Kati tetoio egine kai se mena. Kati allakse kai den to exw vrei akoma. Vevaiwsou oti ta arxeia tis VMS (mapper kai definition) einai stis theseis tous (VirtualDJ/Mappers kai VirtuaDJ/Devices). Se diaforetiki periptwsi ksanakatevase ton mapper (an xrisimopoieis ton diko mou).
An xrisimopoieis ton default, kane factory reset (epanafora) (Config-Mappers to katw eikonidio)
geposted Tue 08 Mar 11 @ 3:17 am
pedia gia tin 7,3 version pos na tin egatastiso?? na tin valo pano se auti pou exo i na apenegatastiso tin proigoumeni k na valo auti?
geposted Tue 08 Mar 11 @ 6:50 am
O tropos egkatastasis exei allaksei. Yparxei neos installer. Katarxin den tha sou zitisei serial number. Deuteron tha se rwtisei an thes typical i custom. Mporeis dld na zitiseis na min egkatastisei ksana skins, plugins klp, an gia kapoio logo as poume exeis allaksei to Default Skin, i exeis svisei kapoia defaults effects.
PANTA kratame backup to fakelo VirtualDJ kai tin database gia pan endexomeno.
Stin prokeimeni periptwsi opws kai se kathe update, kaneis kanonika egkatastasi apo panw.
geposted Tue 08 Mar 11 @ 6:55 am
euxaristo dj dad!
geposted Tue 08 Mar 11 @ 7:01 am
eyxaristw poly!!!
geposted Tue 08 Mar 11 @ 8:44 am
geposted Thu 10 Mar 11 @ 6:04 am
parakolouthiste to video kai peite mou an kano kati lathos kai de bgainei sta apotelesmata me ti proti fora kai thelei kathe fora
add to search gia na to bgalei.
http://www.youtube.com/watch?v=gx6qgV0eZH8
balte 720p kai fullscreen
geposted Fri 11 Mar 11 @ 2:27 pm
akyro
ekana check-clean-fix kai to bgazei tora alla san kainourgio!
ti anapodies einai autes....
geposted Fri 11 Mar 11 @ 2:34 pm
kalhmera se oloys,
xerei kaneis an agoraza thn hercules DEEJAY TRIM 4&6 an tha exw megalyterh endash kai sthn exodo kai sta acoustika sthn vms4;
eyxaristw
eyxaristw
geposted Sun 13 Mar 11 @ 3:09 am
Omire min mpeis stin diadikasia na xwseis alla lefta gia karta ixou. Egw dokimasa tin Audio2Dj pou thewreitai oti exei entasi analogi twn CDplayers kai eida sxetika mikri veltiwsi. Eidika sta akoustika, fainetai pws kapoios eswterikos limiter empodizei tin megali entasi. Gnwmi mou einai na pareis enan enisxyti akoustikwn (pou einai kai ftinoteroi). Twra gia tin entasi eksodou, den asxolithika idiaitera. Eutyxws opou exw paiksei mexri twra, eite me dika mou mixanimata eite allou, apla edina ligo parapanw ston enisxyti.
geposted Sun 13 Mar 11 @ 9:56 am
eyxaristw djdad
geposted Sun 13 Mar 11 @ 1:23 pm
enisxuths akoustikwn???Prwth fora to akouw pali auto... :P epeidh kai gw exw ena 8ema me tn entash sta akoustika mporeis na mou dei3eis ena tetoio enisxuth..?
geposted Sun 13 Mar 11 @ 2:35 pm
....GOOGLE... "headphone amplifier"..
Ante ola etoima ta perimenete oi neoi .. !
geposted Sun 13 Mar 11 @ 3:09 pm
:P
geposted Sun 13 Mar 11 @ 4:06 pm
djdad wrote :
Kapoios sto Wishes Forum zitise apo to VirtualDJ to SLIP MODE pou yparxei sta nea CDJs.. Posa den kserei...lol
Ftiakste ena koumpi me
var_equal "slipmode" 0 ? deck 1 clone_deck 3 & set "slipmode" 1 : deck 3 clone_deck 1 & set "slipmode" 0
xrisimopoieiste ena 4 deck skin.. kai dokimaste to.
kati de katalaba sosta.
se mena de douleuei.
ti prepei na kanei akribos?
auto den enooei?
http://www.youtube.com/watch?v=8Ilucq43dm4
geposted Mon 14 Mar 11 @ 4:50 pm
σημερα ανακαλυψα και τα νεα εφφε phazer k reverb κ wah... ειναι καινουρια αυτα??? πολυ καλα!!!
geposted Mon 14 Mar 11 @ 6:17 pm
Paidia to vrika !!!! , alla thelw dokimes ..emena mou douleuei...
Ftiakste ena shortcut (keyboard i midi) gia na kanei toggle metaksy SLIPMODE ON kai OFF me entoli
var_equal "$slipmod" 0 ? set "$slipmod" 1 : set "$slipmod" 0
meta mapparete to touchwheel_touch ws
var_equal "$slipmod" 0 ? touchwheel_touch : touchwheel_touch & down ? var_equal "clon" 0 ? deck 1 clone_deck 3 & set "clon" 1 : touchwheel_touch : deck 3 clone_deck 1 & set "clon" 0
Ennoeitai oti prepei na exete ena 4deck skin fortwmeno !
An to jog sas den einai touch sensitive, dokimaste na antikatasisete to touchwheel_touch me jogwheel
Peite mou an sas douleuei na diorthwsw to sticky post.
geposted Mon 14 Mar 11 @ 6:27 pm
tha to dokimaso aurio kai tha sou po
geposted Mon 14 Mar 11 @ 7:19 pm
paidia geia sas,
meta thn eggatastash tis v7.0.3 sthn thesh twn playlist moy vgazei to oikonidio 'o ypologistis moy', moy tis exafanise, sos ti ginetai?
eyxaristw!!
eyxaristw!!
geposted Tue 15 Mar 11 @ 11:53 am
Pigaine Config->Browser kai des an stin aristeri stili einai tsekairsmeno to Show Playlists.
An den emfanisoyoun tote diavase to parakatw, einai copy-paste apo to General Forum. Parousiastike ena themataki me ton neo Installer. Tha lythei se epomeno update. Pros to paron dinetai kapoia lysi..
Update to this problem
The problem is because an extra '\' is in the path reference. You can correct this by using Registry Tool or editing the registry entries for the RunFolder and HomeFolder. Just remove the \ at the end of the statement.
Also, noticed that the MP3 Encoder entry has a double \\ in the path statement - that can be corrected in the Recording setup dialog.
The default sampler slot entries also have the \\ in them - also easily corrected in the VirtualDJ sampler section by just selecting the samples again for each slot.
This is most likely because of the changes to the installer we are now using. Information has been passed on to the Dev Team.
geposted Tue 15 Mar 11 @ 12:26 pm
