Forum: VirtualDJ Skins
Topic: JukeBox - Page: 4
docPRO InfinityMember since 2020
DAMILES, I cannot find where to download your skin?
geposted Sat 14 May 16 @ 11:06 am
geposted Sat 14 May 16 @ 12:02 pm
@djdad:
Does there comes in the Future a New Skin of a Jukebox for VDJ 8.2 ?
Was very nice when this Jukebox Skin comes Someday for use on our Homepartys.
greatings and thanks forward
Dirk
geposted Mon 24 Apr 17 @ 12:11 pm
Does there gives some News for a Jukebox Skin for VDJ 8 ?
Where very nice to see a Skin in Jukebox Optic for VDJ 8
Greatings and thanks ,Dirk
geposted Fri 02 Mar 18 @ 6:04 pm
Hola buenas
Me podríais explicar cómo funciona el Jukebox ya que no encuentro vídeos y no se muy bien para que funciona
Un saludo
geposted Wed 11 Apr 18 @ 10:58 am
Just to let you know this skin will row on VDJ 2018 as long as you resize the screen resolution of the touch screen monitor.
Using it a n my bar mates n Thailand.
Thanks to Djdad abs dimiles
geposted Tue 22 Jan 19 @ 9:23 pm
@djdad:
Does there Come in a near Future a Jukebox Skin for VDJ 2020 ?
I hope so,Love The Old V7 Skin
Greatings,Dirk
geposted Thu 13 Feb 20 @ 9:00 am
I'd like to use this on a display with resolution 1366 x 768 How can it be resized? thx Dan
geposted Sat 23 May 20 @ 10:48 am
NicotuxHome userMember since 2014
not only resize is needed ^^
must almost be totally rewrite for 8.4
but you can start with a resize zone just to make it usable
i.e.: just after the grabzone
<resizezone>
<size width="80" height="24"></size>
<pos x="1200" y="1000"></pos>
</resizezone>
geposted Sat 23 May 20 @ 11:22 am
well.. somehow rewritten almost all vectorial and updated for V8
both pages fully resizable
https://imgur.com/a/UpfRZVY
PM/ask to DjDad if he allows to make it available...9 years later ^^
geposted Tue 26 May 20 @ 4:34 pm
Sure, you are free to modify and publish
geposted Tue 26 May 20 @ 5:25 pm
Thanks DjDad some tweeks and uploaded
geposted Tue 26 May 20 @ 6:38 pm
Nicotux. Thank you for your hard work on the new skin.
Just one comment, is there the feature in playlist to clear the playlist and shuffle the playlist. I couldn’t see them.
geposted Wed 03 Mar 21 @ 7:40 pm
Badly no,
to clear the playlist you can select all add rightclick -> remove
Skin is from 2011... there was no shuffle at this time if i remenber correctly.
it stay in automix options that are not exposed
may add this in future version :)
geposted Wed 03 Mar 21 @ 8:30 pm
