Hi I tried to do and up date of software update_virtualdj_v3.0.exe. and I am geting a error message that reads.
virtualdj.exe - inable to locate component
This application has failed to start because d3d9.dll was not found. Re-installing the application may fix this problem
I have re installed the software still geting error message
Please help than you
PS. the above message comes out when starting virtual dj verything downloads ok
geposted Mon 30 May 05 @ 10:37 pm
Try to completely remove VDJ. First uninstall it, then remove HKEY_LOCAL_MACHINE/Software/VirtualDJ
Then install VDJ again and it should work fine. Otherwise contact e-servis.
Dj Nikki
Dj Nikki
geposted Mon 30 May 05 @ 10:54 pm
I did removed the software completly and still doing the same
geposted Mon 30 May 05 @ 11:25 pm
Your anser can be found here - http://www.virtualdj.com/forum/display.html?topic=11911
It's the FAQ from the General Discussion Section.
Read the second to last item.
cstoll
cstoll
geposted Tue 31 May 05 @ 1:08 am
Install the newest DirectX (9.0c?)
If you have it installed already, reinstall it because part of it is either missing or unable to be located by Windows.
Hope that helps,
-Frd
Hope that helps,
-Frd
geposted Tue 31 May 05 @ 5:25 pm
remove HKEY_LOCAL_MACHINE/Software/VirtualDJ.
Where do you go to remove this please?
geposted Thu 02 Jun 05 @ 2:52 pm
Easy way: use RegCleaner and search for it.
Dj Nikki
Dj Nikki
geposted Thu 02 Jun 05 @ 3:13 pm
too complicated:
- windows start
- execute
- "regedit"
- ok
NB: regedit.exe is the windows editor, reader of the windows registry
- windows start
- execute
- "regedit"
- ok
geposted Thu 02 Jun 05 @ 3:42 pm
Be carefull not to change anything else in the registry; else you could make your system crashed.
geposted Thu 02 Jun 05 @ 7:26 pm
that's a directx error reinsall directx9c
geposted Thu 02 Jun 05 @ 7:36 pm
