OK, has anyone tried any other formats other than Bitmap (.bmp)???
I just tried a .png and get an error in line 0. Is there an attribute that needs to be added so VDJ looks for png or other in the zip and not a bmp??
Thanks,
cstoll
Thanks,
cstoll
geposted Mon 30 May 05 @ 4:19 pm
not sure if it is not valid only for version 3 skins :-(
geposted Mon 30 May 05 @ 4:27 pm
yes it only works with: version="3"
so you need to add the VDJ logo too
geposted Mon 30 May 05 @ 7:07 pm
OK, just finished updating a skin to version 3, everything works if the skin is bmp.
If I save it as a png and make a new zip with the png and xml, then I get the error mentioned before.
Any thoughts?
cstoll
Any thoughts?
cstoll
geposted Mon 30 May 05 @ 7:35 pm
i tryed to unpack the original vdj skin
converted bmp to png
packed replaced .... it drops an error
same for the jpg version
all i found on web is in the history section:
skin changes:
from now on, virtualdj logo is compulsory on all skin. Use . Min size is 100x25 (recommended is 177x43) and can't be covered by other elements.
skin files can be in .gif, .png, .jpg, etc...
all new skins need to set in order to use new features
in skin for different multiinstance backgrounds
pannels can be nested ()
to define preview windows for the video mixer
maybe dev team should provide us with more description ....
will vdj autmatically detect the name of the image or have we to specify the exact name ?
skin changes:
geposted Mon 30 May 05 @ 7:52 pm
hey lopez453, thanks for confirming my original post !!
cstoll
cstoll
geposted Mon 30 May 05 @ 7:55 pm
you are welcome :-)
i thought 2 "dumb heads" maybe find out more than one... maybe we need at least three heads to find out ourselves muhehe :-)
geposted Mon 30 May 05 @ 8:13 pm
