here some tweaks that we should all do
this is for vista and windows 7 only .
lets cool down that video card first with RivaTuner v2.24c to set the gpu's fan to %100
i use this in my gig laptop so it is safe its for both ati and nvidia
http://downloads.guru3d.com/download.php?det=163
now that you have installed it
go to the
now under the name of your gpu go to customize
hit the video card button set your fan to %100
go to the
geposted Sun 30 Aug 09 @ 2:44 pm
this next tweak is only for laptop and pc\\\\\\\\\\\\\\\'s that have more than one core cpu's
(first before any thing download cpuz http://www.cpuid.com/cpuz.php)
all this is is cpu info that you need to know for my tweaks
this is my decktop info .take the cpuz exe file out to your decktop
now lets start dj cross+fades pc tweaks for us vista ,windows 7
1. go to start button
find msconfig in the search and click on it .
it looks like this
click on boot
now click on advanced options
now check the box that says number of processors .
i have a dual core so im typing in 2 if you have 3 cores then type 3 if you have 4 then type 4
after that reboot .
this truly enables more core on windows for some reason windows only has one core enabled .
it looks like this
click on boot
after that reboot .
geposted Sun 30 Aug 09 @ 3:09 pm
That last bit you are changing says number of processors, not number of cores. Even if you have 2,3 or 4 cores you still only have one processor!
Gary
Gary
geposted Sun 30 Aug 09 @ 3:33 pm
Gary
Gary
windows thinks that when u have a dual core cpu that it is 2 processor. same thing when u have more core's
windows thinks that you have more processor's than one
sry i forgot to say that
i have done this in my gig laptop and it runs abit smother
geposted Sun 30 Aug 09 @ 3:42 pm
to add to that i have tested this for 1 year and have no problems
geposted Sun 30 Aug 09 @ 3:46 pm
tweak 2:
you need cpuz for this to know your level 2 cache the L2 cache now i have 6144 k on my home pc and on my laptop i have around 3000
(by default windows does not use all your cpu caches this is something that ever program uses .
before the tweak i have to add that i have tested this tweak for 6 months works great it will speed your pc up abit .
(make sure to have cpuz open
step 1:go to the start button
step 2: type in regedit.exe in the search
step 3 : click on regedit.exe
go to Hkey_local_machine\\SYSTEM\\CurrentControlSet \\Control\\Session Manager\\Memory Management\\
once there do not do the first tweaks shown in this pick
it slows your pc down i have tryed it moving on to the SecondLevelDataCache click on it .
hit the modify button .
check the decimal box now type in your cache
mine
mine
geposted Sun 30 Aug 09 @ 4:17 pm
I understand what you are saying, but even if windows thinks there is more than one processor, there isn't so its impossible for it to make any difference, and thats why it won't have given you any trouble over the last year because its not doing anything. I checked this out a while back and it really won't make any difference.
Gary
Gary
geposted Sun 30 Aug 09 @ 4:18 pm
your will say something else if you dont have a e8400 intell core 2 duo
GaryBr wrote :
I understand what you are saying, but even if windows thinks there is more than one processor, there isn\'t so its impossible for it to make any difference, and thats why it won\'t have given you any trouble over the last year because its not doing anything. I checked this out a while back and it really won\'t make any difference.
Gary
Gary
i know there isn't but windows is dumb so if u have a dual core windows thinks u have 2 cpu's
what your doing here is tricking windows in to using all cores
to add to that if you have not tried it then you wont know
:) im just trying to help out my djs here
some mixvibes djs have done this and they said it helped
i do custom pc's i have to clean mind out today i will post a pic
geposted Sun 30 Aug 09 @ 4:37 pm
Gary
Gary
in no way am i trying to be rude im going to clean this up even more but seeing on how its just my own pc i dont care as much
this is all water cooled it gets way to hot in my room so much so that my older pc would shut down from heat .
back to the tips
i will put more
geposted Sun 30 Aug 09 @ 5:15 pm
tweak 3
this one is a must and most djs dont do it
make vista and windows 7 look like xp
so it uses less ram
go to start button Control Panel switch to classic view
now go to System it looks like this
go to advanced system settings
under performance
click on settings
and check the box i checked
now you will see that vista and windows 7 uses less ram and leave more ram for video mixxing
so it uses less ram
under performance
click on settings
geposted Sun 30 Aug 09 @ 5:29 pm
TWEAK 4: go to start in the search type services click on it
disable the flowing ram hogs
security center disable
windows defender disable
windows firewall disable
themes disable
windows updates disable (i enable it once a week to check for updates)
to add to this if your doing gigs with your laptop you dont need this on then
themes disable
geposted Sun 30 Aug 09 @ 5:50 pm
sorry?
sorry?
geposted Sun 30 Aug 09 @ 7:41 pm
sorry?
sorry?
ya i mean security center
windows defender
windows firewall
themes
they take up alot of ram
and should not be on with you gigging pc
geposted Sun 30 Aug 09 @ 8:04 pm
to much tweeking of any system can be bad no matter what your running, first off if your new to vista uninstall norton, if you go onto the internet replace with something that is less of a hog. + disable your uac.
disable all those crappy screen pop ups', you know the ones i mean, system asking you to do this and that.
before a gig along the task bar there are one or two things you should exit from, you'll see them and no explanation is needed, but other than that you should be good to go.
windows 7, why do anything with it, it's the gem between xp and vista and i haven't needed to do anything with it on my desk top, haven't replaced vista on the lappy because it runs well as it is, video's, audio and karaoke [when needed].
do nothing else until you have a problem, then delete or disable one by one otherwise you can make more problems than you are curing.
never listen to well intentioned good advice... except mine, lol.
geposted Sun 30 Aug 09 @ 8:20 pm
lol
geposted Sun 30 Aug 09 @ 8:43 pm
T Hee
geposted Sun 30 Aug 09 @ 8:46 pm
Im gonna be honest here, with a clean install of Vista not much is needed to be tweaked. I ran into a mess of issues when I started "Tweaking". BE CAUTIOUS!!!!!!!! If u have no issues, LEAVE IT ALONE!!!
geposted Sun 30 Aug 09 @ 8:57 pm
ya i know this is all im doing seams like much but its not
its all you need to do .
i tried every tweak hear one at a time .
then ran a nice bench mark
even made my frame rates go up alil
witch is good seeing how i play games on both my laptop and pc
hawks :) you got to love it
as for RivaTuner its not a tweak its a program that lets you turn your gpu fan up that's all
geposted Sun 30 Aug 09 @ 9:23 pm
i have done a wedding with the tweaks you see hear with vdj
i played for 9 hours with no problems .
geposted Sun 30 Aug 09 @ 9:27 pm
