Had my first 5 hour set last night using Lion, not a single problem!!
geposted Sun 31 Jul 11 @ 8:28 am
where is download cache on mac lion can anyone help...Please
geposted Wed 03 Aug 11 @ 12:23 pm
If you mean the NetSearch cache, then this will be in either /users/YOURNAME/Documents/VirtualDJ/Cache or for new installations of VirtualDJ v7.0.3 or later, /users/YOURNAME/Library/VirtualDJ/Cache
geposted Wed 03 Aug 11 @ 1:32 pm
Well, I am officially starting to use OS X Lion with Virtual DJ 7.0.4 now on live gigs. CoreAudio is still buggy when using more than one sound card. Example: I have to every now and then klick on Audi MIDI set up to select Sample 4100.0 HZ and 2ch-16bit Integer for both built-In and built-Out Internal sound card to work with my two Denon DN-S1200s. When the sample rates chosen for more than one soon card It crashes and will not work.
At this point videos runs a lot smoother than compared to Snow-leopard as I previously reported otherwise. In Lion I am confident now to use video mixing during live show using my second generation Macbook.
I still have a copy of Snow-Leopard installed for apps and things which are not yet compatible with Lion.
geposted Thu 04 Aug 11 @ 8:26 pm
Anyone else finding that they are getting digital clipping when loading a track with mac osx lion?
I'm using a macbook air 1.86ghz core duo, 2gb RAM and i never had issues with Snow Leopard but this is now happening on a regular basis. i have did all my spring cleaning on the mac and it's spotless and i'm running no other apps at the same time but this clipping is driving me insane!
Spoke to the Genius bar and they had no clue whatsoever. Will Atomix be releasing a Lion optimised version? i know VDJ is not a heavy programme but it's eating up 30% of the CPU whilst idling and that could not be correct.
Anyone else have the same issue??
geposted Mon 08 Aug 11 @ 11:51 am
How about registering your product and updating your software, i bet that may help.
geposted Mon 08 Aug 11 @ 11:02 pm
I am reporting back that I have been seeing great improvements In video loading time using Lion and Virtual DJ Pro 7.0.5 on the Mac side. Lion seems to be less power hungry.
CoreAudio Is still a bit buggy, but Lion is official for me now at my live gigs.
geposted Thu 11 Aug 11 @ 10:37 am
I just got a new macbook pro, every time I try to open VDJ it says invalid skin file error %i and I have no idea whats going on with it. I am running on Lion now, but when I first got my new macbook pro it wouldn't work in snow leopard. I tried downloading the program multiple times and it still has the same problem I've also erased all the skins I've downloaded. If anyone has any suggestions as to what to do just let me know and that would be helpful.
geposted Sat 13 Aug 11 @ 7:18 pm
Hello, I have problems with Virtual DJ too after updating to Mac OS X Lion. It is crashing before it launches. It displays a problem info window stating the following. Please help.
Process: VirtualDJ Home [521]
Path: /Applications/VirtualDJ Home.app/Contents/MacOS/VirtualDJ Home
Identifier: com.atomixproductions.virtualdjhome
Version: 7.0.4 (7.0.4)
App Item ID: 417934534
App External ID: 3694617
Code Type: X86 (Native)
Parent Process: launchd [195]
Date/Time: 2011-08-14 03:05:16.707 -0500
OS Version: Mac OS X 10.7 (11A511)
Report Version: 9
Interval Since Last Report: 31292 sec
Crashes Since Last Report: 5
Per-App Interval Since Last Report: 32 sec
Per-App Crashes Since Last Report: 5
Anonymous UUID: ED7AE89F-42AD-401B-9CE6-27CE9DBF21EA
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
VM Regions Near 0:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/VirtualDJ Home.app/Contents/MacOS/VirtualDJ Home
__TEXT 0000000000001000-0000000000917000 [ 9304K] r-x/rwx SM=COW /Applications/VirtualDJ Home.app/Contents/MacOS/VirtualDJ Home
Application Specific Information:
objc[521]: garbage collection is OFF
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_c.dylib 0x95a9cd50 strlen + 16
1 com.atomixproductions.virtualdjhome 0x000a7274 CForm::Resize() + 940
2 com.atomixproductions.virtualdjhome 0x000a7d1d CForm::ShowPage(int, bool) + 527
3 com.atomixproductions.virtualdjhome 0x000a7e6c CForm::ChangePage(int) + 86
4 com.atomixproductions.virtualdjhome 0x00100921 CScreen::InitSkin() + 1169
5 com.atomixproductions.virtualdjhome 0x000b95cf CMain::OnCreate(void*) + 813
6 com.atomixproductions.virtualdjhome 0x000b9a1b CMain::WndProc(void*, unsigned int, long, long) + 581
7 com.atomixproductions.virtualdjhome 0x00139374 main + 777
8 com.atomixproductions.virtualdjhome 0x00024cfa start + 54
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x9c66f90a kevent + 10
1 libdispatch.dylib 0x93cceccc _dispatch_mgr_invoke + 969
2 libdispatch.dylib 0x93ccd71b _dispatch_mgr_thread + 53
Thread 2:
0 libsystem_kernel.dylib 0x9c66f02e __workq_kernreturn + 10
1 libsystem_c.dylib 0x95a47ccf _pthread_wqthread + 773
2 libsystem_c.dylib 0x95a496fe start_wqthread + 30
Thread 3:
Thread 4:
0 libsystem_kernel.dylib 0x9c66e83e __psynch_cvwait + 10
1 libsystem_c.dylib 0x95a49e78 _pthread_cond_wait + 914
