Hi,
any news about a the 4 deck version?
Thanks for all your hard work & support ;o)
geposted Thu 05 May 11 @ 11:29 am
This is an excellent controller skin! It sits at the top of my list of all time favorites and use it every weekend. djdad is a machine!
geposted Tue 10 May 11 @ 12:03 pm
superaceman wrote :
... djdad is a machine!
+1 ! :- D
geposted Thu 12 May 11 @ 6:16 am
Update
GROM ver 1.2
Download link :
http://www.virtualdj.com/addons/12902/GROM.html
Ver 1.2
HotCues Indicators....
When you use the Cue-stop button, to cycle through the HotCues, the selected HotCue will now show in different color.
When loop is active the jogs are colored differently and the LOOP indicator now is inside the jogs.
Active Effect now flashes.
Crossfader is removed. The GROM logo on the top is now the 50% crossfader indicator (Grey when different value)
Enjoy !
GROM ver 1.2
Download link :
Ver 1.2
- Added Timecode Signal indicators
- Added Effect Slider\'s names
- Added New Hot Cues indicators
- New Loop Jog indicator
- Several graphic changes
Enjoy !
geposted Sun 22 May 11 @ 7:05 pm
Thanks 4the update Bob..
Downloading...
Downloading...
geposted Sun 22 May 11 @ 8:15 pm
I gotta say even though I don't use your skins, you ALWAYS come out with some dope features!!
Nice work, again, lol!
Huey
Huey
geposted Sun 22 May 11 @ 8:52 pm
...thanks ;o)
geposted Mon 23 May 11 @ 10:55 am
Would look killer in 1080.
I need to GROM as well, but tis is difficult. :)
geposted Mon 23 May 11 @ 12:18 pm
Thanks for this update ;o)
geposted Mon 23 May 11 @ 4:31 pm
djdad wrote :
Hello first. thank you for this great skin
i used it yesterday on an birthday and it works great:-)
but i want you to ask for a small change
1.
at the moment if i whant to load a file i have to put it in the cicle
if it could also load when i put it near the time display it would be very cool when i use the touchpad it is very hard to put it direkly in
2.
unfortunaly i have no lic for skin resicer but my notebook has 1680 x 1050 is it posible for you to make a version with a greater browser section for me
thanks and a gain great work
gerrit
geposted Sun 29 May 11 @ 5:26 am
- About the Dropzone (the deck song drop area)... I should have changed that to last update, but i forgot it :) as i always use keyboard or midi shortcuts for loading.
You can edit the skin file yourself too.
Unzip and edit the 1440X900 xml file with Notepad or similar Text or XML editor. Search for dropzone (you will find two parts) and edit those elements by changing those Bold numbers you see below. Close the file and choose to Save and update the zip file.
part 1 for deck 1 ..
<dropzone chan="1">
<size width="650" height="165"/>
<pos x="9" y="116"/>
</dropzone>
part 2 for deck 2..
<dropzone chan="2">
<pos x="781" y="116"/>
</dropzone>
- About the skin resize to 1680X1050... You can use the Skin Resizer Tool and use with Simple Resize option from 1440X900 to 1680X1050 (same ratio 16:10). You don't need a license for that. This is why i proposed you to edit the 1440X900 resolution above.
<dropzone chan="1">
</dropzone>
part 2 for deck 2..
<dropzone chan="2">
</dropzone>
geposted Sun 29 May 11 @ 10:30 am
nice green and orange color scheme sir.
geposted Mon 30 May 11 @ 3:42 pm
DJdad Your The Zin Ohhh I Mean Skin Master :-0 Im Using Grom Right Now. Then I saw This Post!!!!! Nice I Gotz A Big Gig Dizz Saturday & Will Be Showing Off Your Skinz Peace DJ Tyme209 California
geposted Tue 07 Jun 11 @ 11:10 pm
can you add multiple fx slots like u did for the cues, that would help, thanks
geposted Sat 18 Jun 11 @ 3:21 pm
Looks fantastic, but i miss the video panel.
Guess when the video panel is included and my needed resosolution too (1900X1200) it is hard for me to choose the right one ;-)
> Dark Minimal
> Dark Default HD
> Grom
Damned, you should stop to make such fantasic skins.
Hard to select the right one ;-)
> Dark Minimal
> Dark Default HD
> Grom
geposted Thu 23 Jun 11 @ 3:44 am
> Dark Minimal
> Dark Default HD
> Grom
> Dark Minimal
> Dark Default HD
> Grom
1+
Haui, don't forget the "Rusty" edition ;o)
geposted Thu 23 Jun 11 @ 7:13 am
A Grom Video Edition is in my plans for sure.
Right now i use 2 skins myself too. Grom for Audio gigs and Dark Minimal for Video.
geposted Thu 23 Jun 11 @ 7:54 am
+1 for the Grom Skin if using audio but the Rusty skin is the best for video ;o)
geposted Mon 27 Jun 11 @ 6:29 am
Could you also make a Version of the 2 Deck Skin in 1680*1050? That would be awesome. I really love your Skin because you can focus on the important things^^
geposted Sat 24 Dec 11 @ 5:16 pm
This is the first skin that seems to make total sense and not look like someone had a seizure while tripping acid. Very clean!
My -only- gripe about it is that there is no 1680x1050 or 1920x1080 version. I run a laptop setup, and when at home I have my 1080 monitor hooked up.
Any plans for a larger version?
geposted Mon 26 Dec 11 @ 1:07 pm
