i would like to download the 5.2.1 version but its not in my downloads is there a way of getting it because i amd having problems with virtual dj 6.0.2 drifting
geposted Sat 26 Sep 09 @ 4:17 am
If you put your pitch sensitivity at like 2000ms it should fix this, it does with me. :) (Although i also reverted back to v5)
geposted Sat 26 Sep 09 @ 4:38 am
try what Van said, if that doesn't work and you REALLY want to go to 5.2.1 try contacting support by way of ticket and see if they can help.
Michael
Michael
geposted Sat 26 Sep 09 @ 4:43 am
thanks guys for your help
geposted Sat 26 Sep 09 @ 4:46 am
Do you lot meen that the ptich is drifting when using timecodes?
geposted Sat 26 Sep 09 @ 5:06 am
yes the pitch is drifting with timecodes
geposted Sat 26 Sep 09 @ 11:34 am
If you are still wanting to get an older version of VDJ ask here https://virtualdj.com/contact/
geposted Sat 26 Sep 09 @ 11:54 am
