Hello,
I use some MP3 that are compressed using VBR (variable bit-rate).
If I use the memory limitation, sometime VDJ don't load the song because it saw it as a 33minutes song (for exemple) when it's only 4 minutes.
It should it be interesting to be able to set the memory load limitation using the mp3 file size and not the song lenght (that can be wrong).
Am I alone in this case?
Thanks for all the work done on VDJ.
geposted Mon 25 Aug 03 @ 8:00 pm
