OK, so I just started to jump into some video mixing on my Macbook Pro (Settings below.) I purchased the mac for the hopes of better stability overall, which I have gotten, and eventual hopes of moving to some video clips. Video never worked well on my PC. At any rate, so far I haven't had much success in getting VDJ to stabilize when running video. I believe I am running VDJ Pro 5.2.1, on the machine below:
Macbook Pro 15.4"
2.4 ghz processor
2GB Ram
Any settings that I need to change in either VDJ or within the Mac OS itself? After Cue crashes from the video playing, it throws a Mac OSx error. Just wondering if anyone can point me in the right direction here. I have been running mostly AVI files to date...
Macbook Pro 15.4"
2.4 ghz processor
2GB Ram
geposted Mon 20 Jul 09 @ 8:32 pm
Here's the Crash report tossed by the Mac:
_________________
Process: cue [126]
Path: /Applications/cue.app/Contents/MacOS/cue
Identifier: com.atomixproductions.cue
Version: ??? (5.2.1)
Code Type: X86 (Native)
Parent Process: launchd [66]
Date/Time: 2009-07-21 21:55:49.137 -0400
OS Version: Mac OS X 10.5.6 (9G2133)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000186b3000
Crashed Thread: 15
Thread 15 Crashed:
0 libSystem.B.dylib 0xffff08a0 __memcpy + 256 (cpu_capabilities.h:246)
1 libGLImage.dylib 0x909d4729 glgCopyRowsWithMemCopy(GLGOperation const*, unsigned long, GLDPixelMode const*) + 121
2 libGLImage.dylib 0x909d2b96 glgProcessPixelsWithProcessor + 342
3 com.apple.GeForce8xxxGLDriver 0x1a2abe6d gldAllocVertexBuffer + 24461
4 com.apple.GeForce8xxxGLDriver 0x1a28d651 gldDestroyQuery + 2673
5 com.apple.GeForce8xxxGLDriver 0x1a2af1d8 gldGetTextureLevel + 10216
6 com.apple.GeForce8xxxGLDriver 0x1a2a0c87 gldUpdateDispatch + 487
7 GLEngine 0x18a5f268 glBegin_Exec + 296
8 libGL.dylib 0x90e0b3ab glBegin + 27
9 com.apple.carbonbundletemplate 0x1526b2e6 0x1526a000 + 4838
10 com.apple.carbonbundletemplate 0x1526c5c2 DllGetClassObject + 4458
11 com.atomixproductions.cue 0x00078a8f non-virtual thunk to COutputMacVV::Thread() + 45145
12 com.atomixproductions.cue 0x000b1c8c readatomhdr(void*, TQTAtom*) + 49806
13 com.atomixproductions.cue 0x000b223c readatomhdr(void*, TQTAtom*) + 51262
14 com.atomixproductions.cue 0x000a5e73 readatomhdr(void*, TQTAtom*) + 1141
15 com.atomixproductions.cue 0x000a5edb readatomhdr(void*, TQTAtom*) + 1245
16 ...ple.CoreServices.CarbonCore 0x913450a3 PrivateMPEntryPoint + 56
17 libSystem.B.dylib 0x964af095 _pthread_start + 321
18 libSystem.B.dylib 0x964aef52 thread_start + 34
Thread 15 crashed with X86 Thread State (32-bit):
eax: 0xffff088b ebx: 0x909d2a61 ecx: 0x00000000 edx: 0xfffffb00
edi: 0x1862db00 esi: 0x186b3500 ebp: 0xb0b10548 esp: 0xb0b10540
ss: 0x0000001f efl: 0x00010212 eip: 0xffff08a0 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0x186b3000
Binary Images:
0x14dee000 - 0x14defffb com.apple.carbonbundletemplate 1.0 (1.0)
/Users/mikedonofrio/Documents/Numark CUE/Plugins/VideoEffect/Boom_Auto.bundle/Contents/MacOS/Boom_Auto
0x14fe3000 - 0x14fe4fff com.apple.carbonbundletemplate 1.0 (1.0)
/Users/mikedonofrio/Documents/Numark CUE/Plugins/VideoTransition/Strobo.bundle/Contents/MacOS/Strobo
0x14ff0000 - 0x14ff1fff com.apple.carbonbundletemplate 1.0 (1.0)
/Users/mikedonofrio/Documents/Numark CUE/Plugins/SoundEffect/BackSpin.bundle/Contents/MacOS/BackSpin
0x1526a000 - 0x1526cffb com.apple.carbonbundletemplate 1.0 (1.0) <56af5be9ebe6423791817eaa95b456eb>
