Topic: text with V 3.0
Hi all
How do you get to the window that will let you put in text?
geposted Sun 22 May 05 @ 10:39 pm
go to video pannel of new default skin
(in the middle of skin, between decks)
Choose TEXT button under the video preview window
geposted Sun 22 May 05 @ 10:45 pm
Seems to be integrated into a skin. Check out the default 3.0 skin and you will see by clicking video. I kind of liked the external window.
geposted Sun 22 May 05 @ 10:46 pm
I dont have that can some one post the new default skin?
geposted Sun 22 May 05 @ 10:51 pm
Just install the v3.0 again, the skin is included in the package.
geposted Sun 22 May 05 @ 10:53 pm
I have tryed that. Its not there, My default skin says 2.0
I need a full reInstall
geposted Sun 22 May 05 @ 10:56 pm
It's there. I think it was saved as just default. As long as you updated. Just switch it....
geposted Sun 22 May 05 @ 11:04 pm
It is not there, either the old 2.1 skin is in the update or there is none.
geposted Sun 22 May 05 @ 11:33 pm
Dev staffHome userSenior staffMember since 2003
Try to deactivate multi-users, and install again.
Same problem here .!!!!!!!!!!1
The default skin says in the middle 2.1
tryit everything!!!
???? pleasa help
geposted Sun 22 May 05 @ 11:40 pm
Multi user is off, and there is no skinfile in the update! If I remove 2.1 skin and update there is no new default.zip so I assume it's not there..
geposted Sun 22 May 05 @ 11:42 pm
DachPRO InfinityMember since 2004
Me too. No new skin.
Edit: Damn! That was fast. I still had time to update my old message!
geposted Sun 22 May 05 @ 11:45 pm
JeremKPRO InfinityModeratorMember since 2004
I have the same problem, the new default skin doesn't come with the package.
anyway i'll try again tommorow, maybe i missed it in the skin list in VDJ because i have so many skins.
geposted Sun 22 May 05 @ 11:50 pm
ooop, I know someone who will have a bad time tommorrow at the office ;)
Indeed, the skin didn't installe properly with the update if you had 2.1 installed.
It's been corrected, and you can now donwload anew.
geposted Sun 22 May 05 @ 11:57 pm
there is a new update file with the skin.. Nice to see there's still companies who actually pay attention.. ;)
tnx guys
Thanks support team.
geposted Mon 23 May 05 @ 12:11 am
Posted the information on French Forum.
Unfortunately, it is the most active but always the second aware of everything. LOL
geposted Mon 23 May 05 @ 12:16 am
mp3jrickPRO InfinityHonorary MemberMember since 2003
And working weekends mind you............
geposted Mon 23 May 05 @ 1:58 am
