Hello,
We just released a new version (version 7.0.4).
This is mainly a maintenance build, that only fixes a few small bugs, and add support for new controllers.
You can see the complete list of changes here:
http://www.virtualdj.com/wiki/VirtualDJ%20History.html
And you can download the new version from your Download Center.
geposted Thu 05 May 11 @ 11:31 am
Thank you boss!!!
Can certainly use the pitch range match addition when clicking sync and one song is out of the range (I think I read that right).
geposted Thu 05 May 11 @ 11:58 am
Any Support For DDJ-S1/T1? With This Upadte?
geposted Thu 05 May 11 @ 1:27 pm
Thanks..... I wish it had an upgrade of the internal eq.....
geposted Thu 05 May 11 @ 1:45 pm
Gracias Atomix for the update..
Downloading now..
Downloading now..
geposted Thu 05 May 11 @ 1:54 pm
Hopefully this update works better with NS7 DJ Earl at www.musicallyyoursdj.com
geposted Thu 05 May 11 @ 2:33 pm
Thanx to VDJ TEAM,just tried the new update for 6 hours,and everything is ok.
But still gonna keep asking you,to finish my nightmare with fadetobalck on volume sliders
it´s really very important to implement something like deck´s video fader,so it cannot affect the deck´s volume when using the wonderfull FADE TO BLACK.
geposted Thu 05 May 11 @ 3:42 pm
While the update fixes some minor bugs and offers hardware support for some newer devices, the Pioneer DDJ-S1/T1 are yet to be supported. Please be patient as we are working on it.
geposted Thu 05 May 11 @ 5:32 pm
Awesome! Thanks guys!
DJ RuDe
DJ RuDe
geposted Thu 05 May 11 @ 6:17 pm
Thx for the CUE deleting crashes fix. Right in time form the weddings season!!!!!
geposted Thu 05 May 11 @ 9:05 pm
Hope this sorts out my crash for cdj850's when switching from pc to usb or cd, will give it a try.
Thanks for the updates :)
geposted Fri 06 May 11 @ 12:25 am
Yea, just in time for the weekend. Time to put it to the test. Thanks Team!
geposted Fri 06 May 11 @ 3:17 am
yes, this has been fixed.
geposted Fri 06 May 11 @ 5:47 am
Any major changes or corrections made for Mac?
geposted Fri 06 May 11 @ 8:31 am
thanks
geposted Fri 06 May 11 @ 10:32 am
Thanks!
geposted Fri 06 May 11 @ 12:55 pm
@tookept
MAC: fixed changing latency settings
geposted Fri 06 May 11 @ 3:03 pm
Thank You for the new update!
geposted Fri 06 May 11 @ 4:16 pm
Thanks Again!!
geposted Fri 06 May 11 @ 8:21 pm
There is a problem with the MAC version, I've got an error message when trying to install
regards
regards
geposted Fri 06 May 11 @ 10:40 pm
