Forum: Old versions
Topic: TCV Setup Manual and Additional Instructions
cstollPRO InfinityMember since 2004
Advance Virtual DJ Configuration - Using ASIO4ALL and Timecoded Vinyls
Advanced Asio Config
For Registered Users --
DAMS blog with a connection graphic:
Link
My blog with some basic starting points for manually configuring the MAYA and VDJ:
Link
Anyone else have some good posts for reference on TCV and TCCD setups with the MAYA or other soundcards please post them here as well.
cstoll
geposted Fri 24 Jun 05 @ 5:53 pm
djcelPRO InfinityModeratorMember since 2004
1) You need STEREO audio inputs (line in)
2) Don't forget to mute the line in for the listening mode in the mixer of Windows
(only line in for recording mode has to be open)
geposted Tue 09 May 06 @ 12:04 am