/Users/mikedonofrio/Documents/Numark CUE/Plugins/VideoEffect/SlideShow.bundle/Contents/MacOS/SlideShow
0x1a283000 - 0x1a5ebff8 com.apple.GeForce8xxxGLDriver 1.5.40 (5.4.0) <3deb8ad3a824c172268e287e862f2f68>
/System/Library/Extensions/GeForce8xxxGLDriver.bundle/Contents/MacOS/GeForce8xxxGLDriver
_________________
Process: cue [126]
Report Version: 6
Crashed Thread: 15
Thread 15 Crashed:
cr2: 0x186b3000
Binary Images:
geposted Tue 21 Jul 09 @ 8:58 pm
Apparently it crashed in a video plugin during a OpenGL process. I will have a look more tomorrow.
[EDIT] fyi, the video plugin is "SlideShow.bundle"
geposted Wed 22 Jul 09 @ 6:46 pm
Slideshow.bundle, is that something that I should take a look at or change?
Ideally, I want to give things a shot this Saturday night in the bar, so any feedback you can provide would be GREATLY appreciated.
geposted Wed 22 Jul 09 @ 10:24 pm
About your crash, your video card didn't support the need of the video process. Maybe try to expand the amount of memory allocated to video memory or load smaller picture in the SlideShow plugin.
Maybe "Mac OS X 10.5.7 Combo" could fix the issue as they improved the nVidia support
http://support.apple.com/downloads/Mac_OS_X_10_5_7_Combo_Update
(don't use the Software update from the Apple menu, but download it manually)
geposted Thu 23 Jul 09 @ 2:30 pm
So, is the issue with the video functionality, or the Slideshow plugin? You mentioned using a smaller picture, but doesn't that speak to the slideshow plugin, rather than video in general. I just want to make sure I know how to approach this.
Also, I have Mac specifications as defined by the site here, so I guess I don't know how my machine doesn't have what it needs in order to run video.
geposted Thu 23 Jul 09 @ 3:15 pm
I've had a similar problem with slide show but no problems whatever using clipbank or using regular music video. I use clipbank and just looop the video for when I am playing mp3. I also highly recommend DJ Cel's new Pandoras Box plugin. I just have a jpeg logo running with Pandora effect. It looks great and my boss loved it.
geposted Mon 27 Jul 09 @ 12:23 pm
I downloaded the Pandora plugin, but I can't see any place to point the plugin to a jpg file for audio only files...
anyone with any ideas?
geposted Thu 06 Aug 09 @ 9:51 pm
Where do you download your visualization files for mac?
geposted Sat 29 Aug 09 @ 12:03 am
virtual dj for mac Sound Effect free download
geposted Wed 09 Jan 13 @ 12:23 am
Please do not hijack topics by posting a message that is not related in any way. Your question has nothing to do with crashing video on a Mac. Please open your own new topic by clicking the pen and paper icon at the top of the topics list.
Also, please do not unnecessarily resurrect old topics. This topic is over 3 years old and the issues discussed may no-longer be relevant (E.g: Bug in old version of the software that has long since been resolved.)
Add-ons such as effects, samples, skins, etc. are only available to registered licensed users who have purchased the software.
Do not ask users to send you add-ons to which you are not currently entitled or your account will be locked.
Please support the software and its future development by purchasing it: http://www.virtualdj.com/products/comparison.html (Especially if you are working DJ and are making money as a result of using it at your gigs.)
[Old topic closed]
[Old topic closed]
geposted Wed 09 Jan 13 @ 11:31 am