2 libsystem_c.dylib 0x95a49f7b pthread_cond_timedwait_relative_np + 47
3 com.apple.CoreServices.CarbonCore 0x95b928fb TSWaitOnConditionTimedRelative + 178
4 com.apple.CoreServices.CarbonCore 0x95b92671 TSWaitOnSemaphoreCommon + 490
5 com.apple.CoreServices.CarbonCore 0x95b92482 TSWaitOnSemaphoreRelative + 24
6 com.apple.QuickTimeComponents.component 0x98f8c46e 0x989a0000 + 6210670
7 libsystem_c.dylib 0x95a45ed9 _pthread_start + 335
8 libsystem_c.dylib 0x95a496de thread_start + 34
Thread 5:
6 com.apple.CoreServices.CarbonCore 0x95bc5387 AIOFileThread(void*) + 1019
Thread 6:
Thread 7:
4 com.apple.CoreServices.CarbonCore 0x95bf40d2 MPWaitForEvent + 296
5 com.atomixproductions.virtualdjhome 0x00122525 IThread::ThreadProc() + 61
6 com.atomixproductions.virtualdjhome 0x00122576 StaticThreadProc(void*) + 17
7 com.apple.CoreServices.CarbonCore 0x95bf5988 PrivateMPEntryPoint + 68
8 libsystem_c.dylib 0x95a45ed9 _pthread_start + 335
9 libsystem_c.dylib 0x95a496de thread_start + 34
Thread 8:
Thread 9:: com.apple.NSURLConnectionLoader
0 libsystem_kernel.dylib 0x9c66cc22 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x9c66c1f6 mach_msg + 70
2 com.apple.CoreFoundation 0x9345e9ea __CFRunLoopServiceMachPort + 170
3 com.apple.CoreFoundation 0x93467b14 __CFRunLoopRun + 1428
4 com.apple.CoreFoundation 0x934671ec CFRunLoopRunSpecific + 332
5 com.apple.CoreFoundation 0x93467098 CFRunLoopRunInMode + 120
6 com.apple.Foundation 0x90eb088c +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 378
7 com.apple.Foundation 0x90ea45ed -[NSThread main] + 45
8 com.apple.Foundation 0x90ea459d __NSThread__main__ + 1582
9 libsystem_c.dylib 0x95a45ed9 _pthread_start + 335
10 libsystem_c.dylib 0x95a496de thread_start + 34
Thread 10:: com.apple.audio.IOThread.client
2 com.apple.audio.CoreAudio 0x9b2ce0dc HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, unsigned int) + 114
3 com.apple.audio.CoreAudio 0x9b2c652a HALC_ProxyIOContext::IOWorkLoop() + 1134
4 com.apple.audio.CoreAudio 0x9b2c5ffc HALC_ProxyIOContext::IOThreadEntry(void*) + 136
5 com.apple.audio.CoreAudio 0x9b2c5f6e __HALC_ProxyIOContext_block_invoke_6 + 20
6 com.apple.audio.CoreAudio 0x9b2c5ef3 HALB_IOThread::Entry(void*) + 69
Thread 11:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0xffffffff ebx: 0x00000000 ecx: 0x00000000 edx: 0x00000000
edi: 0x0000007e esi: 0x00be3f60 ebp: 0xbffff938 esp: 0xbffff87c
ss: 0x00000023 efl: 0x00010286 eip: 0x95a9cd50 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x00000000
Logical CPU: 0
Binary Images:
0x1000 - 0x916ffb +com.atomixproductions.virtualdjhome (7.0.4 - 7.0.4) <2587480F-0149-299B-BC3B-9F367EE0BD43> /Applications/VirtualDJ Home.app/Contents/MacOS/VirtualDJ Home
0x1307000 - 0x13b4ff7 libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <7B6DB792-C9E5-3772-8734-8D0052757B8C> /usr/lib/libcrypto.0.9.7.dylib
0x13f9000 - 0x1445ffb com.apple.audio.midi.CoreMIDI (1.8 - 42) <CBD34EBC-0FFD-34B4-B55A-BE1F61EF4BD8> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x2f45000 - 0x2f4affb com.apple.AppleMPEG2Codec (1.0.2 - 220.1) <F3A640A6-52E4-3BE9-86A6-235A0ACD45C3> /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
0x2f95000 - 0x2fceff3 com.apple.QuickTimeFireWireDV.component (7.7.1 - 2246) <539384F7-C119-3CC9-B74B-4D958836A955> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x2fd9000 - 0x2ff1ff2 com.apple.applepixletvideo (1.2.25 - 1.2d25) <7626C28C-478D-33ED-88D6-03DCE4F8728F> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x2ff6000 - 0x2ff7ffc ATSHI.dylib (??? - ???) <B244624E-E09E-34B2-A185-EB30AF08A95D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x4789000 - 0x47aafe7 com.apple.AppleIntermediateCodec (2.0 - 542.4) <C71EE6F3-7B4D-38DA-B3D9-65B0AD4CE313> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0x6158000 - 0x615cffb com.apple.audio.AudioIPCPlugIn (1.2.0 - 1.2.0) <8A4CC918-D47D-3F33-8420-0698071A5944> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0xa011000 - 0xa077fff com.apple.AppleProResDecoder (3.0 - 542.6) <ABCA83B4-EBDA-3851-95F1-03ED201EBFDD> /System/Library/QuickTime/AppleProResDecoder.component/Contents/MacOS/AppleProResDecoder
0xa0a8000 - 0xa0e7ff7 com.apple.AppleVAH264HW.component (3.0 - 3.0) <E18BFDC5-80C8-3B30-A3DF-1C87A659BFDC> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
0xbbb3000 - 0xbbb9ffb com.apple.audio.AppleHDAHALPlugIn (2.1.1 - 2.1.1f11) <8CA3DFAA-56F6-37B1-9C93-16C5C3A0A00F> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x70000000 - 0x70140ffb com.apple.audio.units.Components (1.7 - 1.7) <749EDF0F-BFBD-37A7-845E-3048BAF35D89> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe88000 - 0x8feba9c7 dyld (195.5 - ???) <134323A7-49DC-3A9D-ACFD-32FAD0FD6BA2> /usr/lib/dyld
