Forum: Music discussion
Topic: Siren + cut effect
claxPRO InfinityMember since 2004
A cool sound is to load the sample "siren" in a deck, change the BPM according to the other deck one.
Then when the other deck is playing without voices you play the siren in beats, apply my "cut" effect at 1/2, then change to 1/4 and 1/8 by decreasing the level.
geposted Sat 23 Jul 05 @ 6:34 pm
JeremKPRO InfinityStaffMember since 2004
You will have to explain this to me in french on msn, didn't quite understand everything!
geposted Sun 24 Jul 05 @ 6:57 pm
No problem Jeremie.
geposted Sun 24 Jul 05 @ 9:10 pm
or explain it on the L3 french forum?
Thanks Christophe.
geposted Mon 25 Jul 05 @ 11:56 am
I'll contact you with MSN.
geposted Mon 25 Jul 05 @ 5:00 pm
ntamiHome userMember since 2016
pls how do i find the siren function and other functions in the VDJ8
geposted Fri 19 May 17 @ 10:04 am
geposted Fri 19 May 17 @ 12:15 pm
