Forum: Old versions
Topic: Stanton SCS.4DJ - Setup, Mappings, and Display Enhancement files - Page: 2
If you got the full version of vdj pro, you should email support with your purchase details so they can correct the mistake and you will be able to download the mapper once it is fixed... They are very good, they were able to tell me their problem with my credit card when I originally purchased pro, so they should be able to track your purchase.
http://www.virtualdj.com/contact/index.html
geposted Mon 26 Mar 12 @ 4:24 pm
cstollPRO InfinityMember since 2004
DJCRYSIXBLAZE wrote :
i said that, but it was vdj pro.
You have purchased Broadcaster - look your Download Center and Profile - it says Broadcaster.
If you want to download skins and mappers you must be a PRO FULL licensed user - you can upgrade here - http://www.virtualdj.com/buy/index.html
geposted Mon 26 Mar 12 @ 4:49 pm
@NNSK - Please do not supply links to locations that are not 'official' site links.
If you want to help promote a firmware upgrade then provide a link to the Official Stanton location like this --
New firmware for the SCS.4DJ has been released. Can be downloaded from here -
http://www.stantondj.com/stanton-controllers-systems/scs4dj.html
geposted Mon 16 Jul 12 @ 6:31 pm
ciocePRO InfinityMember since 2004
The new firmware v3.0 is only available in the Gibson forum for the moment and it's necessary to be registered to download it.
cioce wrote :
NEW firmware 3.0 is out for Stanton SCS.4DJ
New Features:
• BeatGrid editing - The ability to edit a track’s beatgrid in real-time, with both Tap Tempo and "Dial-In-BPM" functionality, for increased Sync and Loop accuracy and stability.
• 3 Hot cues per deck – Quick access buttons on the home/waveform screens to add and delete Hot cues. Hot cues are remembered through power cycles.
• Optimized system management – Switching screens is now much faster. Navigating large libraries/playlists is more responsive and precise. Performance gains are seen throughout the system.
• Loop memory - User-created loops are remembered through power cycles, allowing for more powerful set preparation.
• Broader device support for smart phones, MP3 players and tablet computers.
Improvements:
• Headphone Gain Boost now selectable via a menu item.
• Improved recording to USB media.
• When a deck is paused, scratch functionality is automatically enabled to provide fine seeking and setting of cue points.
http://forum.gibson.com/index.php?/topic/89199-scs4dj-v30-update/
geposted Tue 17 Jul 12 @ 4:00 am
I buy a Stanton SCS4 and need a mapper for that. Im trying to download in addons section in this website but no links here.
everyone can help me pls or send to me this mappers?? my email is removed
thanks very much
have a good day
best regards
geposted Mon 27 Aug 12 @ 4:29 pm
If you are a licensed user, then register your serial so you can get access to the downloads.
If not, purchase a license - http://www.virtualdj.com/buy/index.html - and then you can download the mappers.
geposted Mon 27 Aug 12 @ 5:57 pm
Please help me to install my scs.4dj in midi mode. I have downloaded the files but nothing happens when I turn the controller into midi mode... What steps should I follow? I need it for a gig soon! Thank you very much.
Mikidj
geposted Tue 28 Aug 12 @ 7:42 pm
Problem with mapper solved but no way of setting up my external sound device (Alesis I/O2 Express) in midi mode in order to do a prelistening (PFL) for each deck... snif!
geposted Thu 30 Aug 12 @ 2:37 am
The new update 3.01 does not appear on Stanton web page any more but on Gibson Forums page: http://forum.gibson.com/index.php?/topic/90012-scs4dj-301-update-new/page__p__1234219#entry1234219
I hope this helps.