0x90640000 - 0x90769ff9 com.apple.CFNetwork (520.0.13 - 520.0.13) <B21DE9ED-1D99-39C0-9E24-77D2A48FBFEF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x907ca000 - 0x907cdff9 libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <B9344DE6-B84D-352C-95AD-EF73A68B8A10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x907ce000 - 0x9088bff3 ColorSyncDeprecated.dylib (4.6.0 - compatibility 1.0.0) <30A67F4F-80BC-39AD-9BB3-23FB8E3174FC> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x9088c000 - 0x90b11fe3 com.apple.QuickTime (7.7.1 - 2246) <56DF434A-D929-350C-86D5-684089D0EDFB> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x90b85000 - 0x90bd4ffb com.apple.AppleVAFramework (5.0.14 - 5.0.14) <51981B76-9A78-39D7-8709-7686BD2057C8> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x90bd5000 - 0x90bf2ff3 com.apple.openscripting (1.3.3 - ???) <31A51238-0CA1-38C7-9F0E-8A6676EE3241> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x90bf3000 - 0x90c15ffe com.apple.framework.familycontrols (3.0 - 300) <AE51B604-D32D-32F7-AEDC-B1C4EB7191C6> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x90c1c000 - 0x90c4afe7 libSystem.B.dylib (159.0.0 - compatibility 1.0.0) <FA9B75F7-B989-3DD3-97FD-373EB95C5BA8> /usr/lib/libSystem.B.dylib
0x90c6c000 - 0x90d3bffb com.apple.ImageIO.framework (3.1.0 - 3.1.0) <A482C10A-C474-39DC-AB3C-EADBCF3A433B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x90df3000 - 0x90e31fff libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <0AE59D4F-FFA7-3539-8B86-AD8993894AA0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x90e3e000 - 0x90e40ff9 com.apple.securityhi (4.0 - 1) <BD367302-73C3-32F4-8080-E389AE89E434> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x90e45000 - 0x91148ff7 com.apple.Foundation (6.7 - 833.1) <94BFFEDD-0676-368D-B4C6-8784E1DA4306> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x91149000 - 0x91154ffb com.apple.speech.recognition.framework (4.0.19 - 4.0.19) <17C11291-5B27-3BE2-8614-7A806745EE8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x91155000 - 0x9116ffff com.apple.Kerberos (1.0 - 1) <25E5A286-876D-3A8E-A12F-52D184559E8C> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x91170000 - 0x91bf5ffe com.apple.AppKit (6.7 - 1138) <1CEDE402-32DD-3C10-B3B3-8C3DDBE8335D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x91bf6000 - 0x91c80ffb com.apple.SearchKit (1.4.0 - 1.4.0) <C8567435-9CD1-35EE-AE05-304D28858C42> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x91c81000 - 0x91c9afff libPng.dylib (??? - ???) <2C47E152-240A-36A7-87A8-3856EDFF2FE8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91c9b000 - 0x91cabfff com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91dac000 - 0x91dbfff9 com.apple.MultitouchSupport.framework (220.62 - 220.62) <5BD8730D-43A4-3040-9EA3-0BDA52A392A9> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x91dc0000 - 0x91e3bffb com.apple.ApplicationServices.ATS (5.0 - ???) <8DF22F1E-7600-3ADA-BFC1-F6FA79914171> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x91e3c000 - 0x91efcfff com.apple.CoreServices.OSServices (478.25 - 478.25) <13EB75E5-98E5-3C3D-A2D7-CD6CB292C227> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x91efd000 - 0x91f13ffe libxpc.dylib (77.16.0 - compatibility 1.0.0) <2EAF3E13-19FA-3EF2-88D6-64ACBC3A6ADB> /usr/lib/system/libxpc.dylib
0x91f14000 - 0x91f78fff com.apple.framework.IOKit (2.0 - ???) <B5888D02-8C36-3404-A37E-7457D950D629> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x921fe000 - 0x92600ff6 libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92601000 - 0x926d7a5b libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <A0EDB351-4B9D-3AA2-9D1A-0C22204FCCD3> /usr/lib/libobjc.A.dylib
0x92741000 - 0x92742fff liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
0x92743000 - 0x9274cfff libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
0x92c4f000 - 0x92cb9ff3 com.apple.CoreSymbolication (2.1 - 66) <B11C9057-1611-36A5-81F6-2C97A7047321> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x92ce6000 - 0x92d5bfff com.apple.Metadata (10.7.0 - 627.9) <1EF7D615-3DF4-3F5D-88CE-6BDFA120FE32> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x92d5c000 - 0x930b8fff com.apple.MediaToolbox (1.0 - 705.35) <425BD613-CB66-3BE1-8DDC-1B59561A1F5F> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x93157000 - 0x932a9ffb com.apple.audio.toolbox.AudioToolbox (1.7 - 1.7) <5767C518-343D-36DB-8D59-C72986161AEC> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x932aa000 - 0x932aefff libGIF.dylib (??? - ???) <F6094267-AB0E-38FC-8201-510AA4BDC974> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x932af000 - 0x932d8ffe com.apple.opencl (1.50.62 - 1.50.62) <52059AB5-8E0D-356E-98AA-71A4777CBE57> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x932d9000 - 0x93399ff3 com.apple.ColorSync (4.7.0 - 4.7.0) <50767823-56BA-373D-BC5A-37B17B659838> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x933ef000 - 0x9342bfff libcups.2.dylib (2.9.0 - compatibility 2.0.0) <8CB51735-ABE4-37AD-9019-845BB768955F> /usr/lib/libcups.2.dylib
0x9342c000 - 0x93602fef com.apple.CoreFoundation (6.7 - 635) <4EE0D62E-5342-3A9F-A740-DA1D5AEBB1B0> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x93603000 - 0x93603fff libdnsinfo.dylib (395.6.0 - compatibility 1.0.0) <959E5139-EB23-3529-8881-2BCB5724D1A9> /usr/lib/system/libdnsinfo.dylib
