Topic: tell me ...
hey i got about 15 speakers at home and 2 subwoofers i wanna know if i gotta connect them through one amplifier say for may be a room about say 20 ft by 16 ft or something like that which amplifier should i buy which is not very expensive so pl let me know ppl and also may b the price of the amps ull suggest.
will check soon thnx.
geposted Tue 21 Jun 05 @ 9:37 pm
JeremKPRO InfinityModeratorMember since 2004
Please try to write in correct english. It is quite difficult for non-english mother language to understand what you are asking for.
I understood but can't give any advice since i don't own any amplifier.
geposted Wed 22 Jun 05 @ 2:11 am
It takes all types doesn't it ? If this wasn't a general forum I would delete this thread.
geposted Wed 22 Jun 05 @ 5:50 am
djbambiPRO InfinityMember since 2003
you can't connect 15 speakers to one amplifier, there's a question of speaker impedance (XX ohms), not just power.
best would be for you to go to a sound equipment store and talk to a technician.
geposted Wed 22 Jun 05 @ 11:37 am
if the speakers are the same you can easily combine them
but be careful, if you have amplifier for the 4 OHM speakers you can connect anything that
has 4 or more OHMs and your amplifier will not get blown :-)
but more ohms the the sound will be more quiet
if you have two 8 ohm speakers and connect them in series
(amplifier-)...(SP1-) (SP1+)...(SP2-) (SP2+)... (amplifier+)
you will get 16 ohms so it will be ok but will sound quiet
if you have two 8 ohm speakers and connect them in parallel
(amplifier-)...(SP1-) (SP1+)..(amplifier+)
(amplifier-)...(SP2-) (SP2+)..(amplifier+)
you will get 4 ohms and if your amplifier is for 4 ohms it is ideal
you can consider this connection as one speaker then
combining four 4ohm speaker you can get
two 8ohm speaker sets (2 speakers in series) and when you connect theese 2 sets in parallel you will get 4 Ohm 4 speaker set. but 4 times powerful than individual speaker.
It is difficult to combine 15 speakers :-) but you will sure find a way but it will be a lot of cables.
and don't even mind phasing problems comming from the different layout of the individual speakers in the room.
If your subwoofers have a bulit in bass filter all is ok but anyway it's goot to have separate amplifier for the subwoofers and separate for the "normal" speakers. Also you will need a crossover that will separate the frequencies specifically for the subwoofers and for the speakers.
geposted Wed 22 Jun 05 @ 5:00 pm
