For the users that want to use the plugins that give an error message upon trying to install please contact us here: help@virtualdj.com and title the subject NEED 702.
For the time being this is a work around. Download and install VirtualDJ ver 7.02 at a different folder than the default (for example \VirtualDJ702 instead of \VirtualDJ) This just installs the proper keys to validate the package. After that you will have 2 icons on your desktop. VirtualDJ Pro Full (this is 7.03) and VirtualDJ Pro (7.02). So now you can use those addons with 703.
In case you don't need to run version 7.02 you may delete that icon.
geposted Fri 08 Apr 11 @ 12:43 pm
I have this same problem and can't fix it.
geposted Mon 11 Apr 11 @ 5:16 pm
In case you have purchased a valid license please register your software here http://www.virtualdj.com/users/edit.html and raise a ticket to receive the above solution.
If you use the Home Free Version http://www.virtualdj.com/download/free.html then as a No License User you can not download and install any add ons.
geposted Mon 11 Apr 11 @ 10:18 pm