0x93642000 - 0x936ddff3 com.apple.ink.framework (1.3.2 - 110) <9F6F37F9-999E-30C5-93D0-E48D4B5E20CD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x936de000 - 0x93a1dff3 com.apple.HIToolbox (1.7 - ???) <A9583F07-218D-35CD-B29C-C65E6D008836> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93a1e000 - 0x93a52ff3 libTrueTypeScaler.dylib (??? - ???) <FF162272-243C-321C-B152-AD81B3171C54> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x93a53000 - 0x93a6fff5 com.apple.GenerationalStorage (1.0 - 124) <0BC29510-6C26-3445-88B7-21502CAFF372> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x93a70000 - 0x93b07ff3 com.apple.securityfoundation (5.0 - 55005) <F5A98CC2-11C6-34F3-8F72-75B642627630> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x93b08000 - 0x93b13ffe libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <4A7FCD28-9C09-3120-980A-BDF6EDFAAC62> /usr/lib/libbz2.1.0.dylib
0x93b14000 - 0x93b1eff2 com.apple.audio.SoundManager (3.9.4 - 3.9.4) <D23C4761-6492-3974-B4D2-495082B8B7A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x93b33000 - 0x93b3eff3 libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <11726E50-E6FC-3AB0-8750-DDDCCF2B8534> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x93b3f000 - 0x93b5cfff libresolv.9.dylib (46.0.0 - compatibility 1.0.0) <95AE43ED-6C52-3B39-89B6-54C81C62F1FF> /usr/lib/libresolv.9.dylib
0x93b6f000 - 0x93b87ff7 libexpat.1.dylib (7.2.0 - compatibility 7.0.0) <C7003CC0-28CA-3E04-9B9E-0A15138ED726> /usr/lib/libexpat.1.dylib
0x93b88000 - 0x93bd1ff7 libGLU.dylib (??? - ???) <3524C956-C8B2-3E8B-805D-9E25E5481A58> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x93bd2000 - 0x93bdffff libGL.dylib (??? - ???) <C1C549FC-FF7F-3012-9DF5-5255217B4AEA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x93be0000 - 0x93c96ff3 com.apple.QuickTimeMPEG4.component (7.7.1 - 2246) <9291D1DB-48AE-37BC-82C3-0C241ED8C1BD> /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
0x93ccc000 - 0x93cdafff libdispatch.dylib (187.5.0 - compatibility 1.0.0) <1883C8E2-D180-3EA0-8BEF-325F2FEDACD1> /usr/lib/system/libdispatch.dylib
0x93f44000 - 0x93fa1ffb com.apple.htmlrendering (76 - 1.1.4) <743C2943-40BC-36FB-A45C-3421A394F081> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x93fa2000 - 0x93fa3ffd libCVMSPluginSupport.dylib (??? - ???) <8057030D-B290-3A8B-9828-3A1BD123B124> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x93fa4000 - 0x94020fff libType1Scaler.dylib (??? - ???) <DFBB3B4F-31F4-3ED0-B57C-713493CA2756> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x94021000 - 0x94022fff com.apple.TrustEvaluationAgent (2.0 - 1) <EABDA7EE-A98F-35B8-9E3E-7075BA651C68> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x94023000 - 0x944ffff6 libBLAS.dylib (??? - ???) <327C1517-2B63-3D8C-8D8E-CB4EBA2A9C36> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9450c000 - 0x9450cfff com.apple.Accelerate (1.7 - Accelerate 1.7) <881C1C85-2DEC-38DE-BC97-7804BC907282> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9450d000 - 0x94510ff7 libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
0x94511000 - 0x94515fff com.apple.CommonPanels (1.2.5 - 94) <3A988595-DE53-34ED-9367-C9A737E2AF38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x94516000 - 0x9462aff3 com.apple.QuickTimeImporters.component (7.7.1 - 2246) <AB6ABF7E-22FD-3EEF-A9A4-55EC16092D15> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x948f3000 - 0x949feffb com.apple.DesktopServices (1.6.0 - 1.6.0) <66E2BD3A-958A-3F46-8DA0-C0F2358013B0> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x949ff000 - 0x94a61ffb com.apple.datadetectorscore (3.0 - 179.3) <18117942-9D6F-3283-B8B0-03C7550CA2EB> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x94b25000 - 0x94bc9fff com.apple.QD (3.12 - ???) <68CBE425-43BA-3E6D-8668-A4A67396E20D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x94bd5000 - 0x94bf7ff1 com.apple.PerformanceAnalysis (1.10 - 10) <45B10D4C-9B3B-37A6-982D-687A6F9EEA28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x94bf8000 - 0x94bf9ff0 libunc.dylib (24.0.0 - compatibility 1.0.0) <BCD277D0-4271-3E96-A4A2-85669DBEE2E2> /usr/lib/system/libunc.dylib
0x94bfa000 - 0x94c5cff3 libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
0x94c62000 - 0x94c69ffd com.apple.NetFS (4.0 - 4.0) <D0D59145-D211-3E7C-9062-35A2833FA99B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x94cae000 - 0x94cb0ffb libRadiance.dylib (??? - ???) <5112B7CE-BAAF-3E98-94E4-676BCB92867F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x94d34000 - 0x94d38ffd IOSurface (??? - ???) <97E875C2-9F1A-3FBA-B80C-594892A02621> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x94d3c000 - 0x94d4afff libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
0x94d4d000 - 0x94d62fff com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x94e14000 - 0x94f25ff7 libJP2.dylib (??? - ???) <E938C201-C508-3E3D-B9A9-81FE52349E1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x94f4f000 - 0x95037fff libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <ED3F5E83-8C76-3D46-B2FF-0D5BDF8970C5> /usr/lib/libxml2.2.dylib
0x95362000 - 0x953c9fff libc++.1.dylib (19.0.0 - compatibility 1.0.0) <3AFF3CE8-14AE-300F-8F63-8B7FB9D4DA96> /usr/lib/libc++.1.dylib