Regards,
MIKIDJ
New Features:
Improvements:
geposted Thu 30 Aug 12 @ 2:52 am
I have owned my Stanton SCS4dj for almost a year and used it with one active speaker to do mobile djing. All of a sudden I am having problems with the speaker going in and out. I was doing a gig and was 2 hours in when it went out. I thought it may be the speakers until I bough a new activce speaker and tried it. I had the same problem. Then I thought maybe I should hook both up so the power coming out would be more balanced on the output. It stopped cutting out but I had a little feedack. The speakers are differnt models and wattage so maybe I need to fool with the output levels of both to find good settings? Help!!!
geposted Sun 28 Oct 12 @ 2:01 pm
gg1995Home userMember since 2013
i would to know the steps about using SCS4DJ with virtual dj....please!!!
geposted Sun 09 Jun 13 @ 4:43 am
1. Purchase the full VirtualDJ Professional which natively supports it in the latest version: http://www.virtualdj.com/buy/index.html
2. Plug the controller into your computer, put it into MIDI mode (See the user manual) and then start VirtualDJ Pro.
If you have already purchased VirtualDJ Pro, then please register your Pro serial number to your account http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it at your gigs.)
You can test it before purchasing for 10 minutes at a time in VirtualDJ Home FREE: http://www.virtualdj.com/download/free.html
geposted Sun 09 Jun 13 @ 11:17 am
NeeKooHome userMember since 2013
Hello, guys ! I am having trouble with my setup No sound in headphones and I can't control Master Volume on Stanton as well:( I am using Stanton SCS4DJ as midi controller along with Virtual Dj Pro, I just update firmware on my Controller to current which is 4.0.1 My sound card is Juli@ . How come there is no sound in Hedphones i don't get it... It's works fine in normal mode...
geposted Fri 30 Aug 13 @ 6:25 am
I have a scs.4dj with vdj8 and have mapped my mpd32 to trigger hot cues and samples. My question is what command is used to trigger deck A hot cues? or deck B? I'm using hot_cue 1 but it doesn't distinguish A or B so it jumps back and forth. And also I would like to map the vdj8 custom buttons to the scs.4dj hot cue buttons.. Not sure what to assign to them but I wont need two sets of hot cue buttons. I prefer the mpd32 for hot cues. Any Ideas?
geposted Mon 27 Jul 15 @ 8:48 pm
Hi, i have the scs 4dj, os 5.0.1. After the upgrade i am having issues with all usb drives recognising all usb. I have to reboot the scs 4dj a few times (5+) for the usb to he recognised.
Q: how long after boot up should i wait. Is 24 hrs acceptable
Q i am a it engineer and have been trained/experience to recognise faults and this seems to me to be a boot issue as the unit works fine once usb drives are recognised. Any tips anyone
geposted Fri 18 Mar 16 @ 9:14 am
24 hours is rather excessive with version 5.0.1...I had the same issue in the past when I was running version 4 and earlier, it took forever to load, and would lock up almost immediately and was practically unusable as a stand alone system, so I just used as a midi controller forever, but would also keep a VERY SMALL flash drive (512 MB or less preferred) 1 GB MAX with me in case of computer crash.... but make sure you are using the correct format with the drives. NTFS is best, but since you are still having major lag, you should probably format it as FAT 32. Also you should be analyzing all your files prior to putting the drives into the SCS 4 DJ with the newest version of QUICK GRID and be sure you are running version 5.0.1 of the firmware. If you are following all of these steps prior, then just be sure to let the machine analyze you're drives while you are at home, or not at a gig and PUT YOUR DRIVES IN THE BOTTOM BAY and DON'T REMOVE THEM AFTER FINALIZING ANALYSIS!!! In the newest firmware, the software has been set to retain the memory of your drives even after multiple power cycles (ONLY IF YOU DON'T REMOVE THE DRIVES BETWEEN CYCLES!!!) So, after you deal with the long ass loading time once, you never have to deal with them again. I hope this helps... I have been super excited about the newest state of the SCS 4 DJ, as I believe they prematurely released the system years ago without it being stable enough to even feel comfortable using it in a live set. Now, since having the newest upgrade and testing it thoroughly at home, I've used it to play out multiple times. Hope this helps shed some light on the problems you have been having, and helps you get your problems under control. Have a good one!!!
geposted Tue 29 Mar 16 @ 11:45 am
Üdv uraim !
A következő problémám van az SCS.4DJ készülékkel
Bekapcsolás után a képernyő Nothing display felirattal megáll ! kezelőszervekre nem reagál . Usb tápkimenet nincs. és nem olvas be .
Ha van valakinek ötlete a hiba elhárítására megköszönném .
geposted Wed 07 Nov 18 @ 7:09 am
