Forum: Old versions
Topic: Virtual Dj 5.2.1
i would like to download the 5.2.1 version but its not in my downloads is there a way of getting it because i amd having problems with virtual dj 6.0.2 drifting
geposted Sat 26 Sep 09 @ 4:17 am
If you put your pitch sensitivity at like 2000ms it should fix this, it does with me. :) (Although i also reverted back to v5)
try what Van said, if that doesn't work and you REALLY want to go to 5.2.1 try contacting support by way of ticket and see if they can help.
Michael
thanks guys for your help
Do you lot meen that the ptich is drifting when using timecodes?
yes the pitch is drifting with timecodes
