sorry but i don't know if its possible .... if i buy the pro version, can i use VDJPRO stand alone or with another midi like the vci-100 although i got the SW from rmx via 50% of discount?...
more clear... can i use the pro version without rmx. I ask this, since you cant use the limited edition stand alonne (without the rmx).
thanks
thanks
geposted Thu 22 Oct 09 @ 9:01 pm
If you purchase a full version you are not limited to any one controller, or any controller. You can do anything with the software you want. The only limitation is your imagination....... ;-)
geposted Thu 22 Oct 09 @ 9:33 pm
so i can use the sw even without a controller right? (stand alone)..
geposted Fri 23 Oct 09 @ 12:06 am
Thats correct you can use it without any controllers.
geposted Fri 23 Oct 09 @ 3:34 am
