The notepad is found at the plugin tab.
geposted Wed 14 Mar 12 @ 7:50 pm
Sorry, i didnt realize my second screen was there
i know where i find the plugin...
but i did not get an additional window..which i should get ....
geposted Wed 14 Mar 12 @ 8:00 pm
Thanks for that screenshot - that appears to be an older version that I have here so I'll test it and upload an updated version in the very near future.
The newer version just uses a popup, it doesn't bother with the hassle of the double window setup.
geposted Wed 14 Mar 12 @ 8:09 pm
Am I correct that I have the current version available?
Thanks again for your time.
geposted Wed 14 Mar 12 @ 8:24 pm
I believe so. I'll get an updated version sorted over the next couple of days.
geposted Wed 14 Mar 12 @ 9:02 pm
Scott,
If I create a text file with Windows notepad (i.e one line of text on each line, like a list of top 100 disco tracks) and then import it into your notepad plugin, all the formatting is lost, and all the text is in one string ........... Any ideas ?
geposted Mon 04 Nov 13 @ 8:23 am
Any chance of a version of this VDJ 8?
geposted Thu 12 Jun 14 @ 3:29 pm
+1
Please SBDJ ,I Love this Notepad Plugin too
for the Music Wishlist of the Guest
thanks forward
greatings,Dirk
geposted Wed 14 Jan 15 @ 10:38 am
Hello SBDJ!
Gives some news for this Plugin
Do you work eventually on a Notepad Plugin for VDJ 8 ?
greetings and thanks ,Dirk
geposted Sun 05 Feb 17 @ 6:46 pm
Won't this do what you want?
geposted Mon 06 Feb 17 @ 1:43 am
@locodog
thx for pointing this out.
geposted Mon 06 Feb 17 @ 11:21 am
@locodog:
No
I use this as Wishlist for the Title of Music by Guest.
When someone comes to me and have a Title what i soll play than i write this in the Notepad List,for later Time when the Title are comes in my Playlist to the right Time and i not forget him.
greatings,Dirk
No
greatings,Dirk
geposted Mon 06 Feb 17 @ 2:06 pm
Wouldn't it be easier to set these titles apart in a separate playlist or the sidelist directly, instead of fully typing the names and then having to go search for them before you can play them?
geposted Mon 06 Feb 17 @ 2:38 pm
Indeed it would. But sometimes you just don't want to search for a song while the guest is standing next to you. There are plenty of reasons why you would do that.
So you need a place to write down the track.
geposted Mon 06 Feb 17 @ 3:10 pm
