cu
pOpY
I have uploaded it.
cu
pOpY
geposted Wed 22 Jul 09 @ 5:30 am
Skin is Online: http://www.virtualdj.com/addons/8687/VDJ6_with_Beatlock.html
Have fun
cu
pOpY
Have fun
cu
pOpY
geposted Wed 22 Jul 09 @ 9:57 am
