Hi
i'm using both windows and mac versions. and i have a few things (some of u know and some not)
on mac:
terrible with video.
cpu always high!
can see hebrew (i guess something isn't right with the Unicode because this is no problem in the windows vers.)
on windows:
playinst are not in unicode so i cant save a playlist which has songs written in Hebrew.
cant use key lock (sound is crackling) (this doesn't happen on mac)
jog latency is bad!
windows run on macbook unibody via bootcamp.
which you guys would fix some of my problems in the next release.
thanks.
Omry Aviry.
on mac:
cpu always high!
on windows:
jog latency is bad!
thanks.
Omry Aviry.
geposted Thu 29 Oct 09 @ 5:24 am
Keylock causing crackling will be down to your settings on your PC; I would suggest opening a thread in PC Technical Help about it.
geposted Thu 29 Oct 09 @ 5:31 am
talked about this many times.
on my mac there is no problem even on the highest settings, problems are on windows via bootcamp in every settings i tried. i'm not the only one that have this issue.
geposted Thu 29 Oct 09 @ 8:23 am
The Mac version (v6 and more) supports Unicode so I guess it's the font used in the skin which doesn't support hebrew.
For chinese users, we advise to use a chinese font, like "STSong" for example so it is the same issue to my mind. So just edit the xml file and change the font.
About the playlist in Unicode, it's a known issue in VirtualDJ and will be fixed.
geposted Sun 01 Nov 09 @ 1:04 pm
