Hello ,
The gain can be set on off ( gain like track ) auto-remember ( auto 0 db or if you set the gain different ) and remember ( like you set it the last time )
For a better sound there must be a ''gain copy from the other deck'' so you can pitch up the gain and the hole evening the volume is the same.
Gr Marco
Gr Marco
geposted Tue 09 Aug 11 @ 12:24 pm
+1
geposted Wed 10 Aug 11 @ 4:54 am
I'm pretty sure that is why you have the master, you should just let vdj set the gain and leave it
geposted Wed 10 Aug 11 @ 6:12 am
I agree it needs to be better, but I believe it just needs a wider range. When going from standard audio tracks to music videos, videos are often allot lower in volume. Auto gain will just peg the gain sometimes and it will still be lower than the other deck.
+1
+1
geposted Wed 10 Aug 11 @ 10:59 am
+ 1
geposted Mon 15 Aug 11 @ 5:20 pm
+1
geposted Tue 30 Aug 11 @ 8:07 pm
+1
geposted Wed 31 Aug 11 @ 2:35 am
+1
geposted Wed 31 Aug 11 @ 10:16 am
Don't know why you'd need to do that. All it needs is the ability to change the normalization value from 0dB to something else, like -3dB or -6dB. That's what Serato, Traktor, and Torq 2 all let you do. Simple solution that allows mild summation volume increases and EQ without having to touch the master volume to prevent 0dBFS. VDJ's gain remembering system for manual use is already quite sophisticated. I assume VDJ 8 will be adding an optional master compressor, but unless you want it crushing the dynamics constantly, something lower than zero as the default is needed.
geposted Wed 26 Dec 12 @ 7:25 pm
This is an old topic now with the new Headroom and Limiter options that were added in version 7.3.
Topic Closed
Topic Closed
geposted Wed 26 Dec 12 @ 8:47 pm
