I am writing you to indicate that, maybe, the timecode track should be longer than 12 minutes.
I had this idea because if you are using a song longer than 12 minutes and you are using timecode in "Absolute mode", you can't scratch that song when it is playing, for example, to the 15th minute or more.
How about making a timecode track 70 minutes long in order to fill a whole CD ?
geposted Fri 25 Sep 09 @ 5:32 am
i dont use time code cds but maybe this will work.
instead of making just one time code file. make as many of them to fill the cd and remove the 2 second gaps. that way its one long huge file. maybe that will work?
geposted Sat 26 Sep 09 @ 4:42 pm
I think your idea doesn't work..
why:
the timecode track is a special song which allows the software to recognize in every moment the relative position in this track so you can't paste the same song different times; in this way the software can't understand if you are playing the 5th minute, the (5+12)th minute, the (5+24)th minute, etc
I mean the song must be different in each instant in order not to get repetition in this track.
why:
geposted Sun 27 Sep 09 @ 4:27 am
vdj suports seratos TCV dont they have 70 minutes of time code or are you talking about TCD
geposted Mon 28 Sep 09 @ 4:20 pm
The Timecode CD of Serato is 15 minutes long.
geposted Mon 28 Sep 09 @ 4:37 pm
oh...well the longest song iv heard was 11 minutes by dubfire
so i dont see nothing that has to go over 15..
geposted Mon 28 Sep 09 @ 4:51 pm
I have a few song longer than 12 minutes:
They are not so much but there are.
geposted Sat 03 Oct 09 @ 11:24 am
u are probably SPINING MINIMAL ?? MUSIC
geposted Sun 04 Oct 09 @ 5:21 am
DUDE give it a rest!!!
geposted Mon 05 Oct 09 @ 5:52 am