0x953ca000 - 0x95422fff com.apple.HIServices (1.9 - ???) <058E00E0-F1B4-395F-813E-C49C0C5F3BA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x954de000 - 0x954defff com.apple.Carbon (153 - 153) <6FF98F0F-2CDE-3888-A304-4ED447D24CE3> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x954df000 - 0x955d7ff7 libFontParser.dylib (??? - ???) <C428D41A-8635-3423-A2F0-8BA9819F212B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x957f7000 - 0x9580cff7 com.apple.ImageCapture (7.0 - 7.0) <116BC0CA-428E-396F-85DF-52793034D2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x9580d000 - 0x95812ffd libGFXShared.dylib (??? - ???) <7C55BE22-CDB5-3192-B7F0-96EA754A20AC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x95860000 - 0x958ecff7 com.apple.CoreText (4.0.0 - ???) <2ADB0C1E-FE27-371C-8EC3-69D5CFEA2BE7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x959cf000 - 0x959d0ff5 libremovefile.dylib (21.0.0 - compatibility 1.0.0) <9A1E12B7-F822-3544-8E1D-A6DC81E1F2E6> /usr/lib/system/libremovefile.dylib
0x959d1000 - 0x959e8ff8 com.apple.CoreMediaAuthoring (2.0 - 889) <49B55753-BD7E-3889-BA60-15294DA49CB7> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x959e9000 - 0x95ab4fff libsystem_c.dylib (763.11.0 - compatibility 1.0.0) <44AA09FD-3A8F-3DCF-AD98-BC9071CA7376> /usr/lib/system/libsystem_c.dylib
0x95ab5000 - 0x95aebfff com.apple.DebugSymbols (2.1 - 85) <0F996A4A-16A7-3C90-8037-0E2958D1FB16> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x95aee000 - 0x95af1ffb com.apple.help (1.3.2 - 42) <DDCEBA10-5CDE-3ED2-A52F-5CD5A0632CA2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x95b42000 - 0x95b52ff7 libCRFSuite.dylib (??? - ???) <CE616EF3-756A-355A-95AD-3472A876BEB9> /usr/lib/libCRFSuite.dylib
0x95b53000 - 0x95b53fff com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <CB952B04-595A-332B-992B-7671815750FD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x95b54000 - 0x95e54fff com.apple.CoreServices.CarbonCore (960.13 - 960.13) <E098AC3A-E795-3C28-BA92-EED51C461A6F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x95e55000 - 0x95e74fff com.apple.RemoteViewServices (1.0 - 1) <D9810485-6A62-3758-96F5-48950AF250F1> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x95e75000 - 0x95eb8ffd libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <4BA1F5F1-F0A2-3FEB-BB62-F514DCBB3725> /usr/lib/system/libcommonCrypto.dylib
0x95eb9000 - 0x9612affb com.apple.CoreImage (7.77 - 1.0.1) <DF1D9EB7-5879-3EA2-8CF5-80004DAC18BC> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x9612b000 - 0x9617cff9 com.apple.ScalableUserInterface (1.0 - 1) <C3FA7E40-0213-3ABC-A006-2CB00B6A7EAB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x9617d000 - 0x96185ff3 liblaunch.dylib (392.18.0 - compatibility 1.0.0) <CD470A1E-0147-3CB1-B44D-0B61F9061826> /usr/lib/system/liblaunch.dylib
0x96186000 - 0x9621aff7 com.apple.LaunchServices (480.19 - 480.19) <A68C0688-4ED1-35F1-BF44-F5B1917084A0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9621b000 - 0x962a2fff com.apple.print.framework.PrintCore (7.0 - 366) <D037D344-7463-3620-AE8F-8D0D3EA5CE8E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x962a3000 - 0x962f3ff4 libTIFF.dylib (??? - ???) <25796A90-ABD2-3A3A-800C-1056D343A71F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x962f4000 - 0x963d7ff7 libcrypto.0.9.8.dylib (0.9.8 - compatibility 0.9.8) <6E631200-1E22-37B9-85D1-EC40520891AB> /usr/lib/libcrypto.0.9.8.dylib
0x963d8000 - 0x963e6fff com.apple.opengl (1.7.4 - 1.7.4) <C6DE3D3A-CC1F-3F55-B8DD-2637FA40058F> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x96883000 - 0x968dfff3 com.apple.Symbolication (1.2 - 83.1) <E651A2F1-CC13-3DDD-9B0A-09180014966B> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x968e0000 - 0x968e8ff5 libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <A1BFC320-616A-30AA-A41E-29D7904FC4C7> /usr/lib/system/libcopyfile.dylib
0x96a77000 - 0x96a78ff7 libquarantine.dylib (36.0.0 - compatibility 1.0.0) <70782AEC-8933-3EB4-91CA-E44C0E768C90> /usr/lib/system/libquarantine.dylib
0x96a79000 - 0x96a79ff0 com.apple.ApplicationServices (41 - 41) <BED33E1D-C95C-3654-9A3A-0CB3607F9F10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x96a7a000 - 0x96ac1fff com.apple.SystemConfiguration (1.11 - 1.11) <A7769080-2A4F-36AF-9484-08A936690307> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x96ad3000 - 0x96c34ffb com.apple.QuartzCore (1.7 - 269.0) <221FF6A0-9C2C-3977-BC2A-A84C392BA49B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x96c35000 - 0x96c35fff com.apple.audio.units.AudioUnit (1.7 - 1.7) <75E38B34-1DE2-337A-A09F-0F7E91C02ABB> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x96c36000 - 0x96c38ff7 libdyld.dylib (195.5.0 - compatibility 1.0.0) <637660EA-8D12-3B79-B644-041FEADC9C33> /usr/lib/system/libdyld.dylib
0x96ff2000 - 0x9704bff3 com.apple.coreui (0.3 - 162) <BD3FBC84-234A-38E0-AA29-DE0424D3FD16> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9704c000 - 0x97054ff3 libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
0x97055000 - 0x97059ffa libcache.dylib (47.0.0 - compatibility 1.0.0) <98A82BC5-0DD9-3212-9CAE-35A77278EEB6> /usr/lib/system/libcache.dylib
