Actually when you close vdj and reopen it settings for the fx are gone ... if you need a particular time for "brake" fx for instance you need to set it every time, if you remember.
Andrew
Andrew
geposted Wed 18 May 05 @ 11:34 pm
Exactly you're right but the only way to have that is to add in the plugin the action to save the data in a file. Some plugins have that (some of Kaleo and macourteau and some of mine), others no
geposted Thu 19 May 05 @ 12:28 am
I dont like this too, especially for brake fx i dont ike the default brake time.
But even with plugins who save their settings like the (16-32 band eq's),
you need to load the presets manually everytime.
geposted Thu 19 May 05 @ 12:29 pm
well in the eq you can save more than 1 config so how can we load the good one with the plugin that's the reason why maybe only loading the first one or the last used. Why not... ask macourteau to add that in the function Onload() after his exams ;-)
For Brake, i can do it if the team allows me to upload it on the website after
geposted Thu 19 May 05 @ 12:33 pm
2. vdj hold more fx than 3 with keyboard shortcuts (like cueing).
geposted Sat 21 May 05 @ 7:03 am
