slip mode= Option to allow you to scratch using a touch sensitive and then when let go for the song to go bak to exactly where it should have been as if the track was never interrupted.
geposted Mon 14 Mar 11 @ 2:29 pm
Hmmm, i have an idea, but i'll have to try it first. I was thinking something like... cloning the deck to a spare one, and when the slip mode goes off clones the deck back. ... i'll report later.
[EDIT] It was faster than i thought... :p
Use a 4 deck skin..
slip mode ON.. deck 1 clone_deck 3
slip mode OFF.. deck 3 clone_deck 1
Deck's 3 volume must be always down (0%). You might have a slight sound gap, depending on your sound card latency. Mine doesnt have such. Try it and post feedback.
[EDIT2]
Or use a siingle button to toggle slip mode with the folloowing code
var_equal "slipmode" 0 ? deck 1 clone_deck 3 & set "slipmode" 1 : deck 3 clone_deck 1 & set "slipmode" 0
I'm sure jpboggis will fix this script to toggle slipmode automatically when touchwheel is active.(with touchwheel_touch)
You see, Pioneer sells so expensive these features. VDJ asks much less ...lol !!!
Use a 4 deck skin..
[EDIT2]
geposted Mon 14 Mar 11 @ 3:48 pm
Well, i'm close...
This one if you assign to your Touch_Wheel_Touch
touchwheel_touch & down ? var_equal "clon" 0 ? deck 1 clone_deck 3 & set "clon" 1 : nothing : deck 3 clone_deck 1 & set "clon" 0
it will work as described, but i cant make it work according to slipmode.
This doesnt work
var_equal "slipmode" 1 ? touchwheel_touch & down ? var_equal "clon" 0 ? deck 1 clone_deck 3 & set "clon" 1 : nothing : deck 3 clone_deck 1 & set "clon" 0 : touchwheel_touch
I will need some help here..
This doesnt work
geposted Mon 14 Mar 11 @ 5:01 pm
Ok i got it
Assign a keyboard or midi shortcut to to toggle slipmode
var_equal "$slipmod" 0 ? set "$slipmod" 1 : set "$slipmod" 0
then assign you TOUCH_JOG, as
var_equal "$slipmod" 0 ? touchwheel_touch : touchwheel_touch & down ? var_equal "clon" 0 ? deck 1 clone_deck 3 & set "clon" 1 : touchwheel_touch : deck 3 clone_deck 1 & set "clon" 0
you might need to replace touchwheel_touch with speedwheel_touch or jogwheel.
geposted Mon 14 Mar 11 @ 6:23 pm
Hows that old saying go, "Master we are not worthy", frickin genius! Take that Pioneer, lol!!
Huey
Huey
geposted Mon 14 Mar 11 @ 7:56 pm
djdad, thank you. I will try your scripts when I get home.
geposted Mon 14 Mar 11 @ 8:49 pm
I need to clarify one thing more.
You dont have to choose a 4 deck skin to make this work. You may also use a 2 deck skin. But you have to edit the first line of the xml file.
Replace nbdecks="2" with nbdecks="4" and you're good to go.
geposted Mon 14 Mar 11 @ 9:17 pm
This is way too cool :D How to make such a thing with loops? I'm lazy and not too good in VDJscripting...
geposted Tue 15 Mar 11 @ 4:44 pm
Hmmm thats a little harder, because there are several ways to activate a loop, so you will have to change the script to loop, loopin, out, maybe loop1,2,4,8, etc.
I'll report a solution..
Ps i will post later the script for touchwheel_touch to work slipmode on both decks..
geposted Tue 15 Mar 11 @ 5:27 pm
Ok..here we go..
The slip mode final release
For Controllers !
Assign a button to your controller as
var_equal "slipmod" 0 ? set "slipmod" 1 : set "slipmod" 0
and assign your touchwheel_touch as ..
var_equal "slipmod" 0 ? touchwheel_touch : touchwheel_touch & down ? var_equal "clon" 0 ? device_side 'left' ? deck 1 clone_deck 3 & set "clon" 1 : deck 2 clone_deck 4 & set "clon" 1 : touchwheel_touch : device_side "left" ? deck 3 clone_deck 1 & set "clon" 0 : deck 4 clone_deck 2 & set "clon" 0
as you may noticed the var slipmode is not global anymore, meaning that you can switch on and off slip mode to each deck separately.
