Hallo VDJ-Gemeine,
Hallo RMX -User,
kann man seine 12 RMX-Buttons neben den Effekten auch mit Sampler belegen? Wenn ja, wie? Bin auf der Suche weder in den Handbüchern noch hier im Forum fündig geworden!
Gruß
Mario
Hallo RMX -User,
Gruß
Mario
geposted Mon 04 Apr 11 @ 4:24 am
Natürlich.
Du kannst jeden Button frei programmieren (naja fast, den Mic On/Off nicht).
Hier mal ein Auszug aus der VDJScript Verbslist zu den Sample
Und im englischen Wiki gibts die komplette Liste.
Oder direkt, hier: http://www.virtualdj.com/wiki/VDJscript_verbs.html
Quote :
sampler play : play the selected sample. syntax 'sampler play' plays the default sample. 'sampler 4 play' plays the fourth sampler slot.
sampler play_stutter : play the selected sample. if already playing, restart from begining.
sampler play_stop : play the selected sample if it's not already playing, or stop it if it's already playing.
sampler stop : stop the selected sample. syntax 'sampler stop' stops the default sample. 'sampler 4 stop' stops the fourth sampler slot. 'sampler all stop' stops all samples.
sampler volume : change the volume of the selected sample.
sampler rec : on first press, start to record a new sample in the selected slot. on second press, stop to record.
sampler start_rec : start to record a new sample in the selected slot.
sampler stop_rec : stop to record the new sample.
sampler abort_rec : abort the recording of the sample.
sampler loop : put the sample in loop, or change the size of the loop: 'sampler default loop on' or 'sampler default loop 50%'.
sampler pitched : lock or unlock the pitch of the sample on the current song.
sampler beatlock : lock or unlock the phase of the sample on the current song.
sampler options : popup the sample menu.
sampler select : select which sample is the default sampler slot for that deck. syntax 'sampler select 5' selects the fifth sampler slot. 'sampler select +1' scrolls through the sampler slots. 'sampler select' open a popup menu to select the new default sampler slot.
sampler load : load a new sample in the selected slot. 'sampler load "my_sample.vds"' loads a specified file. 'sampler load' open a selection window.
sampler save : save the current sample in a file. 'sampler save "my_sample.vds"' saves in a specified file. 'sampler_save' open a selection window.
sampler position : get the current position of the sample
geposted Mon 04 Apr 11 @ 4:50 am
Hallo erst mal,
danke für das schnelle Feedback!
Die Frage zielte eher in die Richtung der Belegung der RMX Button:
RMX 1 = Sampler a
RMX 2 = Sampler b
RMX 3 = Sampler c
RMX 4 = Effekt z
RMX 5 = Effekt y
RMX 6 = Effekt x
Deck 1 analog zu Deck 2
Gruß de Mario
RMX 1 = Sampler a
RMX 2 = Sampler b
RMX 3 = Sampler c
RMX 4 = Effekt z
RMX 5 = Effekt y
RMX 6 = Effekt x
Gruß de Mario
geposted Mon 04 Apr 11 @ 5:46 am
Wie schon geschriebe.
Die Buttons lassen sich frei belegen.
Wenn du das so haben willst wie von dir geschrieben, dann musst du halt die Buttons so mappen :)
geposted Mon 04 Apr 11 @ 6:11 am
hi wieso läst sich die mic on off taste den nicht programmieren ??? geht bei mir auch nicht brauche sie aber :(
geposted Thu 18 Jul 13 @ 7:47 am
mit welcher Version versuchst du es ?...mit der registrierten LE geht das nämlich nicht...;-)
Du kannst nur mit der Pro Full in das native Mapping von VDJ eingreifen.
geposted Thu 18 Jul 13 @ 7:50 am
wie meinst du das den ?? verstehe ich nicht ganz habe es bei meinem kolöegen mit pro full versucht aber da kann man sie auch nicht belegen dioe mic on off taste :(
geposted Fri 19 Jul 13 @ 8:51 am
der microphone button lässt sich auf so ziemlich jeden button legen..
auch auf jede taste deines Keyboards.
aber wie schon beschrieben, benötigst du die FULL PRO Version dafür.
wenn dein kumpel die hat, soll er doch mal als hier registrierter user nachfragen :)
wir helfen dann gern weiter :)
grüsse
grüsse
geposted Fri 19 Jul 13 @ 9:15 am
Wenn du das bei deinem Kollegen versuchst ist, kannst du es bei dir trotzdem nicht verwenden, da du mit einer LE registriert bist. LE = Limited = eingeschränkte Version. Dort ist die Mapping Option nicht freigeschaltet. Also kannst du auch nix Mappen...;-)
Auch darf dir dein Kollege seine Lizenz nicht überlassen, da es ein Verstoß gegen die EULA von Atomix ist.
Zum Testen kannst du dir aber die aktuelle Home Free laden. Diese läuft bei jedem Programmstart für 10 Minuten als Pro Full. Dort gelangst du über Config in das Mapping. Klicke bitte danach auf die Key Learn Funktion auf dem Screen klicken und dann die Mic Taste am Controller. Wenn dann im Anzeigefeld unter der Action Anzeige nichts erscheint sendet der Button wahrscheinlich überhaupt gar keinen Midibefehl...
Bitte dies mal Testen und dann kurze Rückmeldung....
BTW: Hast du dir dein RMX Control/ Bedienpanel auf der Windows Taskleiste mal etwas genauer angesehen..?
geposted Fri 19 Jul 13 @ 9:17 am
So wie das aussieht kannst du die Mic Taste doch nicht mappen, da die Talkover Funktion des Mic Buttons in dem Hercules Controlpanel implementiert ist. Zur Sicherheit aber bitte nochals o.g Vorgehensweise mit der Home Free testen.
Auch PachN hat hier in diesem Topic was entsprechendes gepostet, und soviel ich weiss hatte er mal ne RMX....
PachN wrote :
Natürlich. Du kannst jeden Button frei programmieren (naja fast, den Mic On/Off nicht).
geposted Fri 19 Jul 13 @ 9:48 am
