Here's a Little audio lesson about BPM's and The basics on how to Blend an Acappella over an instrumental...Its very Helpful and easy to follow along...All credit go's to the author of the lesson (Dj KidKrunk). You can download the audio lesson below...
Musically
Dj WizzKidd
http://s12.yousendit.com/d.aspx?id=19DJTA62Q9FWC1V5AURGZ4DA2K
Musically
Dj WizzKidd
geposted Thu 23 Jun 05 @ 4:33 am
How can i make acapellas from the tracks i have? Is there any software availabe for this?
geposted Sat 25 Jun 05 @ 10:22 pm
you cant...wish there was a way...you can get acappellas from the 12" vinyl or a CD single...some tracks you cant find acappellas for...
geposted Sun 26 Jun 05 @ 1:57 pm
OK, guessed so...thanks anyways!
geposted Mon 27 Jun 05 @ 4:51 am
i heard there is a way if you have an instrumental track and the main version. you simply(easier said then done) match the beat with the main song, i guess you have to invert the sound and it cancels out, much like when you match beats and they sounds so strange, leaving only anything else not cancelled out.
geposted Mon 27 Jun 05 @ 6:05 pm
geposted Mon 27 Jun 05 @ 6:14 pm
Hey, thanks listen2. I'll give that a try if i can.
geposted Thu 30 Jun 05 @ 12:32 pm
