'glad to be of help to you. Enjoy!
Edq2000
Edq2000
geposted Thu 06 Sep 12 @ 9:55 pm
Does the mixdeck quad have Hi Res platters? I didn't see anything in the spec sheet...
geposted Fri 07 Sep 12 @ 9:33 am
I have been following this thread and I still can not get my Quad to work properly with videos. I installed the latest mapper version 2.1. All audio files and contols work great!!! The second I load a video on to one of the decks, I loose my pfl volumes for my channels that are controlling VDJ decks 1 & 2. Now the audio files are the same way. I can not pre listen through the headphones. The software has to be restarted, and everything is fine. (until I try loading a video). Does anyone know how to fix this?? Please, please help.
geposted Sun 09 Sep 12 @ 12:54 pm
Still looking for a solution yo the above post.
Sorry to post twice.
geposted Mon 10 Sep 12 @ 1:17 pm
Just got that lil' cutie, and I have nothing to complain about (well, for now!!!)... Once you guys get acquainted to it, you'll lately realize how fast it'd turned into an "octopus". Now, I'd like to know where the hek am I suppose to get the latest firmware for this jewlery. v' been on www.numark.com, but couldn't find it any where?
If anyone can please give me a push, I'm right there waiting for your assistance.
Thanks in advance.
Thanks in advance.
geposted Mon 10 Sep 12 @ 8:14 pm
Make sure you have Auto Headphones set to Disabled on the Config -> Options tab.
geposted Mon 10 Sep 12 @ 8:19 pm
That did not work. The only way I can hear a PFL volume is on when a channel slider is up, and cross fader on that channel. Any other ideas??
geposted Wed 12 Sep 12 @ 9:54 pm
Hello.
Is there a way to make the Eject button to swap the decks see what deck your on because the way it is now,
I can not tell if I'm on deck 1, 2, 3, or 4 there is no number lights OR anything to tell me the deck number on the skin?
geposted Thu 13 Sep 12 @ 10:12 am
I think it shows the deck number in the LCD Screen on the Mixdeck.
Anyway, I have another problem: I used the mixdeck quad last weekend and at first everything went smooth. However after a few hours of playing it started to become weird.
First I noticed that one of the midi decks died. Pressing any button didn't do anything. I couldn't get it to work anymore so I started to use automix in vdj, which still worked on deck 1. Additionally the preview (or cue) buttons für the headphone didn't work anymore either. So I startet flipping switches around (especially the prg/cue switch on the back) which gave me some weird situations. Sometimes I could hear the master sound on the headphones, then nothing at all and so on.
I then used my cell phone to play some music and restarted the mixdeck. That however didn't help. So I rebooted the laptop. Afterwards it worked again but after a few songs everything seemed to hang again. I'm not quite sure what actually happens there.
I'm using the latest mapper by cstoll (2.1) and the 3-1-2-4 version of it.
Is that mixdeck broken? Or is this a software issue? It's difficult to reproduce this error as I haven't found anything that causes it. It just happens after a while.
geposted Mon 17 Sep 12 @ 7:07 am
I found something that might be a problem:
I use a little fogging machine during my gigs. And every now and then, when I activate it for a couple of seconds it seems the mixdeck goes nuts and hangs like I described above. I don't have any problems with any other equipment and it doesn't seem like I overloaded the power oline at all...
Is it possible, that the mixdeck has some trouble with the high power conssumption in short bursts? It's only a 400w fogger though.
Any ideas on how I get around that problem? I usually do not have a seperate power plug for lighting and fogging.
geposted Thu 04 Oct 12 @ 3:16 am
where do I find the latest version? I can only find what looks to be the 1.0 1-2-3-4 version.
geposted Wed 17 Oct 12 @ 7:55 pm
hey guys im looking into purchasing the numark mixdeck quad and also purchasing the VDJ pro will the mixdeck work fully midi mixer and run video mixing as well? and do i need to download another file or will the current VDJ work with my new mix deck quad thanks!
geposted Wed 24 Oct 12 @ 11:52 pm
cstoll wrote :
First, that Video was done a year ago, by Numark and without any input from VirtualDJ. They didn't even release the unit until just a couple months ago. And on top of that, they decided not to release it with VirtualDJ LE and therefore did not include us in the development process.
So, what does that leave us with. It leaves us with a hardware unit that only has 2 audio channels on the sound card - hence, 1 out for left side and 1 out for right side. If we would have been involved from the beginning - I would have insisted that they re-tract and market the VirtualDJ support correctly OR improve the hardware to support the before mentioned marketing.
As to 'making it 4 decks' - you could still make it 4 decks in 'control' but not in 4 decks of dedicated audio output. Basically, Decks 1 and 3 would output to USB1 and Decks 2 & 4 would output to USB2. It is not the ideal and requires the DJ to be very attentive to what they are doing - but it can be done.
