Could someone make a skin for the Pioneer MEP-7000 Controller ?
Thank You
geposted Wed 07 Apr 10 @ 10:28 am
I could give it a try in a week or so as soon as I finish the current skin I'm working on right now. What type of Dj use you want it for? Audio? Video? Scratch?
geposted Tue 13 Apr 10 @ 3:00 am
I use The MEP-7000 for audio use only.
Thanks
Thanks
geposted Sun 25 Apr 10 @ 4:59 pm
FOR NEW UPDATE:
TODO MIX------> \"SKINATOR\"
geposted Tue 04 May 10 @ 11:44 am
The MEP-7000 skin looks great, I am excited about this , just waiting ti try it out
Thanks
Oswald Bobb
Thanks
Oswald Bobb
geposted Thu 06 May 10 @ 7:33 am
Any good news on the MEP-7000 skin?
Oswald
Oswald
geposted Wed 12 May 10 @ 1:38 pm
this skin look offical like it
geposted Tue 18 May 10 @ 2:15 pm
Need a tester?? I run VDJ on Touchscreen and want to try this to see if the buttons are big enough... This skin looks badass, I also edited some of the BS posts out of your topic. B
geposted Fri 28 May 10 @ 2:56 pm
already posted on the network, just need to stop the tests and for their respective downloads. is two resolutions 1280x800 and 1280x1024 I hope you like them. and if they like it, leave your worries. ok
Todo Mix ----------> Skinarte "skinator"
ps: I want to be tester skins !!!!!
be possible? I have to do to be tester skins? what level should I have?
vip? / Ultra vip / ......??
geposted Fri 28 May 10 @ 6:48 pm
I think you just have to contact the person making the skin and ask them and I guess pro level and above.
Keith
Keith
geposted Sat 29 May 10 @ 2:17 am
geposted Sat 29 May 10 @ 2:04 pm
Thank You Very Much, Great Job
Oswald
Oswald
geposted Sat 29 May 10 @ 3:06 pm