0x97413000 - 0x97413fff com.apple.vecLib (3.7 - vecLib 3.7) <A01CD788-26FB-320F-8617-5A7DF0F9031E> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x97420000 - 0x97448ff7 libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <FCAC685A-724F-3FE7-8416-146108DF75FB> /usr/lib/libxslt.1.dylib
0x9747c000 - 0x97482ffb com.apple.print.framework.Print (7.0 - 247) <1140BB03-0720-308F-8D92-F71B347D63D6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x97483000 - 0x974b1ffb com.apple.DictionaryServices (1.2 - 158) <C614930F-520D-3F77-AD0D-0E16FBCB98CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x974b2000 - 0x974b6ff7 com.apple.OpenDirectory (10.7 - 144) <A117580D-FD86-381E-82FD-B1A040045031> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x974b7000 - 0x974baffc libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
0x974bb000 - 0x975abff1 libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
0x975ac000 - 0x975edff7 com.apple.CoreMedia (1.0 - 705.35) <8A487271-FBEA-357A-8887-27BAA355314C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x975ee000 - 0x976fdff7 libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <01987A45-9270-30FD-8A67-5E53DB637909> /usr/lib/libsqlite3.dylib
0x976fe000 - 0x9770ffff libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
0x97797000 - 0x9779ffff com.apple.DiskArbitration (2.4 - 2.4) <E574D5E7-7297-33B5-8B91-1E6346D5F917> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x977a0000 - 0x97805ff7 libvDSP.dylib (325.3.0 - compatibility 1.0.0) <1C4B66EB-3186-31BE-B93F-878E49334C49> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x9780a000 - 0x9780dffd libCoreVMClient.dylib (??? - ???) <1438A7D5-A622-3623-A49F-45F881B1D947> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x9780e000 - 0x9783eff7 libsystem_info.dylib (??? - ???) <C385F5A9-458A-3B49-9CC7-EA81DC5F9141> /usr/lib/system/libsystem_info.dylib
0x9783f000 - 0x9788ffff libFontRegistry.dylib (??? - ???) <BC35B8F5-7CCA-3A04-A278-FA3306B2C4F8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x97982000 - 0x979f0fff com.apple.Heimdal (2.1 - 2.0) <5BA5BFA4-0B05-3B00-AF06-C3D0D60F36BC> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x97a61000 - 0x97a62fff libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
0x98565000 - 0x98958ff7 com.apple.VideoToolbox (1.0 - 705.35) <B0D04F08-D3EB-370A-A56F-8AF01116B0D0> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x98959000 - 0x98960fff libnotify.dylib (80.0.0 - compatibility 1.0.0) <B3B3875D-311D-31A7-A09F-D1BC56795E00> /usr/lib/system/libnotify.dylib
0x98961000 - 0x9899ffff com.apple.NavigationServices (3.6 - 192) <CB7AE807-9292-3EBA-A5F5-D7DCEE28A5B7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x989a0000 - 0x996f0fe3 com.apple.QuickTimeComponents.component (7.7.1 - 2246) <AD39FCD8-72EB-32C4-9B3F-5776BD3ECA52> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x996f1000 - 0x9972dffa libGLImage.dylib (??? - ???) <7A150184-E3F7-3773-917A-A5E24B9241FA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x99b77000 - 0x99bb7ff7 libauto.dylib (??? - ???) <36E7FE7F-27DF-3301-80AA-DD61FBF722F4> /usr/lib/libauto.dylib
0x99bb8000 - 0x9a00dfff FaceCoreLight (1.4.2 - compatibility 1.0.0) <53AC5DCE-D04B-3DC3-808D-AA1CAD4D0924> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x9a08e000 - 0x9a097ff3 com.apple.CommonAuth (2.1 - 2.0) <94EA2555-212C-3704-8307-FCEE5D6D32C5> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x9a098000 - 0x9a09bff7 libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
0x9a09c000 - 0x9a0a2ffd com.apple.CommerceCore (1.0 - 17) <71641C17-1CA7-3AC9-974E-AAC9EB641035> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x9a0b8000 - 0x9a0bfff5 libsystem_dnssd.dylib (??? - ???) <B3217FA8-A7D6-3C90-ABFC-2E54AEF33547> /usr/lib/system/libsystem_dnssd.dylib
0x9a0c0000 - 0x9a0c0ff2 com.apple.CoreServices (53 - 53) <C513E133-B0E0-3C35-A7CB-DBC35A7EF571> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x9a0c1000 - 0x9a0c6ff7 libmacho.dylib (800.0.0 - compatibility 1.0.0) <56A34E97-518E-307E-8218-C5D43A33EE34> /usr/lib/system/libmacho.dylib
0x9a0c7000 - 0x9a260ff7 com.apple.CoreData (103 - 358.4) <EB07F3A5-6301-3DA4-96FC-F8381D148C69> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9a269000 - 0x9a2f6fe7 libvMisc.dylib (325.3.0 - compatibility 1.0.0) <A44ADE1B-AB2C-3585-8C9D-D85B526E66C0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9a48d000 - 0x9a491ff3 libsystem_network.dylib (??? - ???) <E1455F3E-549B-3D50-A38B-17B394F3C7F6> /usr/lib/system/libsystem_network.dylib
0x9a49c000 - 0x9a74dff7 com.apple.security (7.0 - 55010) <28168576-1B8C-3FE8-9356-DE79390A480A> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9a750000 - 0x9a751ff7 libsystem_sandbox.dylib (??? - ???) <BC0A04E9-4F28-3BC8-AA7B-63C3451E9212> /usr/lib/system/libsystem_sandbox.dylib
0x9a789000 - 0x9a78afff libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
0x9a7e5000 - 0x9a999ff3 libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6270318A-CA9A-376C-AD6D-64A9B4B4A26E> /usr/lib/libicucore.A.dylib
