Forum: VirtualDJ Skins
Topic: button action="load_effect"
djjbPRO InfinityMember since 2004
button action="load_effect" isn't working...
geposted Thu 19 May 05 @ 9:07 am
djcelPRO InfinityModeratorMember since 2004
Well, it doesn't exist that's the reason why :-)
geposted Thu 19 May 05 @ 12:29 pm
WELL DJCEL!!!
read this http://www.virtualdj.com/support/developers/skin.html?PHPSESSID=15eb132131bc77e47c1b2bbbf3c6959e
there you read :(look down)
The Actions
Here is the list of the valid actions:
nothing : Useful to make a zone react to the mouse (with over for example) with no action
close : Close the software and return to Windows
minimize : Minimize the software to the taskbar
maximize : Switch to or from the fullscreen mode
play : Play the song on desk "chan"
play_n_loop : Start a loop on the first beats of the song (or exit the loop the second time).
pause : Pause the song on desk "chan"
stop : Stop the song on desk "chan"
sync : play and synchronize the song on desk "chan"
play_pause : Play the song on desk "chan" if it's paused, or pause it if it's playing
cue_stop : Cue the song on desk "chan" if it's paused, or stop it if it's playing
beatlock : Engage or disable the BeatLock
mix : Start an auto-mix
select : Set the desk "chan" as the active desk
master_volume : Set the windows' soundcard volume
headphone_volume : Set the volume of the headphones if any
headphone_mix : Set the proportion of the active desk you can hear in the headphone in addition to the working desk
mic_volume : Set the volume of the microphone if it's enabled on your soundcard
pitch : Set the pitch of the desk
pitch_reset : Smoothly reset the pitch to 100%
pitch_bend : Add a value to the pitch without changing the display and the pitch slider
crossfader : Set the crossfader value
level : Set the level value
gain : Set the gain value
bass : Set the bass equalizer value
kill_bass : Remove all bass from the song
bassfader : Crossfade only the bass
medium : Set the medium equalizer value
kill_medium : Remove all medium from the song
mediumfader : Crossfade only the mediums
high : Set the high equalizer value
kill_high : Remove all high from the song
highfader : Crossfade only the highs
eq_reset : Reset bass, medium and high to 0db
menu : Change to the "value"th menu page
settings : Open the settings configuration pannel
effect : Activate the "value"th effect
sample : Play the "value"th sample
loop : Enter or exit a loop of "value" beats length
shift_loop : Shift the loop from "value" beats
loop_in : Set the entry point of a manual loop, or change the entry point if relative
loop_in : Set the exit point of a manual loop, or change the exit point if relative
loop_length : Set the length of a manual loop
set_cue : Save the actual position in the "value"th cue point
goto_cue : Go to the "value"th cue point
song_pos : Set the playing position to "value"
scratch : Scratch the song from "value" samples (must be relative)
hold : Hold the disc
nudge : Nudge the song from "value" samples (same as scratch, but without beatlock effect)
skip_beat : Skip "value" beats in the song
zoom : Zoom the rhythm window
seek : Quickly move into the song
edit_bpm : Open the "fix rhythm" window
adjust_cbg : Manually adjust the CBG (obsolete, use edit_bpm instead)
adjust_cbg4 : Manually adjust the 4/4 pattern of the CBG (obsolete, use edit_bpm instead)
goto_mixpoint : Go to an automix point (obsolete, use edit_bpm instead)
set_mixpoint : Set an automix point (obsolete, use edit_bpm instead)
edit_comment : Open the "edit comment" window
pannel : switch the pannel "value" and all its sub-components
show_pannel : show the pannel "value" and all its sub-components
hide_pannel : hide the pannel "value" and all its sub-components
reset_xp10 : recalibrate the touch-sensitive device of the xp10
lock_pannel : Lock or unlock a sidepannel in the browser (directories or playlist)
favorite_folder : Set the current folder as favorite folder
scan_hd : Scan the hard drive for audio files
scan_cd : Scan a CD and add it in the search database
delete_cd : Delete a CD from the search database
automix : Enable or Disable the automatic playlist mixing
randomize : Randomize the playlist
onlynew : Remove all already-played songs from the playlist
repeat_playlist : Enable or Disable the repeat mode of the playlist
load_playlist : Load a playlist
save_playlist : Save a playlist
search : Go to the search page, and set the focus to the search box
record : Start or stop the recording
record_cut : Cut the recording to the next file or track
load_effect : Load an effect
load_sample : Load a sample
geposted Thu 19 May 05 @ 3:17 pm
I have just verified all the vdj actions and i don't see it. Only load_sample
Very strange this story
geposted Thu 19 May 05 @ 8:28 pm
i read it on this website..so i tought?!
geposted Thu 19 May 05 @ 8:51 pm
The easiest way I have found to check if a function is available is to see if you can map it in keyboard shortcuts! If you can assign a shortcut, you can assign a skin button.
geposted Thu 10 Aug 06 @ 4:09 pm
you're a litle late mykel
geposted Fri 11 Aug 06 @ 7:07 am
lol, yes, I am a little late. I am a little new to the forums.
Was hoping (even late) that my post would help future visitors :D
DJ Mykel
DJ Format
geposted Sat 12 Aug 06 @ 2:41 pm