For Controllers !
geposted Tue 15 Mar 11 @ 5:46 pm
Hmm... I'll try that with my CDJ-900 :-) I LOVE the slip mode on that toy :D
geposted Wed 16 Mar 11 @ 2:21 pm
TexZK,
You can try these too on your CDJs 900
slip mode for Loops 1..8
Assign
LOOP1
var_equal "slipmod" 1 ? loop ? device_side 'left' ? deck 3 clone_deck 1 & loop_out : deck 4 clone_deck 2 & loop_out : device_side 'left' ? deck 1 clone_deck 3 & loop 1 : deck 2 clone_deck 4 & loop 1 : loop 1
Assign
LOOP2
var_equal "slipmod" 1 ? loop ? device_side 'left' ? deck 3 clone_deck 1 & loop_out : deck 4 clone_deck 2 & loop_out : device_side 'left' ? deck 1 clone_deck 3 & loop 2 : deck 2 clone_deck 4 & loop 2 : loop 2
LOOP4
var_equal "slipmod" 1 ? loop ? device_side 'left' ? deck 3 clone_deck 1 & loop_out : deck 4 clone_deck 2 & loop_out : device_side 'left' ? deck 1 clone_deck 3 & loop 4 : deck 2 clone_deck 4 & loop 4 : loop 4
LOOP8
var_equal "slipmod" 1 ? loop ? device_side 'left' ? deck 3 clone_deck 1 & loop_out : deck 4 clone_deck 2 & loop_out : device_side 'left' ? deck 1 clone_deck 3 & loop 8 : deck 2 clone_deck 4 & loop 8 : loop 8
Not perfect yet. It works ok, but if you try to jump from loop 2 to loop 1 it messes up :p
For now, you may use loop_double and loop_half combined with the above codes, to work.
Assign
LOOP1
Assign
LOOP2
LOOP4
LOOP8
geposted Thu 17 Mar 11 @ 8:19 pm
LOOP OUT
var_equal "slipmod" 1 ? loop ? device_side 'left' ? deck 3 clone_deck 1 & loop_out : deck 4 clone_deck 2 & loop_out : device_side 'left' ? deck 1 clone_deck 3 & loop_out : deck 2 clone_deck 4 & loop_out : loop_out
LoopIn, LoopHalf and LoopDouble stay as they are.
So the only issue here is when jumping from one loop to another using loop1,2,4,8
Ohh.. and something important. I think in case of single controller such as CDJs you need to replace device_side 'left' with action_deck 1
geposted Thu 17 Mar 11 @ 8:49 pm
Is there also a way to do this without just using a clone deck? I've thought about slip mode before, I would do something like activate dump and reverse at the same time, and then maybe invert the paramater on the jog? Dump is basically like slip mode already, and when you dump and reverse at the same time, the song is moving forward. Then you could scratch, loop, cue juggle, or whatever and it would act exactly like slip mode while only using 1 deck.
geposted Wed 23 Mar 11 @ 4:08 am
If you activate dump, then the you will hear the reverse sound. I think it's not the right way to do.
geposted Wed 23 Mar 11 @ 8:57 am
Would the DNS3700 be considered as having a touchwheel? This is script is interesting...
geposted Wed 23 Mar 11 @ 8:48 pm
Well those denon_platter actions, i cant tell how could they behave, by replacing those touchwheel actions. Maybe you could try. NS7 with those ns7_platter too.
We would need that feedback, if someone tries them.
geposted Wed 23 Mar 11 @ 10:28 pm
can this function work using the mix trak controller?
geposted Thu 31 Mar 11 @ 8:38 pm
Certainly.
geposted Fri 01 Apr 11 @ 6:13 am
I asked about this in another thread - I added the code, but I had to make a few changes to make it work.
I'm using the Denon MC6000.
var_equal '$slipmod' 0 ? touchwheel_touch : touchwheel_touch & down ? var_equal 'clon' 0 ? device_side "left" ? deck 1 clone_deck 3 & set 'clon' 1 : deck 2 clone_deck 4 & set 'clon' 1 : touchwheel_touch : device_side "left" ? deck 3 clone_deck 1 & set 'clon' 0 : deck 4 clone_deck 2 & set 'clon' 0
It's a really smart idea, great work.
The one issue I'm running into is this: let's say I'm working off the left deck. When I release the touchwheel, deck 3 clones itself immediately to deck 1. But the touchwheel is still spinning, so the spinning wheel acts on the song AFTER it got cloned back, so the cloned song gets moved by the wheel. In order for this to work, you have to come to a full stop THEN release (which sucks) , or the programming needs to clone the song AFTER the wheel stops spinning. Any ideas?
geposted Sun 24 Apr 11 @ 2:16 pm
