I would like to see an automatic start / stop of the play decks from the Fader slider. If the slider is at a user defined position on the left side then start the deck and vice versa.
geposted Tue 18 Aug 09 @ 4:09 pm
Version 6 ... it's called Fader_Start ...
Assign this action to a keyboard shortcut to activate and deactivate the feature.
Also, fader_start is deck-dependent - Use "deck 1 fader_start & deck 2 fader_start" in your keyboard activation
geposted Tue 18 Aug 09 @ 5:44 pm
will be deck-dependent soon ;-)
geposted Sun 23 Aug 09 @ 6:31 am
The only issue with the fader start implementation as it is is that it enables crossfader start and channel fader start with the single "fader_start" action.
Please separate this into 2 separate actions. I want to enable crossfader start but not channel fader start.
Thank You
Thank You
geposted Fri 22 Mar 13 @ 12:32 pm
