After clicking the button "SAVE CAPTURE" in the DEBUG window of Timecode section, this is the picture I get:
insted this is the original view:
As you can see, in the first picture, the black areas are displaced compared to the original view.
Check this out and fix that.
geposted Fri 24 Jul 09 @ 2:14 am
Windows XP ?
geposted Sat 25 Jul 09 @ 12:20 pm
Yes, Windows XP SP3
geposted Sat 25 Jul 09 @ 12:48 pm
Ok so it's a known bug.
geposted Sat 25 Jul 09 @ 6:18 pm
I am reading you are working on a new release.
Please, don't forget to fix this bug.
geposted Fri 21 Aug 09 @ 1:22 pm
Not yet fixed in 6.0.2.
geposted Sat 29 Aug 09 @ 2:38 pm
It doesn't stop the performance of the software and their for was not focused on ... but thank you for your astute observation.
geposted Sat 29 Aug 09 @ 3:18 pm
Cstoll, you make me smile ;)
As in the past I suggested to change the window of crash (as I wrote at that time it looked like not so professional) and you did, now I "suggest" to fix that as well.
I think that if there is a feature, it must to work at 100% else, if it works at 50%, it's better to remove that.
geposted Sat 29 Aug 09 @ 3:41 pm
Well even though it is not 'visually' appealing the feature still does what it is suppose to and gives the user a way to show us their settings. So it does work 100% ... it just is not visually appealing.
geposted Sat 29 Aug 09 @ 3:58 pm
You are right about "visually" appealing cstoll.
I am not saying that this "little" but must be fiexd tomorrow..I am just saing this bug should be fixed one day hence Dev Team shouldn't negleting that for the next releases ;)
geposted Sun 30 Aug 09 @ 5:27 am
