Forum: VirtualDJ Skins
Topic: Skins not working with DJConsole version of VDJ...?
WertzHome userMember since 2004
Hi,
I've been trying to update/add some new skins for my DJ console version of VDJ (v1.09-DJC)
I unpack them with winrar and extract to the skin folder in VDJ's program file, but with several of the ones I've tried so far I get Error messages about invaild XML code and various other errors.
What's the story?
Mainly seems to be the Pioneer skins and some others; the good ones in other words.
Are these only meant for the full version?
Can anyone recommend a decent looking skin that WILL work with DJC?
Any help appreciated.
geposted Sun 31 Jul 05 @ 5:19 pm
johansPRO InfinityMember since 2005
If you have xml error for line 0, just replace this line with the one from a working skin and problem is solved.
Had same problem with two skins and I solved it as described above.
Johans
geposted Sun 31 Jul 05 @ 7:02 pm
JeremKPRO InfinityStaffMember since 2004
The problem i think is coming from the skins themself and you version of VDJ. More and more skins are made for the version 2 of VDJ or even version 3, and they have functions that aren't supported with the dj console version that is only version 1.09.
Try to go to the last page of skins and try the skins from the oldest the newer ones.
geposted Mon 01 Aug 05 @ 12:16 am
Thx folks...tried changing the XML but to no avail.
I then tried some of the older skins that are 2.0 compatible and those work fine...
Even found a nice pioneer one, so problem sorted. :D
geposted Mon 01 Aug 05 @ 2:16 pm