0x9a9a6000 - 0x9a9baff7 com.apple.CFOpenDirectory (10.7 - 144) <665CDF77-F0C9-3AFF-8CF8-64257268B7DD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x9a9bd000 - 0x9a9c8ffc com.apple.NetAuth (1.0 - 3.0) <C07853C0-AF32-3633-9CEF-2480860C12C5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x9a9c9000 - 0x9a9c9ffe libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
0x9a9e2000 - 0x9b05dff9 com.apple.CoreAUC (6.11.03 - 6.11.03) <E8553EC9-6A7E-339E-B346-A5853649D3A0> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x9b289000 - 0x9b2aeff9 libJPEG.dylib (??? - ???) <5872B388-D6CC-3DD4-A2F3-8BB464E83D14> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x9b2af000 - 0x9b2b1ffc com.apple.QuickTimeH264.component (7.7.1 - 2246) <550B5A0D-0EFF-30F9-91E3-23D17F53BBA8> /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x9b2b2000 - 0x9b312ffb com.apple.audio.CoreAudio (4.0.0 - 4.0.0) <6026C895-3DC6-3785-A7BB-2F2B9E292D95> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x9b313000 - 0x9b313fff com.apple.Cocoa (6.6 - ???) <650273EF-1ABC-334E-B745-B75AF028F9F4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x9b9af000 - 0x9bacffec com.apple.vImage (5.0 - 5.0) <173F6343-07EE-39F7-A159-DD3837E473DE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x9bad0000 - 0x9bafbfff com.apple.GSS (2.1 - 2.0) <129F4AB0-41AC-3713-A7BC-921769B0E12D> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x9be66000 - 0x9be8eff0 com.apple.CoreServicesInternal (113.7 - 113.7) <F5724FAC-8BB8-3F0F-B8BC-36F2CA75A23D> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x9bf87000 - 0x9bf8efff com.apple.agl (3.1.4 - AGL-3.1.4) <CCCE2A89-026B-3185-ABEA-68D268353164> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x9bf8f000 - 0x9bf9afff libkxld.dylib (??? - ???) <088640F2-429D-3368-AEDA-3C308C4EB80C> /usr/lib/system/libkxld.dylib
0x9bf9b000 - 0x9c60065b com.apple.CoreGraphics (1.600.0 - ???) <DD3B7ADA-0F19-371E-BB87-F3C08464134A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9c601000 - 0x9c637ff7 com.apple.AE (527.6 - 527.6) <77999151-94E3-37CD-A49E-7A9F9084F886> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9c656000 - 0x9c674ff7 libsystem_kernel.dylib (1699.22.73 - compatibility 1.0.0) <D32C2E9C-8184-3FAF-8694-99FC619FC71B> /usr/lib/system/libsystem_kernel.dylib
0x9c675000 - 0x9c698fff com.apple.CoreVideo (1.7 - 70.0) <0CBE6F3B-34C7-3C6B-9BB1-826F9905ECC1> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 3
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 4584
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=175.4M resident=107.1M(61%) swapped_out_or_unallocated=68.3M(39%)
Writable regions: Total=169.6M written=58.4M(34%) resident=64.6M(38%) swapped_out=0K(0%) unallocated=105.0M(62%)
REGION TYPE VIRTUAL
ATS (font support) 32.9M
CG backing stores 3708K
CG shared images 1224K
CoreGraphics 8K
CoreServices 1428K
MALLOC 96.0M
MALLOC guard page 32K
MALLOC_LARGE (reserved) 392K reserved VM address space (unallocated)
Memory tag=240 4K
Memory tag=242 12K
Memory tag=243 4K
Memory tag=249 156K
SQLite page cache 192K
Stack 69.6M
VM_ALLOCATE 16.1M
VM_ALLOCATE (reserved) 40K reserved VM address space (unallocated)
__CI_BITMAP 80K
__DATA 17.3M
__DATA/__OBJC 60K
__IMAGE 1256K
__IMPORT 4K
__LINKEDIT 45.3M
__OBJC 1460K
__OBJC/__DATA 104K
__PAGEZERO 4K
__TEXT 130.0M
__UNICODE 544K
mapped file 150.0M
shared memory 364K
shared pmap 8424K
TOTAL 576.2M
TOTAL, minus reserved VM space 575.8M
Model: MacBookPro8,1, BootROM MBP81.0047.B0E, 2 processors, Intel Core i5, 2.3 GHz, 4 GB, SMC 1.68f96
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 384 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.100.98.75.6)
Bluetooth: Version 2.5.0f17, 2 service, 12 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: TOSHIBA MK3265GSXF, 320.07 GB
Serial ATA Device: MATSHITADVD-R UJ-898
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0xfa200000 / 3
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfa100000 / 2
USB Device: iPhone, apple_vendor_id, 0x1297, 0xfa130000 / 7
USB Device: BRCM2070 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 5
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821a, 0xfa113000 / 6
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0246, 0xfa120000 / 4
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfd100000 / 2
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
Report Version: 9
VM Regions Near 0:
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 11:
cr2: 0x00000000
Logical CPU: 0
Binary Images:
task_for_pid: 3
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 4584
thread_create: 0
thread_set_state: 0
VM Region Summary:
REGION TYPE VIRTUAL
CoreGraphics 8K
CoreServices 1428K
MALLOC 96.0M
Memory tag=240 4K
Memory tag=242 12K
Memory tag=243 4K
Memory tag=249 156K
Stack 69.6M
VM_ALLOCATE 16.1M
__CI_BITMAP 80K
__DATA 17.3M
__DATA/__OBJC 60K
__IMAGE 1256K
__IMPORT 4K
__LINKEDIT 45.3M
__OBJC 1460K
__OBJC/__DATA 104K
__PAGEZERO 4K
__TEXT 130.0M
__UNICODE 544K
mapped file 150.0M
shared memory 364K
shared pmap 8424K
TOTAL 576.2M
geposted Sun 14 Aug 11 @ 3:08 am
I had major issues. I'll start out by saying, "Tech Support here at VDJ is first rate."
