Topic: Timecoded Vinyl - skipping when fading?
PaulyVPRO InfinityMember since 2005
Hi there,
One more question...
When using TCV I am experiencing skipping when i am using the crossfader on my mixer...I find this odd as surely both streams are coming out regardless of how i use the crossfader on my mixer. I know it is the PC and not the mixer causing this as the HD light flickers in perfect time with the skipping....any ideas?
best wishes
geposted Thu 28 Apr 05 @ 12:53 pm
djejPRO InfinityMember since 2004
I've read your post and was hoping someone would answer you...I've never had this problem using TCV. You're right, there should be any problem with streams since the mixer isn't really even interacting with VDJ. RAM and/or background apps seem to be some of the more common causes of skipping. There is a post on skipping solutions you should read through.
geposted Fri 29 Apr 05 @ 2:59 pm
djcelPRO InfinityModeratorMember since 2004
Maybe TCV is not well configured so when you crossfade, the signal is not enough to be read by VDJ ...
geposted Fri 29 Apr 05 @ 8:34 pm
Is your TCV signal over 80%?
geposted Sat 30 Apr 05 @ 1:42 am