Well considering you don't get an LE when buying this controller and you don't have a PRO license, then your options are still open to purchasing a product that truly supports 4 decks of mixing. There are plenty of options on the market.
No. And Licensed PRO users can download it from the link provided earlier.
vhr32 wrote :
How come when this unit was first released, it came out with full 4 deck VDJ software according to this video?
http://www.youtube.com/watch?v=HL1tTgcVPwk
That means you must have got a sample unit ages ago?!
I'm confused, you only made it support 2 decks but then you say you can do 4 decks??
vhr32 wrote :
I just want 4 deck MIDI controller like it is advertised to be with the option of using the other sources if I need to.
dexempo wrote :
Hi Chris, can you please send me the mail ****@***** mapping Numark Mixdeck Quad?
I have just purchaced the VDJ PRO and I am not able to acess links?
geposted Thu 25 Oct 12 @ 8:19 pm
The download link is no-longer available any more because the MixDeck Quad is now natively supported and built into the latest versions of VirtualDJ Pro: http://www.virtualdj.com/wiki/VirtualDJ%20Controllers.html
Please ensure that you have the latest v7.2 Pro installed: http://www.virtualdj.com/download/updates.html
geposted Fri 26 Oct 12 @ 4:07 am
Hey for some reason I am unable to download the Mixdeck quad mapping. Can someone please send it to my email: *****@****
[Sorry, E-mail addresses and other contact details are not permitted for unlicensed users - Please read the forum rules]
geposted Tue 30 Oct 12 @ 6:31 am
Mapper downloads are only available to registered licensed users who have purchased and registered the full VirtualDJ Professional. The MixDeck Quad is also natively supported in the latest VirtualDJ v7.2 Pro so installing a separate mapper is no-longer required.
Please register your Pro serial number on your profile page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it.)
geposted Tue 30 Oct 12 @ 8:18 am
THANK YOU
i got everything workin but i can not get my cue buttons to work correctly currently i use auto headphones so that the track cues on load but i can not switch back and forth useing the cue buttons on the controller
any suggestions ?
geposted Sun 04 Nov 12 @ 9:26 pm
On 4 deck controllers, the PFL (CUE) buttons are normally toggles, allowing you to toggle on and pre-listen to more than one deck at once. Press the mixer PFL buttons to toggle on the decks that you wish to pre-listen to. Make sure that the MixDeck is also configured correctly: http://www.virtualdj.com/wiki/MixDeck%20Quad.html
If you wish to change this behaviour, you will need to change the mapping of each PFL button to select: Edit the mapping for each PFL button and replace the word pfl with select - This will then change the selected deck in VirtualDJ, but will only allow pre-listening to one at a time.
See http://www.virtualdj.com/wiki/How%20do%20I%20change%20the%20mapping%20for%20a%20button.html
geposted Mon 05 Nov 12 @ 10:13 am
jbart19 wrote :
CDs might be lame but have you ever tried to navigate an external drive with several GB's of songs on the small LCD's on something like this? it is a real pita. CD back up is more reliable and professional looking than relying on an Ipod if your computer goes out mid-gig. Using the mixdeck the change over is seamless and your client might not even notice the laptop went down. Sure you don't have ALL your music but with a couple hundred mix CDs and a printed index you can still cover a lot of genre's and find things pretty quick. That is the real advantage of the Mixdeck over other midi only controllers. If you don't want to have the CD option there are plenty of other 4 deck controllers out there.
The usb inputs are nice for flash drives with a playlist or maybe up to 100 songs or so but anything more than that gets to be quite tedious. I usually use mine for backup of the must haves the client has asked for in a single folder with printed reference list in the order they are in the folder or a backup playlist with up to 100 or so songs that would be appropriate for the event but the printed list really comes in handy when trying to navigate to a song those LCDs just are tough to see and navigate with. Would be nice of Numark would take gemini's lead and angle the LCDs towards the user instead of making them flush to the surface.
And in the unthinkable event your computer goes all to hell you can even book events using your CD backups to earn cash to replace the laptop :)
+1
geposted Sat 29 Dec 12 @ 1:41 pm
HELP,,,,,,,,,,,,,just got the the quad mixdeck and its hooked up to lap top and using the usb sound card (read this online a a help tip). Problem is the headphones ar so LOW in sound. Its low and thats just messing around with it in the home but doing a party and system pumping dont think I will hear anything . First party is this saturday and going to use the new system if I can get headphones to work. Anything you can tell me to correct problem and sorry I dont know mapping and computer configures stuff so please be specific ,,,,,THANK YOU
geposted Mon 18 Feb 13 @ 11:46 am