I'm running a MBP 13" mid-2010 with 8gb ram, 500gb 7200 hybrid drive. upon upgrading to lion, I've recieved random program kernal panics, and the famous black screen of death.
I recently purchased the DN-MC6000. Using this midi board with VDJ Pro, I find freezes every 20-50 minutes. I particuraly find these freezes when loading Deck A whil Deck B is playing. Not sure why it's that way.
I read hundreds of post and recieved strong support form VDJ. After reading many Apple post, I realized that many mid-2010 mbp users have experienced black screens and freezes. I'm glad I filed a ticket, because my warranty runs out in 10 days. Now, they have filed an exemption to resolve my issue.
Tested ram, HD, video and reformatted and reinstalled 3 times, the 3rd per apple. I've just reimaged back to Snow Lepord for my gig this weekend. I plan on practicing for 4-5 hours tomorrow to test the laptop against crashes. I'll update post.
Monday, I'll put the other drive back in with Lion and ship it off to Apple. From my readings, Apple has had issue with the Mid-2010 MBP logic boards. I'd suggest starting a claim before your apple care expires.
geposted Mon 15 Aug 11 @ 9:24 pm
OS X 10.7.1 has just been released. I am testing It right about now, So far so good.
http://support.apple.com/kb/DL1438
geposted Tue 16 Aug 11 @ 8:12 pm
yep I grabbed it earlier, need a little more time before I give the all clear.
geposted Tue 16 Aug 11 @ 10:04 pm
I'm having no issues whatsoever with lion, before or after yesterdays update. i'm using a new 15' macbook pro with a denon mc6000
geposted Wed 17 Aug 11 @ 1:42 pm
Does anyone know if Mac OS lion is compatible with older Virtual Dj Software?
geposted Wed 17 Aug 11 @ 7:44 pm
probably not, but why would you want you want to use an older version? registered users get free updates for life.
geposted Thu 18 Aug 11 @ 6:43 pm
JUST WANT TELL THAT I HAD THE SAME PROBLEM AND IT APPEARS THAT FOR SOME MAC PRO LAPTOS WORKS AND OTHER DONT. OF COURSE MINE DIDNT BUT IF YOU GET THE VDJ VERSION 7.02 THAT WILL DEFINITELY WORK.
geposted Thu 18 Aug 11 @ 7:53 pm
Report Version: 9
VM Regions Near 0:
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 11:
cr2: 0x00000000
Logical CPU: 0
Binary Images:
task_for_pid: 3
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 4584
thread_create: 0
thread_set_state: 0
VM Region Summary:
REGION TYPE VIRTUAL
CoreGraphics 8K
CoreServices 1428K
MALLOC 96.0M
Memory tag=240 4K
Memory tag=242 12K
Memory tag=243 4K
Memory tag=249 156K
Stack 69.6M
VM_ALLOCATE 16.1M
__CI_BITMAP 80K
__DATA 17.3M
__DATA/__OBJC 60K
__IMAGE 1256K
__IMPORT 4K
__LINKEDIT 45.3M
__OBJC 1460K
__OBJC/__DATA 104K
__PAGEZERO 4K
__TEXT 130.0M
__UNICODE 544K
mapped file 150.0M
shared memory 364K
shared pmap 8424K
TOTAL 576.2M
Report Version: 9
VM Regions Near 0:
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 11:
cr2: 0x00000000
Logical CPU: 0
Binary Images:
task_for_pid: 3
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 4584
thread_create: 0
thread_set_state: 0
VM Region Summary:
REGION TYPE VIRTUAL
CoreGraphics 8K
CoreServices 1428K
MALLOC 96.0M
Memory tag=240 4K
Memory tag=242 12K
Memory tag=243 4K
Memory tag=249 156K
Stack 69.6M
VM_ALLOCATE 16.1M
__CI_BITMAP 80K
__DATA 17.3M
__DATA/__OBJC 60K
__IMAGE 1256K
__IMPORT 4K
__LINKEDIT 45.3M
__OBJC 1460K
__OBJC/__DATA 104K
__PAGEZERO 4K
__TEXT 130.0M
__UNICODE 544K
mapped file 150.0M
shared memory 364K
shared pmap 8424K
TOTAL 576.2M
JUST WANT TO TELL YOU THAT I HAD THE SAME PROBLEM AND IT APPEARS THAT FOR SOME MAC PRO LAPTOS WORKS AND OTHER DONT. OF COURSE MINE DIDNT BUT IF YOU GET THE VDJ VERSION 7.02 THAT WILL DEFINITELY WORK. I HAVE THE NEW MAC PRO AND COULD NOT RUN VDJ 7.05 BECAUSE OF THE INVALID SKIN FILE ERROR.
geposted Thu 18 Aug 11 @ 7:59 pm
KANIFORM wrote :
Since I installed Lion my version of Virtual DJ Pro crashes before it opens. I've tried uninstalling and reinstalling and making sure everything's up to date. Any ideas / anyone else experienced this?
geposted Thu 18 Aug 11 @ 8:06 pm
Dude no need to shout lol, mind the CAPS
geposted Sat 20 Aug 11 @ 6:07 pm
Wow...wow...Wow... Video mixing is so so so much smoother & leaner running OSX Lion using my old Macbook with VirtualDJ Pro full 7.0.5 Mac!!
I had a wedding In New Jersey this past Friday and a Christening In Long Island NY this past Saturday doing live video mixing and running Lion and VirtualDJ Pro Full 7.0.5 Mac. Everything went smooth. I am very Impressed with Lion and also VirtualDJ. There are still some room to make Improvements on Virtual side to make the app runs even a lot leaner and less power hungry, but I am very Impressed.
VirtualDJ staff, keep up the good work.
geposted Sun 21 Aug 11 @ 8:33 am
