Hello,
I'm proud to announce we have a Radio Player for Android on the Market.
The official launch date is next 1st June.
But it's available from now.
So this announce comes 2 days early only for you: the forum members.
https://market.android.com/details?id=com.pdnmusic.vdjradio
Regards!
Regards!
geposted Mon 30 May 11 @ 11:20 am
Stream doesnt load on my samsung galaxy 550 :(
geposted Wed 01 Jun 11 @ 3:58 pm
It works best if you stream on a higher banwidth like wifi or 4g/LTE..
This is perfect. I've been waiting for a true streaming for a while. Great job developers!
geposted Wed 01 Jun 11 @ 4:41 pm
You can try:
MENU > Preferences > Stream Performance
And choose "Optional".
Hope this helps.
Regards!
geposted Thu 02 Jun 11 @ 2:30 am
downloaded, played with, force closes, crashes, and pretty much useless unless you have wifi connection handy... but can listen easily through winamp app for droid playing vdj radio stations with 3g or 4g. go figure.
and the ads are kinda annoying too, but oh well...
geposted Fri 03 Jun 11 @ 5:14 am
Can you try this?
Still crashes?
Device model? Android OS Version?
geposted Fri 03 Jun 11 @ 5:46 am
EVO 4G android 2.2
setting for "optional" for lower performance kinda defeats the purpose of listening?
geposted Fri 03 Jun 11 @ 7:56 am
EVO 4G android 2.2
DEFAULT: Plays directly in PLS format.
OPTIONAL: Decodes in MP3 format.
Like the radio flash player.
It don't uses a URL with ports, so its the option to use behind firewall.
During my tests I got some sound 'clicks' and skips => 'lower performance'
It worked for you the "optional" way?
geposted Fri 03 Jun 11 @ 1:36 pm
pdnmusic wrote :
You can try:
Hope this helps.
Regards!
You can try:
Hope this helps.
Regards!
Yup works now thanks :),
you should also post in on the radio forums
geposted Fri 03 Jun 11 @ 8:35 pm
pdnmusic wrote :
You can try:
Hope this helps.
Regards!
You can try:
Hope this helps.
Regards!
Will do, also will be on the FAQ and help of the APP
geposted Sat 04 Jun 11 @ 3:09 pm
APP updated on the Market (v.1.6.1)
Regards!
Regards!
geposted Fri 01 Jul 11 @ 5:13 am
APP updated on the Market (v.1.6.3)
Fixed some bugs
Regards!
Fixed some bugs
Regards!
geposted Wed 20 Jul 11 @ 8:31 am
NEW VERSION
v.1.9.1
★ (BETA) Status Bar Notification.
★ (BETA) Advert Free Usage Program:
Temporarily free of advertisement depending on usage.
★ Updated some language translations.
★ Default Stream Performance mode is now "Optional".
(Solve some devices play hang).
★ Bug fixes.
v.1.9.1
★ Bug fixes.
geposted Mon 16 Jan 12 @ 1:49 pm
